as it is positioned now the combi boiler exhaust extraction outlet is aprox 20 feet away so when using the shower or running a bath the diy aqi unit readings almost doubles so kind of highlights it works to some extent , but just might hang it in the garden if the wireless reception holds up. i have another unit sitting in a box in our second home wish i hadnt taken it with me .
https://shop.airvisual.com/row-en/monit ... ro-eu-plug
toto i will make a simple graphic highlighting intervals for each position but in short wind based positions are 10 second intervals the rest like temp,rain vary from 60 seconds to 2 minutes for barometer . its always been like this since 2016 in all versions.
rzelle-K1TTC
Post by rzelle-K1TTC »
Hi Everyone,
Trying to keep up with what's happening with AQ Sensor support etc .. I'm considering adding one. Brian did you build you're own if so where did you find plans? I looked at the link you included for the airvisual but was considering the purple air.
After the last updates when viewing almanac then returning to main screen it opens another tab.
73s to all
..Ron
rzelle-K1TTC wrote: Thu Apr 30, 2020 4:50 pm Hi Everyone,
73s to all
..Ron
Hi Ron,
I have been pleased with the Purple Air unit. I have had it for 12-18 months and it has worked fine during that time.
Yes, on the New Tab. I think there is a target="_blank" in there.
rzelle-K1TTC
Hi Chuck,
Brian stoked my DIY curiosity when he mentioned a DIY Sensor .. BTW what are you using for Lightening Strike sensor.
..Ron
rzelle-K1TTC wrote: Thu Apr 30, 2020 5:27 pm Hi Chuck,
..Ron
I have a WeatherFlow station https://smartweather.weatherflow.com/station/4781/grid that I have been testing for a year, or so - Brian had one, as well. It is a 2 part station, and one of the units came with a Franklin style Lightning sensor, built in. They call the 2 units - Sky and Air. The lightning sensor works well. I have found that the rain and wind sensors are not very accurate.
You do have to run a separate Meteobridge to get the data from Weather Flow to Brian's Template.
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Thu Apr 30, 2020 2:46 pm as it is positioned now the combi boiler exhaust extraction outlet is aprox 20 feet away so when using the shower or running a bath the diy aqi unit readings almost doubles so kind of highlights it works to some extent , but just might hang it in the garden if the wireless reception holds up. i have another unit sitting in a box in our second home wish i hadnt taken it with me .
hello bryan,you could add a small clock that indicates the refresh time of each individual module??? would it be a doable thing?? Thank you
73s to all
..Ron
bought my iqair model over year ago for our second home wife is a bit particular about industrial looking things so that suited me and herself , purple air dont ship to turkey or didnt at the time . the diy air quality was build yourself cheap from china i ordered it early december it arrived a few days ago ! i actually had given up and pretty much forgot about it and suddenly knock at the door a few parcels all turned up at once.. i will find the parts i ordered and forward them on vi pm in total i paid around $48 inc shipping no local tax surprisingly .
personally i would buy the purple air more robust for outdoor use .
as for lightning it was the only thing i found useful out of the weatherflow stuff mines buried in the ground in a sealed bag as its used for lightning only the rest of the wf stuff i have running up on the roof until battery dies and then it will just sit in a box forever more sadly unless someone wants to arrange and pay the shipping and import costs they can have it for free .
i think you could just buy the weatherflow air alone if you want a cheap method of localized lightning detection, fortunately im located with a 270 degree of nothing but sea no properties etc so i get a rather extended range of detection like today for example most of the strikes detected were some 80-100km away using the popular blitzortunglive app to compare but its all sea direction the range towards the city is greatly reduced as localized generated noise is far higher .mine is hooked up to an old tplink type meteobridge which does the job perfectly.
you can buy it ready assembled mines based on the nova component seen here with the wireless node.. https://weatherspares.co.uk/collections ... monitoring I had to source the tubes/pipes locally and build my own casing.i just clicked on purchase link for mine and no longer is there but there are other variations just have to find the parts on Alibaba https://www.alibaba.com/product-detail/ ... 2d075OB0ys
meteolive57290
Post by meteolive57290 »
http://valdefench57sgz.franceserv.com/pws/index.php
http://seremange-meteolive.franceserv.com/pws/index.php
hello
since this morning my two templates are offline my meteobridges work for data reports I have the following log
an idea ?
thnx and best regards
Although it is strange that both Meteobridges have the same problem:
Did you reboot the Meteobridge already?
I had the same type of problem once. The realtime file was not uploaded at all.
Reboot of the Meteobridge solved that.
@ xxvincixx
does this work for you not perfect but this derives from the time the meteobridge file uploaded/updated to your server .
let me know .
Screenshot at May 01 10-48-36.png (205.83 KiB) Viewed 5664 times
meteolive57290
hi
i just rebooted my two MB I have an online status but no report data ... my MBrealtimeuoplad.txt file does not download or more :?:
no worries before this morning :(
did you delete MBrealtimeupload.txt ?
does your server permit to create a new file MBrealtimeupload.txt if it does not exist ?
were folder/file permissions compromised/reset ?
need to check things at server level to eliminate if server issue
then no logical reason to see why meteobridge is reproducing the error would suggest open a new thread to get more ideas .
mbridge/MBrealtimeupload.txt returns a 404 !
does the folder mbridge exists?
meteolive57290 wrote: Fri May 01, 2020 10:15 am hi
The error occurs probably between your Meteobridge and your website.
It could be your local network/router:
You should test that with http://seremange-meteolive.franceserv.c ... /mb.php?d= in your browser.
The message "success" should be displayed and an empty file should occur on your website.
But
Again VERY strange that both Meteobridges accessing two different websites fail.
You should contact your provider if they blacklisted your uploads.
Maybe they do not like your frequent uploads?
Ask them, just to be sure.
Or it can be the contents of the ?d= which the Meteobridge can not handle
From the LiveData tab, could you please try to copy the whole string from ?d= to the end?
And post that in your message inside code /code which occur when you click the button </>
It seems the mb.php is not run, that the error occurs before mb.php can store the contents in a file.
So lets check what is in the file that your Meteobridges are trying to sent.
Also
As this seems to be NOT a weather34/ problem, and if this is not solved quickly, you should post this in a new topic named something like "http upload fail". Then other more technical poeple will look also to your post.
Mention the version of your Meteobridge as displayed on the system tab.
please move to another thread .
