weatherist34 wrote: Sat Apr 04, 2020 10:07 pm
Hello Chuck
slowly adding missing parts just added the min max values to charts see screenshot. think Ive resolved the update file it is definitely my Macbook causing the issue so Im installing/upgrading it to Catalina as that what my desktop had been using .
screenshot of chart additions shows in today/month/year but not previous year
Hello Chuck
thanks just pushed an update ..interesting how Firefox is beginning to be different to webkit browsers like safari,chrome etc .
screenshot of Firefox just now.
Screenshot at Apr 05 12-41-41.png (163.04 KiB) Viewed 4765 times
BigAlT wrote: Sat Sep 21, 2019 5:35 pm
Is Boris going to upgrade the Nano SD local dashboard to the new Weather34 Template ?.
Yes, I plan to make it as a second dashboard option available. Only problem is that I am brutally short of time. So please be a bit patient on this...
Has this been pushed out yet via the reboot updates to MB NanoSD users?
I love the Weather34 that came built into the NanoSD. I have read the forum and the Weather34 web site about the new design update but I'm confused. Can I update this myself on my NanoSD or should I wait for it to be included in MB update?
I'm using MB NanoSD (Meteobridge 4.3 (Mar 24 2020, build 3025), FW 1.3). I only have physical access to the NanoSD twice a year when I'm visiting the house where it's located.
Just wanted to say I tried the 04/04 update with the settings updater and it appears to be working now. I prefer to use github it's much easier to keep my system up to date and I like seeing what your changing so I can check the results ..
I noticed the Firefox thing yesterday but all is looking good on my ipad and W10 now.
Hello Chuck
Everything is looking good on all the browsers that I tried. I have one minor 2019 rain chart scaling issue (inches), but I think it may be because of the extremes during 2019. You can see it below. Not a big deal.
Thanks ToTo. I read that in the Sept 2019 FAQ but wasn’t sure if there was any new information. I love Weather34 interface. I will wait for the update.
Thanks again.
Hello Chuck
ToTo wrote: Mon Apr 06, 2020 10:00 am
Good morning,
i get an overlapping text "Sonnenuntergang" from sunmod module, when I open the webcam, info or template info window:
Would it be possible to include a switching of the console language in the interface?
Good afternoon Toto
I have adjusted the css to remove the overlap (z-index) . as for languages needs a lot of rewriting and some thought how to offer that not something Im planning on in the near future . but lets look at it at a later date as the only thought needs to be how to offer in terms of display without congesting the rest of the appearance.
Would it still be possible to add another module e.g. for indoor humidity chart? Because I have no UV or solar sensor and the only alternative is to view the indoor temperature twice in the smartphone chart.
Toto not at the moment not doing any new additional modules but we can implement some existing modules as a replacement for those not having uv or solar .
I added two option to the setup screen as a short term fix for you best I can do for now.
as in previous post I have allocated my desktop Mac to wife for the foreseeable future which I do or did most design work on. I don't find using a laptop screen very productive and don't have all the software I have on my desktop on my laptop to do some of the finer design code.So for now I am not doing anything apart from what is reasonably quick or manageable(simple) on a laptop.
screenshot of the extra option you can choose sun or clock
weatherist34 wrote: Thu Apr 02, 2020 3:40 pm
i did buy a 3g router hub which uses my cellphone account i used it reliably when the electric outages occurred district wide but unfortunately its 600km away in second home in a box ..
ps i saw your pm on lightning feature .. if you have a secondary tp link type hub sitting around then no problem as you can just send a separate request to a dedicated wf lightning file ..its quite easy and only contains a few strings . im not familiar with wf api anymore as i dont use anything apart from the lightning feature..which might amuse you as i only use if for lightning not temperature etc i buried it in the garden horizontally stuck it in a few ziplock food bags to prevent it getting damp or water getting in and now i dont get the seasonal combi gas boilers triggering false lightning and it works just as good as when i had it located near the house..
I thought I will give it a try. I did setup a spare Meteobridge with WF and I have it generating MBrealtimeupload.txt file, every 5 minutes, in mbridge2 (just picked that folder at random- can easily change it). Seems to be working fine.
