Re: Weather34 TEMPLATE
Good morning
simple (526kb) Standalone-update-03-06-2020.zip update adds to barometer module month max/min values and repositions current day max / min as per screenshot.
update available via https://weather34.com/homeweatherstatio ... alone.html
alexeysailman
Post by alexeysailman »
Hi, Brian! Please tell me: your latest update 03-06-2020 only works for those who use hPa and inHg? You added more mmHg in trends and on the main screen, maybe that's why I can't see these changes after this update?
just updated the simple update file was waiting to see if the recent firmware update produced a timestamp after no rain for three days .still waiting as it rained :-( just when you don't want it too. anyway screenshot
Screenshot at Jun 06 11-25-27.png (64.99 KiB) Viewed 5141 times
alexeysailman
Everything works! By the way, a couple more points about this:
- in your previous post about this innovation, a marker with the inscription 24H is visible on the screenshot, and here it is missing, is it so necessary?
- even when you introduced a new unit of measurement in the form of mmHg, now it is everywhere except the almanac, there is still hPa.
good evening
should be ok now just download the update (80kb) Standalone-update-06-06-2020.zip again from https://weather34.com/homeweatherstatio ... alone.html and run it via the update screen should be fine now. sorry the value at 24 hour ago is not available it is not in the API that is from my custom personal API. I did ask years ago what would be the preferred and the majority preferred max / min indicator.
screenshot of almanac mmHG
ConligWX
Post by ConligWX »
Brian, I just updated to the new update and the purpleair cloud at the bottom of the footer has gone. did something change?
https://www.conligwx.org/pws/index.php
ahh. now under AQI name...
Hope all is well. I have been checking updates on Git, but I just noticed that there appear to be a few files in the updater zip that I did not see on Git.
The ones I have noticed so far are: console-light.css, console-dark.css, console-setup.php, directionmod.php, rainmod.php, shared.php.
Just wanted to make sure I did not miss anything.
hello Chuck 99% of the time the GITHUB is the master and latest as it is easier to update realtime from the local server(localhost), the small standalone updates are majority of the time a day behind the GITHUB as it is a compiled zipped file to ensure only neccessary updated files get updated.
weatherist34 wrote: Sun Jun 07, 2020 4:02 pm hello Chuck 99% of the time the GITHUB is the master and latest as it is easier to update realtime from the local server(localhost), the small standalone updates are majority of the time a day behind the GITHUB as it is a compiled zipped file to ensure only neccessary updated files get updated.
OK. I will continue to use Github. Just grabbed the latest. Which one of these is these is the preferred for Purple Air? Seeing two versions.
Latest on Git is the first one.
Take care.
ha my slight error as usual :D i was going to implement support for additional air quality sensors using the nova pm sensor but backed off as i could envisage spending hours trying support how to sniff the data locally .so ill remove the AQI text icon and revert to purple air icon as per GITHUB master . thanks for highlighting i didnt realize i had included it but going forth only going to support purple air use i know there are others but dont want to get sucked into supporting stuff i have no knowledge off .
OK. That works fine for me! :D
Lespius
Post by Lespius »
I am running the version 5.34. Do you recommend to download just the latest update or the full one?
Second question: what is the source of data for the almanac. I thought it would be /weather34/charts/2020.csv ? but it seems it is not this file.
Alain
http://www.meteo-cugy.ch
http://www.meteo-cugy.ch/MBSMARTv2.0/console/index.php
hello might want to run this (920kb) Standalone-update-07-06-2020a.zip from the link below
contains all the updates I think since version 5.34 . if not just request a full download request and save your current weather34charts folder to your desktop and install the new full download and then just copy/upload the weather34charts folder you saved to the new install.
but try the Standalone-update-07-06-2020a.zip via
https://www.mediafire.com/file/16xlsokt ... a.zip/file
please note the password to download full version changes on Monday at 12:00 midday my time(istanbul)
Lespius
Post by Lespius »
Ok, thank you. I have already dowloaded the *zip. Maybe I will ask you for a password on Tuesday.
And what about my quations about about the data source of the almanach?
sorry i missed that ..almanac history values , data is delivered via the meteobridge API values not the graphs .
