Nonzerotime after few days empty?
Re: Nonzerotime after few days empty?
command: cat /var/run/meteohub/nonzerotime-rain0total
1567947449
Convert epoch to human-readable date and vice versa
1567947449
Timestamp to Human date 1567947449
Supports Unix timestamps in seconds, milliseconds, microseconds and nanoseconds.
Assuming that this timestamp is in seconds:
GMT: Sunday, 8 September 2019 12:57:29
Your time zone: Sunday, 8 September 2019 15:57:29 GMT+03:00
Relative: 3 days ago
ok, so data is there. I will look into the code again.
cool :-)
WS Grave
Post by WS Grave »
For me there is no data, but I don't want to interrupt you.
I'm following your discussion with interest.
ConligWX
Post by ConligWX »
sorry to reopen this thread but I have no nonzerotime-rain0total file present. is this file removed after a number of days?
24th of may was the last time it rained (now 29th May) but when I use the template in my website it was showing last rained 01/Jan/1970
when I read this thread I seen others having similar problems.
root@MeteoBridge:~# cat /var/run/meteohub/nonzerotime-rain0total
cat: can't open '/var/run/meteohub/nonzerotime-rain0total': No such file or directory
is this a bug or something broken in my MB?
how is this file created? what process?
I dived a bit into this rather old code section. nonzerotime is held in RAM disk, so in general after a reboot it is gone. It is also stored on the Meteobridge server like min/max values but looks not to be used for restore on reboot. I changed that in the code.
For raintotal it registers increments so after applying the update you need a new rain event to have it working.
Please test and give me feedback.
ConligWX
Post by ConligWX »
Hi there thanks for looking at this. We have rain for the first time this morning which then created a new var/run/meteohub/nonzerotime-rain0total entry.
After a reboot, the values are still here. Will check in a moment that the file still exists...
ConligWX
Post by ConligWX »
ok got home checked the
/var/run/meteohub/nonzerotime-rain0total file but it is not there. there is however a update-rain0total file which I guess is the new "last rained file" ?
data on website is still showing correct last rained value.
Good morning Simon
currently testing the newer firmware for the last rain measured time/date as in the past it would often not produce a valid timestamp output as the original OP had posted months ago . previous fixes or ideas did not produce any valid timestamp after 72 hours it would simply produce a -- using the meteobridge string [rain0total-nonzerotime:--]
currently can monitor it for the next few days in the template as the string as been present for over a year and as no rain is expected here can see if it produces a valid string after 72 hours.
I applied a fix so that "rain0total-nonzerotime" should work fine now.
hi boris i forgot yes in last firmware upgrade earlier this week the value or timestamp wasnt present after 72hrs using the [rain0total-nonzerotime:--] output string , i also noticed when it was actually raining the month, year values were not incrementing realtime until the hour past .
i.e if the rain was 0.2mm at 10:20am the month,hour value did not update till 11:00am i have seen this in a past firmware release but seem to be fixed in a later release.
only way to test this is wait for a rain event and then hope there is no rain for the following 72hours .
hope it makes sense :D
