Wheater34 template
Wheater34 template
Post by 36260 »
I'm using Wheater34 template on Nano HD. When a chart is displayed (click on the footer of a widget), month is not displayed in the correct language. "TOUKO" is currently displayed (English or French UI) which seems to be Finnish?
Re: Wheater34 template
hello there is no Finnish(Finland) support ? please provide a url so I can determine which version you are using ? if its private/non public then send a url via a Personal Message .
ConligWX
Post by ConligWX »
TOUKO maybe Danish as the local dashboard (Meteobridge DASHBOARD W34-MB) has that language build in.
would be nice if a screenshot or two was posted so we can see exactly what and where the OP is talking about.
36260
Post by 36260 »
Version (Final) Source:Meteobridge NanoSD(4.3-3057) Hardware:Davis® Vantage Pro2 Solar™
Every graph display month to what I think is Finnish or maybe Danish. UI set to English or French does not matter. Touko meaning May
36260 wrote: Sat May 23, 2020 6:14 pm Version (Final) Source:Meteobridge NanoSD(4.3-3057) Hardware:Davis® Vantage Pro2 Solar™
i see thats the internal version in the nanosd the graphs are generated by the nanosd meteobridge software so it is not something i can help with. perhaps Boris can help... also beware that version is using darksky for forecast data it is no longer possible to get an API key for new newer purchases of Nanosd only older users will see a forecast .may be a user(s) can share an api key ?.. sorry i cant help...brian... ps pm if you need an api key i have two keys i dont use anymore..
ConligWX
Post by ConligWX »
yep, not sure what the issue is, as I dont have "Touko" at all and mine is set to English.
I take it you have go into the menu of that page and setup any "settings" that are needed?
http://ip.of.mb.nano/PWS/easyweathersetup.php
jasonmfarrow
Re: Weather34 template
Post by jasonmfarrow »
Brian, yes please (if there are no other takers....).
Jason
sorry I only had two I sent them out a few days ago .
36260
Post by 36260 »
you did not receive my pm that I sent right away? Any change to migrate to PWS weather?
Any chance that the bug regarding the month language be sorted out? Pretty annoying when looking at a full year.
i see it now it .. but didnt see it over the weekend sorry about that . internal pws graphs i cant help what do you mean by pws weather ?
36260
Post by 36260 »
I mean replace Darksky API (that will stop access in 2021) by PWSweather API https://www.pwsweather.com/
best ask boris anything at firmware level i cant actually do anything to help.so sorry about the key i just didnt see your pm until earlier..brian
36260 wrote: Wed May 27, 2020 1:04 pm you did not receive my pm that I sent right away? Any change to migrate to PWS weather?
have sent you a key I had another old email registered at dark sky logged in and found a key I have never used hope it is of use..Brian
36260
Post by 36260 »
Hooray! Thank you very much. Are there any plans to transition to another weather network, since Darsky will cease access to API in 2021.
36260
Post by 36260 »
ConligWX wrote: Sat May 23, 2020 9:19 pm yep, not sure what the issue is, as I dont have "Touko" at all and mine is set to English.
I had the idea to set display language menu to no. Then the bug disappears. Reverting to yes and the problem cannot be seen any more. However let’s say one select English in the menu langage then the language of the month will stay in stay in French whereas it should have switched to English.
