Twitter Error **solved**
MeteoOudkarspel
Post by MeteoOudkarspel »
I get the following message with regard to the update of 25-08-2019:
Error: twitter registration failed: openssl: can't resolve symbol 'COMP_zlib_cleanup'
Error: Twiter feed from Meteobridge not yet authorized
And this message appears in the Weather Network status:
Twitter upload:
2019-08-25 21:09:55 Error: 2019-08-25 21:09:23 openssl: can't resolve symbol 'COMP_zlib_cleanup' openssl: can't resolve symbol 'COMP_zlib_cleanup' error (215): "Bad Authentication data." (no more tries)
Sincerely,
Re: Twitter Error
Thanks for spotting this bug. It is a side effect of the new openssl lib used. I made a fix with just released update. Please reboot and give it a try,
webcam
Re: Twitter Error
Post by webcam »
I have the same problem. Have the system also restarted, unfortunately without success.
Greeting
Daniel
MeteoOudkarspel
Re: Twitter Error
When I'm on "Request PIN" button then the next problem comes then this message:
Error: Twiter feed from Meteobridge not yet authorized.
Meteobridge 4.1 (Aug 26 2019, build 13110), FW 1.4 installed, twitter problem is not solved.
Last edited by MeteoOudkarspel on Mon Aug 26, 2019 11:03 am, edited 2 times in total.
Sincerely,
theojurriens
Re: Twitter Error
Post by theojurriens »
Currently Meteobridge 4.1 (Aug 26 2019, build 13110), FW 1.4 installed, twitter problem is not solved .
webcam
Re: Twitter Error
Post by webcam »
Works again ..... Merci for the top service.
Greeting
Daniel
theojurriens
Re: Twitter Error
What did you do Daniel, in my case unsolved :-(
Re: Twitter Error
please reboot, there is a new version online.
theojurriens
Re: Twitter Error
I did a re-boot, but still the same error.
Re: Twitter Error
please try again.
MeteoOudkarspel
Re: Twitter Error
Thanks Boris now it works again with version Meteobridge 4.1 (Aug 27 2019, build 13116), FW 1.4
Sincerely,
webcam
Re: Twitter Error **solved**
Post by webcam »
@theojurriens
sorry I just read it now. But seems to work now.
Greeting
Daniel
