Recently I've noticed that no matter which Upload Interval I choose for the AWEKAS (Under the Weather Nets Tab), the upload occurs every 5 minutes.
I had it set for 30 minutes. I've tried each of the intervals, but it still uploads every 5 minutes. Is this a known issue? Seems like it use to do it correctly. I've tried rebooting the Meteobridge Pro, but it didn't help. Thank you.
Weather Nets AWEKAS Upload Interval **solved**
Re: Weather Nets AWEKAS Upload Interval
I assume you did a "Save" before rebooting?
Yes, I did. I am also running the latest software version. Please help if possible. Thank you!
Is anyone else uploading to AWEKAS and experiencing this same issue? Thank you.
Does the web interface of the Meteobridge show 30 min upload interval after you specify this and press "save"? Or is it flipping back to 5 mins on the web interface.
It still showed the 30 minute interval. It did not flip back. However, an update was posted today. I downloaded it and it has corrected the issue.
Thank you for your attention to this!
