meteolive57290
Re: Weather34 TEMPLATE
Post by meteolive57290 »
hello thanks for the ugrade :wink:
at home i have display ./consolecharts-month.php which does not display anything ?
the problem is present on my two sites !
an idea :?:
thnx BR
http://seremange-meteolive.franceserv.c ... -month.php
http://valdefench57sgz.franceserv.com/p ... -month.php
yep on inspection
I found the 2020.csv last date was 3rd June !
1 Jun,27.7,10.9,12.9,6.6,0.0,6.3,1.0,17.9,1019.1,1016.2
2 Jun,29.0,14.3,14.2,8.9,0.0,4.9,0.5,19.1,1017.3,1009.7
3 Jun,26.9,15.3,16.0,9.2,0.2,6.7,0.8,17.8,1009.7,999.0
then I run the consolecharts-year.php and the new file http://seremange-meteolive.franceserv.com/ on your domain http://seremange-meteolive.franceserv.com/ through the browser
it updated the file with July data so it looks like you have not been running the console charts-year.php since 4th June !!!
4 Jul,23.6,13.2,13.4,10.1,0.0,6.7,1.0,22.8,1019.0,1017.0
so check meteobridge services are correctly set to run as per guide .
nothing changed in anyway the way chart is handled if it had then it would be highlighted as a significant change the last significant change was in May 2020 with the newer alternative charts-end-of-day.php
(New for May 2020)
*New process allows to run the end of day at a few seconds before midnight as opposed to old process running at 23:45 ,allows true accurate end of day totals without missing the last 15 minutes of the current day.
Select the Services Tab
1. Goto Select new service
2. Select from the drop down menu HTTP Request
3. Select Perodical in the next menu
4. Click Save at the bottom of the screen
5. Now look for new HTTP request
6. select "before each new day" (it will run at a few seconds before midnight)
7. NOW INSERT THE URL example
8. https://yourdomain.com/console/charts-end-of-day.php
9. now click save .
*the path can be in the root if the template was uploaded to the root directory https://yourdomain.com/charts-end-of-day.php
*if you are an existing user *important remove(delete) the old service that runs at 23:45 https://yourdomain.com/charts-month-year.php
jasonmfarrow wrote: Fri Jul 03, 2020 6:44 pm
weatherist34 wrote: Fri Jun 12, 2020 2:00 pm hello jason
....when you have it installed and configured to produce valid data to file send me a copy of that file with valid data and ill compile a version for you.
Brian. I hope you enjoyed your time away. I worked on this whilst you were off. My AQI now looks like this:
Both sensors report via the Raspberry PI and upload to mbridge/AQIrealtimeupload.txt and mbridge/VOCrealtimeupload.txt.
If anyone else wants the code (for the RPi or the Template) I can make this fully available.
Jason looks cool is it sited/positioned indoors ? love to have a real world value of 1 -:) ...
@ron @chuck im very well thank you had to return to istanbul last week some unfortunate circumstances arose but off again next week has its somewhat easier to travel now ..hope your both well and guess you saw and grabbed the minor changes over the last week .nothing else expected apart from some minor alignments in the new addition ..take care and trust you are both well.. ps chuck reboot your meteobridge/weatherflow hub its registering 0 miles for distance strikes guess weather flow may have updated the hub firmware recently I tend to find a meteobridge/wf hub both need a reboot after wf firmware update to kick in the correct distance reading output.no idea why but reboot cures it..Brian
meteolive57290
@brian thnx fr responsive oups :oops: i had indeed deleted the old cron task but not configured the new one ./charts-end-of-day.php !
i just executed the setup in stride ... it should be good finally I hope! have a nice week end BR
update 5-7-2020 (117kb) Standalone-update-05-07-2020.zip
adds theme dark/light switching to indoor screen + adds new setup option to hide indoor icon if no data available or wish not to use
All is well here. Virus continues to escalate as we are invaded by tourists, but it will gradually return to normal.
Thanks for reminding me to reboot the meteo/wxflow for strike distance. Humid hot air has been generating plenty of afternoon storms. Just grabbed the latest update and noticed that the link to return "home" from the Indoor Module is going back to the root (../index.php). Looks like the path need to be changed.
