Weather-network "Schleswig-Holstein-Netz" not accessible **solved**
xray77
Post by xray77 »
i am a member of the weather-network "Schleswig-Holstein-Netz", who is selectable in the list of the weather-networks. If I select this network to add, it will not appear in my list of weather-networks. So I can't configure any to send data to this network.
My MeteoBridge-Version:
Plattform: Meteobridge NANO SD (awekas Version)
RAM: 125572 kB insgesamt, 43616 kB frei (65% verwendet)
Speicher: swissbit SLC, 1825 MB total, 1766 MB free (3% used)
SW-Version: Meteobridge 4.3 (Jun 9 2020, build 3101), FW 1.4
Laufzeit: 18 Stunden, 30 Minuten Puffer: 5 Einträge (1%)
When the weather network first appeared in the list, I was able to add and configure it once, but unfortunately it did not work with data transfer. After that I deleted it from my list and since then I cannot add it again to test it with new SW-versions. This procedure works for the other networks, but not for the "Schleswig-Holstein Netz".
It would be great, if anyone have a solution for this problem, many thanks!
best regards
Mike
xray77
Re: Weather-network "Schleswig-Holstein-Netz" not accessible
Post by xray77 »
..have installed the newest Version, no change of my problem..
RAM: 125572 kB insgesamt, 43772 kB frei (65% verwendet)
Speicher: swissbit SLC, 1826 MB total, 1765 MB free (3% used)
SW-Version: Meteobridge 4.3 (Jun 18 2020, build 3128), FW 1.4
Laufzeit: 7 Stunden, 25 Minuten Puffer: 4 Einträge (0%)
Unfortunately I can select the "Schleswig-Holstein-Netz" as often as I want, no configuration window is shown to me anymore. Not even with the latest version. I was able to configure it exactly 1x when it was displayed for the first time, few weeks ago... After I deactivated it again because it didn't work, I can select it in the list of networks, but no configuration window is loaded anymore.
Normally you would have to create an entry with "Schleswig-Holstein-Netz", but this does not happen. So I can't configure anything and no entry with "Schleswig-Holstein-Netz" is shown in the live data.
There also appears a Jun 20 FW4.3 but not sure if this is meant to be a final 4.3 or not? Doesn't appear to be as there is no sticky FW4.3 in either the Pro or Nano? FYI I can't load this particular WeatherNet in either a Pro or Nano.
Jun 20 update should have support for SH-Netz. But not fully tested yet.
xray77
Post by xray77 »
it also doesn't work with Jun 20 update..
same problem as described in earlier posting..
Another special feature has been on display for a few days now:
In AWEKAS an error message is displayed on the weather network page, but the transfer to AWEKAS works fine.
Bildschirmfoto 2020-06-21 um 11.24.41.png (160.88 KiB) Viewed 4652 times
AWEKAS: Reason is an internal warnong message reagrding an SQL statement on AWEKAS side. I made Meteobridge more tolerant to this. Just released update fixes the problem.
SH-NETZ: Network was still restricted to Meteobridges in "beta program". Just released update fixes that.
xray77
Re: Weather-network "Schleswig-Holstein-Netz" not accessible **solved**
Post by xray77 »
Hello Admin,
within the last Update all works fine now!
Thank you and best regards
Mike
xray77
Post by xray77 »
Hello Admin,
I have found two more things... 8)
First, the windspeed-data: it seems so, MB transmits the wind speed-values in m/s, is this correct? Therefore, the admin of sh-netz would be to adapt the windspeed in his charts from m/s to km/h because in his charts the windspeed is displayed in km/h..
Second, the pressure tendency (3h) isn't transmitted. Is it possible to integrate this value to the data-transfer, that would be great!
Michael
Thanks, one wind parameter was still reported in m/s, I switch this to km/h, so no need to have a special procedure for Meteobridge data.
Which values are you expecting for tendency? 0, +1, -1? How are the tendency values defined? Having that definitions, I can easily implement that.
xray77
Post by xray77 »
Thanks for your very quickly response!
I asked the SH-Netz-Admin, which pressure tendency values are needed, waiting for answer and will post it immediately here.. :-)
thanks and best regards
Michael
xray77
Post by xray77 »
Hello Admin,
The SH-Netz-Admin wrote to me:
"I still need the penultimate value in the data string: air pressure tendency of the last three hours as numerical value (current) in hPa"
I think with one decimal point e.g. -3.1 / 0.3 or so...
hope, this helps?
best regards
Michael
Please try again with latest update.
xray77
Post by xray77 »
Hello Admin,
Ok, i will try it after the next regular reboot (my MB auto-reboots after 48 h runtime) tomorrow afternoon.
Thank you very much for your fast response, this is cool!
Best regards
Michael
xray77
Post by xray77 »
Hello Admin,
All data provided to the "Schleswig-Holstein-Netz" seems to be correct now, included the pressure tendency
Thanks for it, great job! --> Meteobridge 4.3 (Jun 22 2020, build 3154), FW 1.4
Only feature I already miss is the native sunshine-hours-calculation with the MB, this is possible.. (see my posting from Tue Apr 21, 2020 12:53 pm on this forum).
If this were still an option in the near future, I would be extremely satisfied with the MB Nano SD. ;-) ;-)
Best regards
Michael
