hello fix for humidity just pushed update humidity mod.php I set the threshold too <100 I should have set too <=100 so it reads 100% or any value below below..apologies
but the dewpoint reference which is directly from the meteobridge API so can you explain a bit more as the template doesn't use any formula for dewpoint it just reads what is sent to it for dewpoint . if you have a 100% humidity and the temperature is 9.7c the dewpoint would be 9.7c .
for those interested the update pushed this morning contained a relative indicator bar for wind speed works much like the rain rate bar but changes color at certain speeds.
atlantic21
- Junior Boarder
Brian after reading your explanation on dewpoint and humidity that explains why the current temperature and dewpoint were the same, theirs still lots for me to learn
Thanks for the great support
- rzelle-K1TTC
I like the Wind & Average Bar additions. Very Nice!
Thank You.
73s
.. Ron
Thank You.
73s
.. Ron
@atlantic21 no problem its good to share .... Ron glad you like it just another subtle small piece of css nothing complex just hope I got color sequence right
... however I wasn't sure where to put it I could have spent some time and moved it into the larger area and moved wind units out but it was easier like this as it uses same position as the rain rate .. stay healthy ...Brian
thanks for the idea of using a relative scale indicator so graham I did like this so it kind of works across evenly for m/s,km/h,mph,kts simply applied a number scale.
and tweaked the sun module.
3 files
windmod.php
gustmod.php
weather34-sun.php
3 files
windmod.php
gustmod.php
weather34-sun.php
hey Brian, would it be possible to create an alternative rain module (just like you did for the barometer)?So anyway to leave users the choice of which to use. It would be interesting if I created a form more "coherent" with the rest of the modules (rectangular with the number of millimeters inside) .. as it happens for the other modules, perhaps with the blue characters so as to recall the color of the water ...weatherist34 wrote: Wed Mar 11, 2020 10:54 pm thanks for the idea of using a relative scale indicator so graham I did like this so it kind of works across evenly for m/s,km/h,mph,kts simply applied a number scale.
3 files
windmod.php
gustmod.php
weather34-sun.php
I leave you a screenshot to make you understand what I mean ... Thanks for your wonderful work
- 1098_resize_66.jpg (178.36 KiB) Viewed 5830 times
Could you please adapt the wind forecast in the weather34-dayforecast.php as translation?
sure no problemToTo wrote: Thu Mar 12, 2020 1:23 pm Could you please adapt the wind forecast in the weather34-dayforecast.php as translation?
i thank you so, for this i have adapted the german language file once again (see attachment).
- lang.dl.zip
- (5.67 KiB) Downloaded 218 times
good afternoon
please treat this last update pushed this morning as the last for the near or distant future , Im sure you are all aware of what is happening in the world today and how it is hard to not focus on it or escape from it .
From the bottom of my heart I sincerely hope to see and hear from you all in the near or far distant future when there is some normality to our daily life and we can do all the things we became accustom too . When those times return Im sure we can all exchange our ideas and improvements enjoy our hobby and push for better ways of doing things.
For us my wife's company is shutdown for two weeks and likelihood of being longer depending on the situation with that we basically are going to look after ourselves and relatives, avoid overcrowding which istanbul is a congested city and the risk factor is high and abide by the advice given to us and try to continue the best we can.
My sincere deep heartfelt prayers are with anyone deeply affected by this situation..time to throw away the political bitching and do the right thing and listen to those that offer advice without any motive other than humanity..
yours Brian aka weather34..
ps..Kindly ask you not to email me for anything weather related in time as above when some daily normality returns we can pick it up again and share ideas.....
- prestwickwx
Well said, Brian.weatherist34 wrote: Sat Mar 14, 2020 1:27 pm good afternoon
Best wishes to you and your family.
Take care,
- rzelle-K1TTC
Stay Safe and Well see you at the other end. We are trying our best at this end as well.
73s
..Ron
73s
..Ron
Take care of yourself and your family.
All the best
Torsten
All the best
Torsten
xray77
Hello weatherist34,
I still have a question about the display of the wind speed on the display. Is it possible to display it without decimals? I prefer the wind-display in the unit knots, here a resolution without decimals is standard.
e.g. 9,7 kts displayed as 10 kts..?
Thanks again
Mike
I have now moved my question to this thread. The example looks good, just as I would like to have it with me!
My URL:
https://www.buedelsdorfwetter.de/MBSMAR ... /index.php
I also have the desktop display running, here the wind values are partly even with 2 digits..
Thanks again
Mike
My URL:
this file contains all the wind knots features though some areas need some attention but that is where it as for now
https://www.mediafire.com/file/yjdz2run ... onsole.zip
there is no plans to work on the main nanosd version display anymore im afraid i guess if you had been around during 2019 we could have adapted but unfortunately i have not done or made any changes to that version since December 2019 and no plans todo so just leaving it as it is..
tip...in the nanosd version main display look for the file called shared.php then at the near top you will see references to mphtokts,kmhtokts etc change number format from 1 to 0 ..sorry no screenshots perhaps later in the week if you are unsure.
unfortunately also i can not update the github repo at present with these additional wind knots features i will try later in the week but for now https://www.mediafire.com/file/yjdz2run ... onsole.zip contains what you see in that screenshot from other thread. note that file is for the smart update feature .
hope it works for you ok ..brian
