Nano SD: Local Dashboard Forecast empty **solved**
On my Local Dashboard i get since two days no forecast. I have nothing change (darksky key).
Firmware 4.0 22.06.
Does anyone have that yet?
xxvincixx
Re: Nano SD: Local Dashboard Forecast empty
Post by xxvincixx »
the same thing for me
My DarkSky Account says, i have used up my free 1000 calls for a day! :shock:
This behaiver comes with new Firmware from 22.06. and this must be a bug, Boris please fix it!
BigAlT
Post by BigAlT »
Also updated to the 4.0 6-22 release with same result.
ConligWX
Post by ConligWX »
can confirm here too on the Nano SD.
Darksky however is working on my website so it must be some issue with the PWS install.
mthiessen
Post by mthiessen »
I have the same problem
ConligWX
Post by ConligWX »
I hope hope Boris sees this soon.
BigAlT
Post by BigAlT »
Boris has released a new update ( July 7 ) that fixes the Dashboard forecast missing problem. I installed it and the Dashboard is working fine again.
I did discover that all of my Dashboard settings had reset to defaults including the password I created for the dashboard settings itself and I had to input them manually and save them just like the first time I set it up.
Re: Nano SD: Local Dashboard Forecast empty **solved**
Yes, it‘s fixed.
Thanks!
