MB-Smart hosted on a Synology NAS in US
rzelle-K1TTC
Re: MB-Smart Beta hosted on a Synology NAS in US
Post by rzelle-K1TTC »
Updated at 13:45 after I saw your message re moonphase etc.
73s ..Ron
rzelle-K1TTC wrote: Fri Sep 06, 2019 2:12 am Updated at 13:45 after I saw your message re moonphase etc.
73s ..Ron
Ron thanks for installing and yourself using non metric has really helped pinpoint some issues I dont see .
I have fixed the charts for displaying feels like and wetbulb display . however its not perfect but returns a true value recorded when using non metric F option as the default .
three files were updated .
todaytemperaturechart.php
then two files to replace in the weather34charts folder
todaydewmedium.php
todaytempmedium.php
rzelle-K1TTC
Glad the site has been a help with development. :-)
I updated as of 0700 also caught the css file change adding the close button. Nice!
73s ..Ron
rzelle-K1TTC
My site is updated as of 1500 today everything looks good.
I have 2 requests however..:-)
Make the Dark UI cursor brighter it's hard to spot its location at times.
It would be Nice to have the system Date & Time in a little larger Font and the clock in a Box something like the Nano's Clock.
73s .. Ron
rzelle-K1TTC wrote: Mon Sep 09, 2019 9:28 pm My site is updated as of 1500 today everything looks good.
73s .. Ron
no problem
dark theme changed cursor to blue as per light theme cursor
increased font size for clock enclosed in box . used to be a seperate module but a bit of wasting actual space to perhaps use actual weather data so not going to add it to a module has some newer modules will appear sometime i.e leaf sensor,additional temp sensors etc.also fixed the after midnight still displaying 24 for 1st hour sorry i missed this I never get beyond 23:00 before collapsing in bed..😁
menu.php
shared.php
updater.php
and 2 css main files updated
rzelle-K1TTC
I updated the files listed this morning and I see the much more visible cursor now but I don't see changes to the clock font or that it is in a box unless you mean the box at top with station name info and clock... :-)
Thanks ..
.. Ron
cant change the font only the size clocks need to use monospace type and there are not many modern ones that match design. monospace is ugly in general . if you dont use a monotype then you get the irritating expanding and shrinking when seconds and minutes change .best i could do im afraid.
clock wont be in module(you call box) modules are being used for data values
rzelle-K1TTC
Thanks I understand fully re fonts and use of space .. :-)
.. Ron
rzelle-K1TTC
I updated at 1800 now my UV - Solar is not displaying correctly tried removing and replacing with moon and moon looked ok then re-enabled UV and still not displaying correctly.
Take a look ..
.. Ron
rzelle-K1TTC
I swapped UV-Solar with Camera and display looks OK now. I've attached a screen shot before swap.
UV Solar Issue in last.PNG (228.34 KiB) Viewed 5754 times
good morning i was able to reproduce it and see my error . it will go quiet now for a while i have limited internet so not a reliable way to update multiple files and the past tells me failed me uploads .there is one pending file update but that wont get pushed to GITHUB until Boris applies a change to the API .
index.php was just updated many thanks again. brian
rzelle-K1TTC
Updated as of 1330 I swapped UV/Solar and Camera back to where they were all looks good.
The camera window has been showing Offline I keep forgetting to mention it ..:-)
..Ron
rzelle-K1TTC wrote: Sat Sep 14, 2019 7:40 pm Updated as of 1330 I swapped UV/Solar and Camera back to where they were all looks good.
..Ron
ill take a look sometime in the week when i have a reliable internet , your cam wont load up on my limited 3g internet so not possible for me to work out
at the moment. if you updated today you will need to reboot nanosd to reflect new API string for month direction average otherwise it always will show north .
rzelle-K1TTC
As of 1600 NANO Rebooted and site updated .. :-)
.. Ron
thanks to paul wilman for spotting there was a missing timezone string in the sun3.php causing sunrise/set times to go awol so applied the fix . almost there lots of translations were done yesterday by graham so this part has 90% done and however some popup module will not be translated like moon , earthquakes....brian
