Nano SD pushing to Weather34 template
dtrop1
Post by dtrop1 »
Good Day.
Just got started with my station and everything. I have a Davis 6163 with the Nano SD. So far everything is working great and pushing up to the online services for weather data.
I'm preparing my own site based on the weather34 Beta template. Currently it is running on my Mac at home running MAMP.
It doesn't look like any charts or realtime data is updating. The php files on the server have not been modified. So, i'm either thinking it is a issue with the URL for Home Weather STation in the Weather nets section of the setup. I'm using http://yourdomain/mbridge/MBrealtimeupload.txt with my domain changed to the right one or i've tried the IP address of the server directly. I'm planning to eventually move this to a hosting service.
I thought it was a permissions issue and changed the permissions on the files for R/W for everyone. at least thru the mac GUI. I guess i should look at it via terminal.
Here is the screenshot of the error.
Screen Shot 2019-07-31 at 11.17.23 AM.png (85.42 KiB) Viewed 2038 times
Thanks for the help
Re: Nano SD pushing to Weather34 template
you will need to verify meteobridge can see the localhost or server . hence the red cross indicates it can not be reached .
which port ? http://<ip>:<port>/
i use Xampp on an old 2009 mac mini that is just acting as a server without a keyboard or monitor .
path if accessible/viewable to meteobridge I use simple localhost:80/folder/file in my case
http://localhost:80/Meteobridge-Beta/mbridge/mb.php
caution the beta version is not ready for prime time and unlikely to be complete until mid-late december its a slow process of taking each day to work on one thing..but its getting there now going through the dilemma of do i keep languages,reduce then to four languages or continue with them..
i would safely use the trusted meteobridge version maintained by william at https://github.com/weather34/Meteobridge-MB-SMART
...brian
screenshot running on localhost realtime. edit forgot to add path screenshot ..
Screenshot at Jul 31 22-25-58.png (414.16 KiB) Viewed 2022 times
Screenshot at Jul 31 21-13-10.png (96.02 KiB) Viewed 2032 times
also i should add make sure all php modules are running some default php installs disable some php modules.. include,fopen etc...create a phpinfo file and run it to show if any php modules are disabled ..
