PSJohn
Post by PSJohn »
weatherist34 wrote: Wed Jan 15, 2020 6:56 pm ha ok very sorry I run out of time to push a new update earlier and the program I use for zipping files(Keka) I don't have on my iPad ..anyway update pushed just now 16-01-2020update.zip
http://www.mediafire.com/file/dkrpofq0a ... e.zip/file
it basically is the whole console alternative layout without the console-settings.php file . have fun..
I have a question concerning updates... where do I find what current version of V2.0 I'm using and is there a version history posted somewhere. Is this thread the "official" location to check for updates(the xx-xx-2020update.zip file needed for the updater)?
thanks
https://desertweather.com
Palm Springs, California
https://lakehemetweather.com
Lake Hemet, California
rzelle-K1TTC
Post by rzelle-K1TTC »
Attached is a shot of my iPad Console in a stand I purchased for it. I am also a stickler for not having exposed cables and having a Clean Look so that WhiteThing sticking out of the IPad is being replaced with Black right-angle version to help somewhat in improving the appearance. As far Skeuomorphism your efforts are working my partner is using the Console she's commenting positively on the appearance and has stopped asking me about the current conditions .. :-)
When you have a minute I would like to know where you purchased the inexpensive Android Tablets. OK if you want to respond to my email address.
Lot's of 73s
.. Ron
oturn
Post by oturn »
Is this available as a second dashboard on the Nano SD yet, or are we still waiting?
oturn wrote: Mon Jan 20, 2020 5:32 am Is this available as a second dashboard on the Nano SD yet, or are we still waiting?
Hello unfortunately its not something I can answer this is done at firmware release level so best contact Boris .
*Update for Pressure css graphic module
Extends range of barometer 935-1055(hpa/mb) & 27.5-31.5(in) caters for extreme high pressure as seen in UK currently(20th Jan 2020).
https://weather34.com/homeweatherstatio ... smart.html
* the main full download is always automatically or simultaneously updated when smart update is released.
or use a GITHUB app to pull updates, GITHUB offers a full history log and code changes with highlights of actual code changes.
https://github.com/weather34/Meteobridge-MB-SMART
best place to monitor for updates is via https://weather34.com/homeweatherstatio ... smart.html or GITHUB
this thread is primarily for discussing issues or if you get into the habit of using GITHUB you can raise issues directly there and push code ideas via the ISSUES tab via https://github.com/weather34/Meteobridg ... ART/issues
Screenshot at Jan 20 11-01-06.png (287.52 KiB) Viewed 6530 times
garybridge
Post by garybridge »
Thank you for the clarification that main download was updated automatically to the latest version.
This is a useful Get Out of Jail card for me as for some reason some parts of the template didn’t update correctly.
Gary Bridge MIET, MIPS.
geoair
Post by geoair »
weatherist34 wrote: Mon Jan 13, 2020 4:04 pm
geoair wrote: Mon Jan 13, 2020 2:51 pm Hi all,
Is there a way to reset the settings password on a Meteobridge NanoSD(4.2-2795)?
Thank you
do you mean on the meteobridge NANOSD itself ?
I'm referring to the weather34 settings console:
I need to adjust the time zone on my setup, and for some reason I cannot access the settings page with the password I think I've defined.
Best regards.
hello by default there is no password just hit enter however if you forgot password you set then perhaps contact Boris for clarification on procedure
to reset password as in above post the in built version I have no access to publicly and any changes I guess are a firmware release level.
on another subject ive posted below a clear example the benefit of using a GITHUB app to follow updates they are available in many flavors for all OS Mac,windows etc just have to find and use one that suits your needs . You can see it automatically lists all changes in history and code
I use the standard default GITHUB Mac OS version .
I have been asked a few times in recent months does template support or work with Brotli ?
Brotli support ?
Answer. Yes weather34.com uses Brotli and has done for a few months , it offers advantages over the popular existing common GZIP approach. It is not a case of whether the template supports its a feature enabled at server level by your host .ICDSOFT hosting offers this and is enabled by default on their servers. The difference is negligible and would hardly be noticed by any visitors but for those who like to have their sites using the latest feature or being one step ahead then a google search on enabling Brotli via your servers root htaccess will return many results but be safe and contact your hosting technical support.
for those interested
https://www.interserver.net/tips/kb/bro ... tter-gzip/
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Tue Jan 21, 2020 10:30 am I have been asked a few times in recent months does template support or work with Brotli ?
