rzelle-K1TTC wrote: Thu Feb 06, 2020 3:17 pm Thanks Chuck, I missed it up there .. :-)
..Ron
No problem. I missed it myself, at first. :D
The house symbol is missing on my iPhone and the month on the clock?
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Sun Feb 02, 2020 9:11 pm ok ron another oversight try and do tomorrow...
about default switching your not alone thats been asked a few times this week however i will try and do it sometime in the mean time you could just add a redirect in the index.php of the main template if you not too bothered about seo stuff the quick way
<?php
header('Location: https://www.yourdomain.com/console/consoledavis.php ');
exit;
or
<?php
header('Location:console/consoledavis.php');
exit;
or common meta refresh method
<meta http-equiv="refresh" content="0; URL='https://yourdomain.com/console/consoledavis.php'" />
there are other ways via .htaccess but above should be sufficient..
hello brian, with the latest version of the update.mbsmart file I can no longer make the backup, but only the update .. how can I solve it ??
Annotazione 2020-02-06 182522.jpg (38.97 KiB) Viewed 5307 times
ToTo wrote: Thu Feb 06, 2020 7:09 pm The house symbol is missing on my iPhone and the month on the clock?
Toto this was removed too much hassle in adapting to languages each time so I dumped it..sorry but multiple support of languages thwart progress too often .
see screenshot it has simple clock now
Screenshot at Feb 06 21-47-00.png (328.78 KiB) Viewed 5300 times
xxvincixx wrote: Thu Feb 06, 2020 7:43 pm
<?php
exit;
or
<?php
exit;
I am making another backup solution as the original one was not widespread server friendly but it takes a bit of time to run it through on different servers I have access too but I will do it when time permits.
rzelle-K1TTC
Post by rzelle-K1TTC »
The Framing appearance of the console now makes the data modules pop very nicely ..
73s
..Ron
good Ron thank you striving for best clean look without going into information overload :-) ..and thats it from me for 10 days all barring my wife drums up the courage to get on the plane due to the fatal accident here this week it has blown her confidence...
last implementation was increase visibility on bottom bar..
The new frame really makes it stand out!
Have a great trip.
rzelle-K1TTC
Enjoy your away and Safe Journey.
..Ron
we hope so ...thank you both for your consistent help , got mine working on a Samsung 27” smart tv today looks pretty cool so when we get back probably spend a few days trying out on some other brands and sizes .
Lespius
Post by Lespius »
Beaufort scale
Hi there !
I have noticed that on both standard screen and console the Beaufort numbers appear to be linked to the wind speed (ie more or less instantaneous) rather than linked to the average speed. As per its definiton the Beaufort scale scale is linked an average wind, usually a 10 min average.
Alain
weatherist34 wrote: Fri Feb 07, 2020 6:32 pm we hope so ...thank you both for your consistent help , got mine working on a Samsung 27” smart tv today looks pretty cool so when we get back probably spend a few days trying out on some other brands and sizes .
Just a note for a future update. The path to the console-setup.php in the latest consoledavis.php update needs to be corrected.
Best wishes, :D
prestwickwx wrote: Sun Feb 09, 2020 8:50 pm
Best wishes, :D
sorry its short but addressed this earlier with a few other language alignments..
ps tplink owners rejoice standalone console version will be adapted to be compatible...
Hope all is well. Wanted to let you know that some of your updates on Github have pushed duplicate files into the root directory (main template), as well as, the console folder. I have a screen shot of what I see, so far.
Also, there was a index.php that was placed in the console folder. I think it has the same content as the consoledavis.php.
It also looks like it pushed the shared.php that you updated and sent it to the main template, as well as, the console. It must have over written the shared.php in the main template.
Just thought I would let you know.
many thanks my mess up ! should be fine now ?
changes once again reflect languages alignment
example below
