On my Local Dashboard i get since two days no forecast. I have nothing change (darksky key).
Firmware 4.0 22.06.
Does anyone have that yet?
Nano SD: Local Dashboard Forecast empty **solved**
- 8CAF201B-9ED7-447B-97C8-9DCD411E7945.jpeg (80.43 KiB) Viewed 4745 times
Re: Nano SD: Local Dashboard Forecast empty
the same thing for me
My DarkSky Account says, i have used up my free 1000 calls for a day!
This behaiver comes with new Firmware from 22.06. and this must be a bug, Boris please fix it!
- 5F2EDC11-A4E8-4448-8507-34F526792AF0.jpeg (109.03 KiB) Viewed 4707 times
Also updated to the 4.0 6-22 release with same result.
- ConligWX
can confirm here too on the Nano SD.
Darksky however is working on my website so it must be some issue with the PWS install.
Regards Simon
https://www.conligwx.org/pws
I have the same problem
- ConligWX
I hope hope Boris sees this soon.
Regards Simon
Boris has released a new update ( July 7 ) that fixes the Dashboard forecast missing problem. I installed it and the Dashboard is working fine again.
I did discover that all of my Dashboard settings had reset to defaults including the password I created for the dashboard settings itself and I had to input them manually and save them just like the first time I set it up.
Re: Nano SD: Local Dashboard Forecast empty **solved**
Yes, it‘s fixed.
Thanks!
Thanks!
