Nonzerotime after few days empty?
WS Grave
Post by WS Grave »
Goodmorning, since a few months I have a Meteobridge Pro Red with my new weatherstation (VP2).
I'm creating my own templates for my website and I would like to use the tags [rain0total-nonzerotime:--] and/or [rain0rate-nonzerotime:--] and they do work, a few days, but after those 1,2 or 3 days I see only the "--" instead of the date.
Is that how it should be or should I be able to see the last time it rained even after a few weeks or so!??
Thanks a lot for your reply 👍
Re: Nonzerotime after few days empty?
did you a get response because i cant quite make it work and get same as you .have updated to version 4 now 4.1 still same result two days later it returns - - ...
Problem is that "nonzerotime" is not made persistent over logger restarts. So when the logger process restarts because of a larger data gap or because you change something logger related on the web interface, then reference data is lost. I will think about this. A solution that survives a restart of the logger might be easy to do, one that survives a reboot is a harder challenge.
In just release update I made the "nonzerotime" selector surviving a restart of the logger process. After a process restart it will need the respective sensor to be initialized by getting some data from the station before it can report on "nonzerotime".
admin wrote: Sun Sep 08, 2019 1:16 pm In just release update I made the "nonzerotime" selector surviving a restart of the logger process. After a process restart it will need the respective sensor to be initialized by getting some data from the station before it can report on "nonzerotime".
hello boris
so let me understand lets say i update now the nonzerotime will be effective or generate a timestamp from the next rain event we get or
my last rain event here was 21st august will it detect that . sorry for the questions just been confused on this for months . brian
ok i updated 8th September 4.1-2424 and went out poured a bit of water into the cone to generate 0.2mm ,
it now generates timestamp i can edit out after a few days so lets see if it picks up the [rain0total-nonzerotime:--] as of todays timestamp 20190908155729 so lets see if it remains there in a 2 or 3 days as what use to happen it would revert back to -- .
screenshot shows with the orange dots ..brian
Screenshot at Sep 08 16-04-25.png (39.66 KiB) Viewed 6484 times
hello boris unfortunately that didnt work after 3 days exactly no timestamp is returned only —
so i dont how else to return a last rainfall date with a valid timestamp
brian
Could you please post the result of
http://ip-of-my-meteobridge/cgi-bin/system.cgi?ls -la /var/run/meteohub/
admin wrote: Wed Sep 11, 2019 4:07 pm Could you please post the result of
command: ls -la /var/run/meteohub/
drwxr-xr-x 2 root root 460 Sep 8 15:57 .
drwxr-xr-x 5 root root 640 Sep 11 17:22 ..
-rw-r--r-- 1 root root 10 Sep 11 17:22 logger.dat
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data10num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data11num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data12num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data13num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data15num
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-data16num
-rw-r--r-- 1 root root 10 Sep 8 15:57 nonzerotime-rain0total
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0dew
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0heatindex
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0hum
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-th0temp
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0dew
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0hum
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0press
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0seapress
-rw-r--r-- 1 root root 10 Sep 11 17:21 nonzerotime-thb0temp
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0avgwind
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0chill
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0dir
-rw-r--r-- 1 root root 10 Sep 11 17:22 nonzerotime-wind0wind
this the string used [rain0total-nonzerotime:--] in the API
Fine, so the data is there. Could you please give this command, so that we see epoch time of last rain event:
...system.cgi?cat /var/run/meteohub/nonzerotime-rain0total
it doesnt now return a timestamp at exactly 15:57 today it now returns only - -
prior to that it would return 20190908155729
the string used to call is [rain0total-nonzerotime:--]
admin wrote: Wed Sep 11, 2019 4:28 pm Fine, so the data is there. Could you please give this command, so that we see epoch time of last rain event:
command: /cat/var/run/meteohub/nonzerotime-rain0total
/www/cgi-bin/system.cgi: line 22: /cat/var/run/meteohub/nonzerotime-rain0total: not found
It needs to be "cat /var/..." not "/cat/var/..."
command: /cat /var/run/meteohub/nonzerotime-rain0total
/www/cgi-bin/system.cgi: line 22: /cat: not found
you are nearly there... please "cat" instead of "/cat" :D