Brotli support ?
hello Brian, would it be possible (in the alternative console) to change the positioning of mm of rain per day ??? they are the only data that can be read little because of its small character ... perhaps removing it "from the water" or decreasing the size of the tray to allow you to enlarge the characters of the daily mm .... thanks :) :) :)
think Im understanding so I changed it to this simply moving the unit above and increased font size a wee bit and increase today rainfall value font size . If not I don't think its a critical thing to spend to much time on but I do appreciate the feedback and try to cater for most ideas thrown around.
I have a growing number of emails this morning/afternoon and it seems these are all related to Meteobridge Pro after firmware 4.3 , I have cross checked everything and 100% nothing changed in how the template handles the data sent from Meteobridge . in fact the file that does that is the same has it was in 2018 that file mb.php .
The template only displays what is sent from the Meteobridge API !! it doesn't do anything and can't control meteobridge hardware in anyway.
All these issues have arisen only on Meteobridge Pro using firmware 4.3 . cross checked all known NANOSD users using firmware 4.3 and there are no issues or similar to what I m getting in emails .
issues raised with Meteobridge Pro
1.no console Davis forecast data sent from Meteobridge
2.Incomplete data sets example below you can see its stopped at almost CARAMBOLA2 and missing two thirds of the data set
CARAMBOLA2 is the MB pro identifier
22/01/2020 11:55:45 5.3 97.0 4.9 0.0 0.0 47.0 0.0 0.0 1034.9 47.0 0 m/s C hPa mm 0.0 1035.0 79.8 79.8 0.0 17.0 53.0 5.3 4.4 5.3 20200122114818 -2.2 20200122013338 0.3 20200122101702 1.4 20200122085509 1039.0 20200122110143 1026.8 20200122080939 4.3 13331 0.5 CARAMBOLA2 -- -- 0.0 [
here is another MB pro output with 4.3 firmware with NO console forecast data but with all the dataset
22/01/2020 14:08:30 6.9 69.0 1.6 1.7 1.4 213.0 0.0 0.0 1030.5 213.0 1 m/s C hPa mm 1.7 1031.6 16.3 16.3 0.0 36.2 21.0 6.2 6.8 7.3 20200122133919 -2.6 20200122080642 2.8 20200122134159 3.3 20200122134017 1036.6 20200122000501 1030.5 20200122140321 4.3 13331 2.8 CARAMBOLA2 -- 0.4 0.0 178.0 209.0 0.0 6.7 20200102140912 -4.7 20200107070236 0.5 20200121153734 6.7 20200102140912 -4.7 20200107070236 0.7 95.0 20200122090427 64.0 20200122131118 2.4 20200122133919 -3.7 20200122080642 7.2 68.0 1.7 36.2 21 1.6 1.8 -- -- -- -- -- -- 441.0 258732 9.2 20200121133435 -2.9 20200121075102 13.3 20200111142849 -3.9 20200107070236 13.3 20200111142849 -3.9 20200107070236 2.8 20200121122618 7.6 20200120181126 7.6 20200120181126 0.0 16.3 20200101000004 16.3 20200103094942 441.0 20200122124142 410.0 20200121120958 441.0 20200122124142 441.0 20200122124142 20200122113658 0.8 20200121115355 0.8 20200112115845 0.8 20200112115845 -4.2 20200121073600 8 6.9 -- 19.8 20191125134038 -3.9 20200107070236 15.7 20191105132115 -6.2 20191211124551 19.5 20191112231426 1043.2 20200121000127 1036.5 20200121235302 1043.3 20200120232526 1019.0 20200104205837 1043.3 20200120232526 1019.0 20200104205837 1043.3 20200120232526 982.6 20191213164455 1214.1 1.0 7 5.7 09:20 05:49 14:43 0.3 97.0 20200103104714 43.0 20200120135801 97.0 20200103104714 43.0 20200120135801 94.0 20200121090856 49.0 20200121133851 0.0 0.0 107.3 1197.8 -- 6.7 1030.7 0.4 1.7 232.8 1.1 0.0 67.4 2.4 0.6 20191028204918 20191028203245 20191028184103 20191001000000 20200101000004 316.0 13.3 20200111142849 -7.0 20200108061317 _
