xray77
Post by xray77 »
Hello, Brian,
It now works in the standard display, thanks for the download link!
Despite the changes in the shared.php there is no change in the NanoSD display, but that's not too bad, I have the standard display... :)
It's a pity that you won't be able to update the NanoSD display, but you will have your reasons for that.
I thank you for the fast and competent help, this is not self-evident nowadays!
Edit: i have found another little issue:
The left field represents the average wind speed, right? But the Beaufort value displayed is linked to the current wind speed, not to the average wind speed displayed in the field. So the BFT value should probably be in the field of the current wind speed and the max-value texts from the current wind field in the average wind field. Simply said: exactly the other way round as current... ;-)
Bildschirmfoto 2020-03-16 um 12.45.11.png (163 KiB) Viewed 6695 times
Best regards
Mike
been raised before a few times but template uses the direct string from meteobridge output position 12 in the api output [wind0wind-act=bft.0:--] . no formulas or manipulation in template for Beaufort readings . in livedata.php you will see $weather["wind_speed_bft"] = $meteobridgeapi[12];
perhaps in the future move the bft output to windspeed but needs some thought as not to congest and cram the info into small areas otherwise it all becomes a mess. lets look at this in the future ...
the value in the larger box is an average wind speed reading not actual
Brian
weatherist34 wrote: Mon Mar 16, 2020 2:49 pm been raised before a few times but template uses the direct string from meteobridge output position 12 in the api output [wind0wind-act=bft.0:--] . no formulas or manipulation in template for Beaufort readings . in livedata.php you will see $weather["wind_speed_bft"] = $meteobridgeapi[12];
bft is actual
Brian
xray77
Post by xray77 »
Hello Brian,
Hello, Brian,
OK; there is of course no easy manipulation possible if the BFT value comes directly from the Meteobridge... :|
The only possibility seems to be to calculate the BFT value directly in the template from the average wind speed. If you do it so, you first need a formula for calculation...
I don't know if this might help in the future, I have a javascript (works with WSWIN-Weatherstation-Program) for the conversion.
var wind = %avg10minwindg% (its the variable in WSWIN, might be replaced with ["wind_speed_avg15"] = $meteobridgeapi[72]? but I seem the Meteobridge-output is in m/s?
Wind data here in m/s:
var bft = 0
var txt =" bft"
if (wind > 0.28 && wind < 1.67){bft=1;}
if (wind > 1.66 && wind < 3.33){bft=2;}
if (wind > 3.32 && wind < 5.56){bft=3;}
if (wind > 5.55 && wind < 8.06){bft=4;}
if (wind > 8.05 && wind < 10.83){bft=5;}
if (wind > 10.82 && wind < 13.89){bft=6;}
if (wind > 13.88 && wind < 17.22){bft=7;}
if (wind > 17.21 && wind < 20.83){bft=8;}
if (wind > 20.82 && wind < 24.72){bft=9;}
if (wind > 24.71 && wind < 28.61){bft=10;}
if (wind > 28.60 && wind < 32.78){bft=11;}
if (wind > 32.77){bft=12;}
if (wind == 0) {document.write('silence')}
if (wind > 0) {document.write(bft)}
if (wind > 0) {document.write(txt)}
Maybe you can adapt something like this to php at some point in the livedata.php. :-)
I already thought that it is a space problem to put the BFT value into the current wind field.
Thanks for your explanations! Thank you very much for the very fast reaction time and for your excellent work in offering this possibility of weather data display.
Best regards
Mike
Hello brian, how do I call up the charts in the mobile phone version?
The button is removed with the new switch C/kts...
xray77
Post by xray77 »
ToTo wrote: Tue Mar 17, 2020 1:12 pm Hello brian, how do I call up the charts in the mobile phone version?
i am not Brian but the button is now here:
regards
Mike
Hallo Mike,
not on my iPhone 8. A small error is also the arrow that shows above, although the text says falling.
xray77
Post by xray77 »
Okay, so I guess Brian has to look.
I am surprised that it is different with you than with me, I would not have expected that now.
(iPhone 10XR and iPad Air II)
regards
Mike
please note this project is now archived on GITHUB until some normality returns ..
compromises were made to cater for languages extra metrics and so on , the chart display and forecast are now accessed via icons .having the option of F,C,kts,mph,kmh,ms ,charts,almanac,forecast,forecast summary just simply is not possible in all screen devices so the almanac,charts, forecast,forecast summary are icons . as per screenshot.
best I can do for now .
Screenshot_2020-03-17 Demo Home Weather Station(2).jpg (149.22 KiB) Viewed 6630 times
Brian, I'm more than happy with the solution.
Take care of yourself!
Torsten
xray77 wrote: Mon Mar 16, 2020 12:30 pm Hello, Brian,
Best regards
Mike
an idea but need it is of interest to anyone to use as opposed to wind speed average module ?
does this work ? a color coded Beaufort module replaces wind speed average module ..please let me know if possible before Sunday 29TH March..
allow time to translate a few words.. i.e wind barb scale
if not ill leave as is ..
Nice that there is something new again :-)
The Beaufort module shows the current wind speed or the average? I prefer the current one.
Wind Run is already used with the wind speed module, I might still have an average wind speed at that position.
ToTo wrote: Fri Mar 27, 2020 6:31 pm Nice that there is something new again :-)
no planned updates for the nanosd version anymore so this option wont affect you or others using that version its just an idea and i prefer it being in a rather predominant wind location where calm days are rare . ps windrun is moved into beaufort module when used and shows daily average in wind speed module . but as above option will be in standalone version only.
weatherist34 wrote: Fri Mar 27, 2020 9:25 pm no planned updates for the nanosd version anymore
Very sad to hear that. Can't the module also be an option for the nanosd version?
The console version for nanosd is actually identical with the MB SMART Console Ver 4.0 or not?
don't be sad I said weeks ago I wanted to move away from the NANOSD version as its reached its limit and really went beyond what I initially wanted to design around . The console version standalone is different and much easier to implement changes.
STANDALONE version once installed with default data aprox 4.2MB (download size zipped 970Kb)
you can see the difference just in size how the standalone version is easier to maintain and has very small footprint.
NANOSD version will remain as just a download via the download page no need to remove it as many still prefer that to use .
