rzelle-K1TTC wrote: Sun Apr 19, 2020 2:36 pm Hi Brian,
Hope all are well there. We are in the midst of "The Surge" as they claim so staying home as before.
I've been keeping my site up to date as you make improvements.
I have a request or 2 if we have the UV & Solar sensors can you add UV plot as a module in the Daily Charts as you did for Purple Air. It would be nice if both UV & Solar could be plotted in one chart but that may be too difficult UV would be the the most important to see. Another thought I had is it would be nice while in the Daily Charts to have the option to step back to the previous day or more.
73s
..Ron
Hi Ron,
You may already know, but I just use the UV selection in place of indoor for my daily UV chart.
Stay safe.
No Download Weather34 TEMPLATE is possible.
I found also nothing on GitHub https://github.com/weather34
Brain can you explain this?
meteolive57290
Post by meteolive57290 »
hello
http://seremange-meteolive.franceserv.c ... charts.php
after the update version Standalone of the day, i can't find the WIND block_chart for my station :?:
thnx and best regards
i could but its not something i want to discuss here this is a meteobridge product forum not a place too hang out dirty laundry .. as of 20th April you can request the template , if you have a valid github user account you can request access to regular changes and follow changes via normal github web access or a desktop github application.
all requested downloads are unique to your request not different from any other . you can still use the small update packages as per normal as these only contain updated files not full installation.
the unique download to your request only contains info relevant to yourself, it does not do anything malicious, it does not call to home, it runs just as per any previous version .
many already use the github web or application to follow updates .
dont read anything into it has nothing todo with anything related to this forum or users on this forum. this forum and its users has provided much of the ideas seen in the current version however sometimes it is not easy to implement all ideas some need some thought and justification of being widely useful. i never like to say no or ignore ideas just some ideas will defeat the idea of having a low resource , small manageable template . this is why i strongly suggest if anyone wants more data , more capabilities then its better to use the version released by wim van de kuil as that is the only ongoing supported similar template regularly maintained.all others have or are no long developed or reached their optimum.
i hope that clears any curiosity in the sudden change. the change was not a radical thought just considered over a few days.
brian
meteolive57290 wrote: Mon Apr 20, 2020 10:46 am hello
internet died or just failed to confirm upload during this morning please try and download again. it just installed ok here.
rzelle-K1TTC
Post by rzelle-K1TTC »
Chuck & Brian,
Chuck Thanks for the Tip on the UV Chart that works out well for me.
Brian, My Github app is having problems connecting to the repository this morning was something changed possibly it was renamed?
Thanks to both of you
..Ron
rzelle-K1TTC
Brian, It sounds like I need to request access to the template on github my ID on github is rzelle and logging in with rzelle@actweb.com
Hope all is well ...
73s
..Ron
rzelle-K1TTC wrote: Mon Apr 20, 2020 1:56 pm Chuck & Brian,
..Ron
Glad that worked for you Ron.
rzelle-K1TTC
Received the invite and accepted all is githubing with app again now. :-)
..Ron
rzelle-K1TTC wrote: Mon Apr 20, 2020 5:18 pm Brian,
..Ron
cool business as usual for you no delays ..GITHUB is the way forward .
rzelle-K1TTC
Thanks Brian, Yes it works well.
..Ron
xray77
Post by xray77 »
Hello Brian,
I think I found a small error in the graphic display of the month in the wind maxima.
I use the MBSMART template with the nano SD display and the integrated console display. With the nano SD graphic display the monthly max wind values are displayed correctly, but with the console display they are too low:
Console-Screen with wrong wind-max
Bildschirmfoto 2020-04-20 um 21.40.33.png (64.72 KiB) Viewed 4811 times
MBSMART-Screen with correct wind-max
Bildschirmfoto 2020-04-20 um 21.39.37.png (300.73 KiB) Viewed 4811 times
Is there still a way to correct this or is it not possible because the MBSMART template does not actually receive any more updates and my console-screen is a part of the MBSMART-Template? I would like to have both possibilities to view the weather-data...
By this way: many thanks for your work and the very good support!
Stay healthy and best regards
Mike
good morning no problem
the link below contains 6 files .
monthwindspeedmodulechart2.php
monthavgwindspeedmodulechart2.php
yearwindspeedmodulechart2019.php
yearwindspeedmodulechart2.php
yearavgwindspeedmodulechart2019.php
yearavgwindspeedmodulechart2.php
basically adds the missing conversion
else if ($windunit == 'kts') {$conv= '1.94384';}
download
unzip on desktop
upload to server into the console/weathercharts folder job done.
http://www.mediafire.com/file/al6hqoapt ... x.zip/file
Brian
xray77
Post by xray77 »
Hello Brian,
Many thanks for this superfix little update, great support! Works perfect now!
Have a nice day and stay healthy!
Best regards
Mike
no problem and i got your pm.
for the interest of others based on your offer. Donations are not required , i never monetize anything todo with my hobby , donations are not required but I dont ignore the appreciation but you would have received a thank you but not necessary message,reply. Ive stuck to this principal for past 5 years or more. Doing this template costs me nothing but a little bit of personal time ,the biggest and best donation you can offer is contribute with ideas and constructive discussions that benefit others. as I always say i just make it look pretty . for those not in the know Paypal is not a recognized tender here it is blocked and impossible to transfer payments from paypal to a regular bank here and living here I use the regular banks .so please I dont ignore the offer, the appreciation but it is not necessary or expected and I dont put a price tag on my time if I did I probably would not still be doing this been there before never mix business with pleasure/hobbies.. as per my website quote.”you probably already spent enough of your earned money on your hardware to even consider using this template so its nice not to have an additional cost to pay just a little bit of your personal time.. “
brian
