http-request error message, how can it fixed? **solved**
xray77
Post by xray77 »
Have a problem on my NanoSD: Since a few days there is always an HTTP error on the live screen of the Nano SD for the HTTP requests on my webspace. I have installed the weather34-template on my webspace and this must "feed" with 3 http-requests.
one or all of this 3 (numbers 16,19,20) requests produce an error-message, but it seems to be working for the assumed template.
I have a lot of services running (19 from max. 20), here are screenshots from all defined services:
Bildschirmfoto 2020-04-19 um 11.26.13.png (379.26 KiB) Viewed 1670 times
Bildschirmfoto 2020-04-19 um 11.26.26.png (348.81 KiB) Viewed 1670 times
Bildschirmfoto 2020-04-19 um 11.26.36.png (302.34 KiB) Viewed 1670 times
On the live-screen of meteobridge:
Bildschirmfoto 2020-04-19 um 11.33.46.png (245.45 KiB) Viewed 1670 times
This error message remains as long as I leave the http-requests active, if I switch them off, the error message has disappeared. Apparently, the http-requests are still executed, because the requesting template (weather34-template) contains all graphics and forecasts, which are requested with it.All my other uploads to my webspace works without some issues..
A reboot of the Nano SD and a reinstallation of the template on my webspace don't change anything...
Has anyone an idea, how I can fix this error-message on Meteobridge-livescreen, this would be great!
regards
Mike
Re: http-request error message, how can it fixed?
try removing/deleting the word "success" ..
Screenshot at Apr 19 13-10-.jpg (141.61 KiB) Viewed 1665 times
xray77
Post by xray77 »
Hello Brian,
Thanks, I will try it..
it would be crazy if it was just that word... Then what is this field for anyway?
:-) Yes, that was actually the cause, incredible! The error was gone! I had searched hour by hour to find the reason, but I would never have come across this cause! :-)
Just a few minutes ago the meteoBridge completely hung, I must make it powerless to reboot it... :(
The service "reboot" would be run every day at nighttime now, hope this prevent such as it in the future..
Mike
Re: http-request error message, how can it fixed? (Solved!)
no problem glad it is ok now. :D :wink: :wink:
tip when you have an issue provide as much info and screenshots as possible someone will spot the problem sooner or later ..