Now with a NANOSD with firmware 4.3 below you can see its three times as much data and forecast is present and is labeled VOCORE2
22/01/2020 12:43:16 7.6 97.0 7.2 0.4 0.0 358.0 0.0 0.2 1037.6 358.0 0 m/s C hPa mm 0.2 1038.0 63.0 63.0 0.2 17.6 38.0 7.6 6.3 7.6 20200122123738 1.1 20200122000027 0.4 20200122044410 1.3 20200122120636 1040.3 20200122000412 1037.6 20200122062512 4.3 2808 0.9 VOCORE2 -- -- 0.4 104.0 358.0 0.0 12.1 20200114132412 -3.1 20200119075704 4.8 20200121140034 12.1 20200114132412 -3.1 20200119075704 -- 97.0 20200122115042 94.0 20200122000027 7.2 20200122124038 0.2 20200122000027 7.4 96.0 6.8 17.6 38 0.2 0.2 -- -- -- -- -- -- 135.0 304132 7.5 20200121151502 -2.1 20200121074818 14.1 20200114144340 -2.3 20200119075644 14.1 20200114144340 -2.3 20200119075644 1.8 20200121132446 15.6 20200113173456 15.6 20200113173456 0.2 63.0 20200101000011 63.0 20200113180548 135.0 20200122120902 260.0 20200121123610 360.0 20200112123543 360.0 20200112123543 -- -- -- -- -- -- -- -2.8 20200121074818 0 7.1 20200122045902 33.7 20180727160000 -6.1 20190203073130 21.6 20190629125639 -7.2 20190203073130 20.1 20190207022510 1044.8 20200121000011 1040.2 20200121203912 1049.7 20200120020809 988.9 20200114130912 1049.7 20200120020809 988.9 20200114130912 1049.7 20200120020809 968.9 20191221195916 1534.4 3.2 7 5.9 08:40 06:15 14:15 0.0 97.0 20200122115042 70.0 20200103152043 97.0 20200122115042 70.0 20200103152043 96.0 20200121094822 81.0 20200121152226 0.0 0.0 118.4 791.8 -- 7.5 1037.7 -- 0.4 102.3 7.1 0.0 96.6 7.1 1.8 20180206040000 20180214040000 20180805020000 20180602010000 20200101000011 247.0 14.1 20200114144340 -3.6 20200119061556 _Partly cloudy with little temperature change.
I have emailed Boris to try and resolve or get some insight but these issues are NOT apparent on NANOSD hardware with 4.3
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Wed Jan 22, 2020 10:34 am think Im understanding so I changed it to this simply moving the unit above and increased font size a wee bit and increase today rainfall value font size . If not I don't think its a critical thing to spend to much time on but I do appreciate the feedback and try to cater for most ideas thrown around.
thanks brian, so it is already much better .. :D :D :D
one last thing, you could try to set the font in black/dark grey, instead of white..I think it would look even better and would be more in contrast with the blue water .. obviously mine are just tips and feedback ,thanks for your hard work :) :) :)
alexeysailman
Post by alexeysailman »
Hi Brian.
Need your advice please.
I've already rechecked many times according to your instructions https://weather34.com/homeweatherstatio ... setup.html my settings. But statistics for the day are not saved. For example, it has been three days since the start of work, but the average daily values remained for the first day, and then there is a void.
hello
that is one mind-blowing url :-)
however I have just run the url for charts-month-year.php through the browser you will see it created data for 23rd Jan in month and year .
so check there are no hidden whitespaces at the end of the url in the charts-month-year at 23:45 . also click the test button to confirm it is running.
doing exactly the same from a browser creates updated data. thats all I can think of
alexeysailman
As i understand, after runing the url for charts-month-year.php through the browser it turns out such as in the picture, this story can be removed somehow?
