After update to 4.1 no FTP upload and historical data missing. **solved**
Re: After update to 4.1 no FTP upload and historical data missing.
Looks like it is related to some platforms. User "wsnoordbergum" is using the rather rare TL-WR703N. Can be a tmpfs size issue. I fixed that for MR3020 but did not take care of WR703N.
- wsnoordbergum
Maybe time to switch to the nano.....
For now I use version 3.9
Too bad the WR703N is not fixed (or can't be fixed) as platform.
Just extended my license.
wsnoordbergum
wsnoordbergum
Changed the code, please give just released update a try.
- wsnoordbergum
Seems like you already rebooted my device.
The FTP upload does not work.
Also my data gone ..... again.
Also reload template results in error.
See attached screenshot.
This is not good.
This is not good.
- Screenshot_20190831-120609.png (191.65 KiB) Viewed 5661 times
- Screenshot_20190831-120540.png (202.98 KiB) Viewed 5661 times
I rebooted before I did the change, but cannot login currently. Please reboot again.
- wsnoordbergum
Any chance you can find my historical data Boris?
I now only have 1 historical data loaded..
I reboot back to 4.0 now.
If all works well I will re-enter data manually again...
Also in 4.1 connectivity problems, that's the reason for not being able to log on
Wsnoordbergum
Wsnoordbergum
Last edited by wsnoordbergum on Sat Aug 31, 2019 12:46 pm, edited 1 time in total.
My MR3020 also stopped uploading data and I went back to 4.0. All historic data in MB is lost!
strange, each time I select "boot newest" and restart, I cannot login. Can you please revert to 4.0 so that I can login again? I have an idea, why this happens.
- wsnoordbergum
Ok
Rebooted, selected 4.0 but is 4.1 ?
When you send remote login details to "info@meteobridge.com" I can check the root cause.heersje wrote: Sat Aug 31, 2019 12:42 pm My MR3020 also stopped uploading data and I went back to 4.0. All historic data in MB is lost!
stephane01
- Fresh Boarder
test of last update, ftp does still not work Also my data gone again.
hi boris a user today piet has emailed me with same issue of historical data lost after reboot or upgrade to latest on tplink type.
his case no lightning data or historical lightning data from the weatherflow hardware.all his historical data is dated from today and previous was lost ...brian
With the latest update the ftp and loss of historical data persists, I have provided access to Boris to have a look but have temporarily rolled back to 4.0 to feed my website and others.
TP-Link MR3020
TP-Link MR3020
Hi!
I have a MR3020 and I have lost all my history data when the meteobridge update yesterday.
I'm seeing the same issue on 4.1 for MR3020. It's complaining about SSL so it cannot download my template. I reverted to 4.0 and it is working again.
4.1 was giving an error about ssl not being compiled in. My template is on a site secured with TLS 1.2
Edit: Also my history is gone as well.
