Server Change on December 8, 2019
We had to change servers and data center and many ports of the underlying SW stack. Please report problems regarding Meteoplug server operation here.
We tried our best in preparing that, but I guess some bugs will still be in there.
grwkak
Re: Server Change on December 8, 2019
Post by grwkak »
Getting a Meteoplug refuses to connect error (grwkak.meteoplug.com) on web pages where I use the charts. See - all data tab on http://wilsonsweather.host-ed.me/wp/ as an example.
I seem to be able to log into the system (user admin) and can view charts that way.
Guy
Stormedy
Post by Stormedy »
....I am missing with my weatherstation site "Aathal" http://www.kaikowetter.ch/mc/meteoplug_seegrabenX.html the graphic meteoplug and the gauges showing actual temp/wind/rain etc. When checking with meteobridge "meteocloud graphing" it is not working! Can you check where the trouble is?
thanks
Ed
paul_1055
Post by paul_1055 »
Alle Grafiken die per I-Frame eingebunden sind werden vom Server abgelehnt und nicht dargestellt
Gruß Torsten
gcams
Post by gcams »
I'm having issues on my site too with meteplug iframes not loading.
it looks to me like www.meteoplug.com gets redirected to http://wiki.meteoplug.com which then serves a page which constantly tries to refresh, ending in a refresh loop in the browser. The same happens if I try and visit the control panel at https://login.meteoplug.com.
I noticed the iframes do work if you call them direct (not embedded in website) via the hostname "meteoplug.com" (without the www) but in these pages, the SAMEORIGIN iframe header is set which I think may be stopping the browser from loading it:
Returned headers:
< HTTP/2 200
< server: nginx
< date: Mon, 09 Dec 2019 14:26:05 GMT
< content-type: text/html; charset=UTF-8
< content-length: 107
< last-modified: Sun, 19 Jun 2016 09:16:59 GMT
< vary: Accept-Encoding
< etag: "5766630b-6b"
< x-frame-options: SAMEORIGIN
< strict-transport-security: max-age=31536000; preload
< accept-ranges: bytes
Error from Chrome console:
Refused to display 'https://meteoplug.com/cgi-bin/meteochart.cgi?draw=[removed for privacy]&engine=javascript' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
hallansen
Post by hallansen »
With the server conversion you have disabled the iframe support for html embedding of the graphics. Please let them know if it will stay that way permanently. Doing this without any notice is very questionable, since under certain circumstances the entire homepage of the weather station is programmed to iframe. Then you would actually have to charge back royalties.
frabey
Post by frabey »
Hi Boris, sämtliche auf meiner Website eingebundenen Grafiken und Templates (iframe) werden nicht angezeigt. Es ist nicht schön das die Nutzer nicht über einen Serverwechsel informiert wurden. Hoffe das dies zügig behoben wird. So nützt Meteoplug nichts.
Gruß
Frank
www.elsterwetter.de
Die meisten Bugs sollten jetzt raus sein. Wenn noch was klemmt, bitte nachfolgend berichten.
Most bugs should be resolved by now. If there are still problems please report below this posting.
hallansen
Post by hallansen »
Der iframe Bug war aber ein ganz Böser......... :oops:
grwkak
Post by grwkak »
One iframe does not appear to work.
It links to http://grwkak.meteoplug.com and displays the Meteoplug Wiki.
Its supposed to be a compilation of temp, humidity, rainfall, pressure and wind (line charts).
Actually it links to https://www.meteoplug.com/cgi-bin/meteo ... 0c071c180e
Which displays fine - may be an issue with my site, not the chart.
Guy
kaiko
Post by kaiko »
Hallo Boris
Weiterer Bug?
Die Overlay png's für die Mobotix können nicht mehr erstellt werden.
Ich erhalte folgende Fehlermeldung:
https://www.meteoplug.com/cgi-bin/meteo ... c2c9c1.png
liefert
Error: Illegal parameter for "draw" tag: 96929e999f8cd9c9d9dacac7c9dbc7dcd0dedd89c0c8cbc5c3dddcc2c9c1.png
https://www.meteoplug.com/cgi-bin/meteo ... dddcc2c9c1
liefert das Bild zurück.
Grüsse Kai
Topic:
Alternative URL
"Meteoplug can generate pure graphic files (like png) when used in gnuplot or picture mode.
Some data polling devices need the URL to address a ".png" or ".jpg" file.
Therefore, URLs like "http://www.meteoplug.com/cgi-bin/meteoc ... 2a343a3337" won't do, because this does not match the expected URL naming schema.
For situations like this you can change the URL to "http://www.meteoplug.com/draw/696368686 ... 1month.png" where the draw toke is used as a path identifier and a filename of your choice in that path.
This technique was designed to generate overlay png file to be used by Mobotix webcams but might be usefull in other situations as well.
Additional URL parameters cannot be handled by this type of URL resolution. "
Please try again with a working draw token. It should do now.
grwkak wrote: Tue Dec 10, 2019 1:19 am One iframe does not appear to work.
Guy
I think your browser cache does fool you. Both links are working ok.
Rutishauser
Post by Rutishauser »
Die Grafiken werden mittlerweile wieder angezeigt, aber nur teilweise. Wie die meine Wind und Globalstrahlungswerte
Bildschirmfoto 2019-12-10 um 18.00.11.png (311.48 KiB) Viewed 16026 times
bubulino
Post by bubulino »
Hallo in die Runde
Seit 01:00 ist der upload irgendwie gestoppt.
Auch Kunden berichten vom selben Problem.
Zudem können sich "echte" meteoplug-clients nicht mehr anmelden.
Grafik generieren geht:
http://www.meteoplug.com/draw/595e5d5f5 ... 021d3a.png
Aber die Mobotix akzeptiert kein https://
LG, Markus Brotschi
