MB-Smart hosted on a Synology NAS in US
rzelle-K1TTC
Re: MB-Smart Beta hosted on a Synology NAS in US
Post by rzelle-K1TTC »
OK on possible future export I don't have a lot of data since I installed the nano in July but would be nice to have what's there.
I updated the site this morning at 0900 and just looking over additions/changes. The Weather Cam stopped displaying and Station Info Graphic looks like it needs tweaking ..:-)
.. Ron
rzelle-K1TTC wrote: Thu Sep 19, 2019 3:32 pm OK on possible future export I don't have a lot of data since I installed the nano in July but would be nice to have what's there.
.. Ron
if you goto settings change davis hardware type to davis vp2+ was called davis vp2 pro or something which was too long
change small module option to battery for now until i ask boris to add a few extra heat index/windchill values to the api . no changes were made to anything related to webcam see for example https://www.paulwilman.com/pw4/
double check you updated updater.php and added new files listed in github
each file updated marked with
*Significant Update new files,new modules , new translations rev 1.02
*caution new heat index module data not ready requires new data to be added to API . 23 files were updated . now shows 21 modules ! see https://singaporeweather.info for demo
change the two settings below now uses shorter phrases and change module option ..
rzelle-K1TTC
Made the changes in setting also verified 21 files updated. Camera issue was a camera issue .. :-)
..Ron
rzelle-K1TTC
I believe it’s already tomorrow for you so Good Very Early Morning ..
Just checking things out before retiring for the evening noticed my Today charts for Temp and Wind are empty no charted data there are values in the colored boxes but no charts. Should Barometer have a Today as well?
73s ..Ron
rzelle-K1TTC wrote: Fri Sep 20, 2019 2:51 am I believe it’s already tomorrow for you so Good Very Early Morning ..
73s ..Ron
good morning (6am)
no changes to charts or anything related so i would say check the at server level and make sure the two services charts today and year month are running in nanosd .
all languages files updated *changed options in setup screen + others 13 files
*important goto setup screen change
*mb-smart-setup.php updated
*Which Meteobridge Platform Do Yo Use ? NANOSD or NANO or Pro (now uses shorter phrase does not include meteobridge phrase )
*Position Last small module 3 options luftdaten air quality or heat index almanac change to moonphase or air quality. heat index option is for future change to API
*index.php updated change to recognise new language strings
*hardware.php updated minor change
*updater.php changed updated position options
*note for air quality users (purple air or luftdaten) new chart options will appear next week sometime , here testing at http://singaporeweather.info click air quality popup
rzelle-K1TTC
Good Afternoon..
Updates applied as of 0730 plus made settings changes ..
Today Charts are working this morning I will keep an eye on services from nano and the Today charts through the day .. :-)
..Ron
rzelle-K1TTC
Checked the new Battery module looks great but the console power should 5v DC ..:-)
..Ron
ha corrected AC input DC output
scenarios to indicate low power battery etc notification if it ever happens
thats now 12 extra different modules and combinations shown below.
weatherist34 wrote: Thu Sep 05, 2019 7:28 pm
rzelle-K1TTC wrote: Thu Sep 05, 2019 6:41 pm The site is updated as of 11:51 ..
:) .. Ron
ok there was still a minor issue in the weather34-moonphase.php and moonphase.php mooninfo.php but i managed to find the rogue inverted comma so just update those three and that should be ok for moon data now. most upcoming changes will just be css files has i go into the tedious task of removing unused stuff so keep an eye open . nothing in terms of significant changes will happen now as the hard part is almost done and there is nice bunch of testers constantly helping.. thanks for your feedback.
now new thread viewtopic.php?f=56&t=14398 for public release...many thanks for the ideas, feedback, etc in the last few weeks Ron
rzelle-K1TTC
Good Afternoon, My site is updated as of 0740 everything is looking Really Nice!
A Strange Problem with Today Charts..
I kept track of Today charts during the day yesterday only until around 1200 and they charted with data. I then checked Today charts again at 2130 and no graphing which is what I saw the other evening.
The csv file 20Sep2019.csv had data entries every 10min so the NANO-SD was sending data as it should. I tried viewing the Today's Charts via Ipad and windows browsers with the same results. Checked Today Charts at 0030 this morning and they were graphing again.I've attached 2 screen shots of what I saw last nigh at 2130.
Blank Charts-092019-2130.PNG (173.92 KiB) Viewed 5289 times
Blank Charts-Data-csv-092019-2130.PNG (95.7 KiB) Viewed 5289 times
..Ron
rzelle-K1TTC wrote: Sat Sep 21, 2019 2:04 pm Good Afternoon, My site is updated as of 0740 everything is looking Really Nice!
..Ron
hi ron you need to look at server errors when this occurs or browser source mode might throw some indication,
if the csv is populated thats all the charts do is read that csv for todays date .
you screenshot this indicates either file cant be reached (was it writing to file at that point?) or momentarily (period) server changes date ahead ? next time look for any server errors or use developer mode in the browser .
rzelle-K1TTC
Thanks Brian, I will try to see if I can capture errors as you suggest at this end.
The Site is Looking Great I removed Beta from my site's Title .. :-)
..Ron
rzelle-K1TTC
Good Afternoon ... I checked the Today Charts throughout the day yesterday until just after 2015 when they stopped Charting, Browser Network Dev Mode revealed that Charting was looking for the next days csv chart file see attached. I checked Server Time and Workstation Times and all are in sync to my local time and zone. It looks like the the Today's Chart is looking ahead 4hrs. My Time Zone settings are set to America/New_York -4hrs. Ive attached a Today Chart get from this morning as well.
Get Error Todays Chart 1 day ahead.PNG (10.05 KiB) Viewed 5276 times
Get Next Day No Error Todays Chart.PNG (17.86 KiB) Viewed 5276 times
Hope we can figure this one out .. :-)
.. Ron
server related im afraid as times are derived based on server php timezone setting ,the bit i dont get new york minus 4 hours as that is the time it starts looking for tomorrows date i.e 20:15 obviously something is expecting 00:15 or later from there on.
i cant help at server level im afraid , ive zero experience of using synology perhaps search around forums related to synology.
sorry i dont have an answer.
