Weather Nets AWEKAS Upload Interval **solved**
ORNTX19
Post by ORNTX19 »
Recently I've noticed that no matter which Upload Interval I choose for the AWEKAS (Under the Weather Nets Tab), the upload occurs every 5 minutes.
I had it set for 30 minutes. I've tried each of the intervals, but it still uploads every 5 minutes. Is this a known issue? Seems like it use to do it correctly. I've tried rebooting the Meteobridge Pro, but it didn't help. Thank you.
Ron
Davis VP2
Meteobridge Pro
www.oakridgewx.net
Re: Weather Nets AWEKAS Upload Interval
I assume you did a "Save" before rebooting?
ORNTX19
Post by ORNTX19 »
Yes, I did. I am also running the latest software version. Please help if possible. Thank you!
Ron
Davis VP2
Meteobridge Pro
www.oakridgewx.net
ORNTX19
Post by ORNTX19 »
Is anyone else uploading to AWEKAS and experiencing this same issue? Thank you.
Ron
Davis VP2
Meteobridge Pro
www.oakridgewx.net
Does the web interface of the Meteobridge show 30 min upload interval after you specify this and press "save"? Or is it flipping back to 5 mins on the web interface.
ORNTX19
Post by ORNTX19 »
It still showed the 30 minute interval. It did not flip back. However, an update was posted today. I downloaded it and it has corrected the issue.
Thank you for your attention to this!
Ron
Davis VP2
Meteobridge Pro
www.oakridgewx.net