Best wishes,
yes I know what you mean about the humidity same levels here in istanbul at the moment unbearable combinations of 90-98% humidity with 25-30c(73-86F) at night time absolutely mullers (disturbs) you (Monday it was 30.5C-86.9F at midnight no wind it was crippling !!) . daytime humidity drops but heat index is floating around 35c(95f) and very warm winds .just typical summer here but thank god for the AC ! .as for tourists like other coastal areas its a part of the economy and peoples livelihoods , unfortunately its not an easy decision for those who govern many of my friends have family business like fish restaurants local shops etc most of those were on the brink of collapse and adapted to home deliveries but now most are open with restrictions in place.in istanbul on the outskirts where we live is a low risk area but drive 5 km into the city the risk factor is high .masks are compulsory by law with a hefty fine caught without whilst outside of your home !! there are no exceptions one rule for all across the country..
pushed the fix for the path of index.php ..many thanks Brian
weatherist34 wrote: Sun Jul 05, 2020 2:54 pm yes I know what you mean about the humidity same levels here in istanbul at the moment unbearable combinations of 90-98% humidity with 25-30c(73-86F) at night time absolutely mullers (disturbs) you (Monday it was 30.5C-86.9F at midnight no wind it was crippling !!) . daytime humidity drops but heat index is floating around 35c(95f) and very warm winds .just typical summer here but thank god for the AC ! .as for tourists like other coastal areas its a part of the economy and peoples livelihoods , unfortunately its not an easy decision for those who govern many of my friends have family business like fish restaurants local shops etc most of those were on the brink of collapse and adapted to home deliveries but now most are open with restrictions in place.in istanbul on the outskirts where we live is a low risk area but drive 5 km into the city the risk factor is high .masks are compulsory by law with a hefty fine caught without whilst outside of your home !! there are no exceptions one rule for all across the country..
Same here. The small businesses were hit hard and are struggling to stay open and comply with the requirements to protect customers and employees. Fortunately, in our area, while the infection rate is rising (particularly the young), the number requiring hospitalization seems to be dropping off.
Thanks for the update :D
rzelle-K1TTC
Post by rzelle-K1TTC »
Brian & Chuck,
Noticed the link issue Chuck beat to it .. :-)
Re Covid19 Massachusetts is going to our Phase 3 this week except Boston which of course we are hoping does not cause a big spike in cases. Mask wearing in public etc is not punishable by fines but everyone I know are wearing them. My partner has been making different decorated masks for us to wear. :-) We've been taking advantage of the Senior hours at our Grocery and other stores which feels safer to us. My MSPCA Volunteer work as a Cat Matchmaker & Cat Task Force guy is just starting up very slowly now with no general public allowed inn the facilities without prior phone interviews and appoint.
Be Safe Everyone ..
..73s
..Ron
good to hear things are slowly returning to some normality but as ever be cautious ..so last update just pushed just now to the indoor screen addition with a few additional bottom modules to balance it all out.applied to both dark/light themes .
have a great weekend whats left of it...Brian
Till next time have a great week ahead time for me to head to the airport.. last minute clean up of code for the newer indoor addition with blue styled hover tips when hovering over functions/links and it should resemble the screenshot as of 6th July ..have fun and thanks for the feedback..
jasonmfarrow
Post by jasonmfarrow »
weatherist34 wrote: Sat Jul 04, 2020 3:33 pm
Yes, both sensors are in my Conservatory (also doubles as my office). This means that on a bad/cold/wet day the sensors get less fresh air and on a good/warm/dry day they can get more fresh air as I have the doors & windows open.
In no way would I consider the VOC & CO2 to be accurate readings. I've yet to see the CO2 move from 400ppm and the VOC varies wildly regardless of whether I'm in the room or not. The PM2.5 and PM10 appear to be reasonably accurate and responsive but are not setup as "outdoor" PM sensors so are always going to be on the lower side of reality but with the doors open and lots of fresh air wandering past they are giving consistent readings with other sensors in nearby areas.
Jason
jasonmfarrow
Odd formatting glitch between browsers for the weather34-ev.php: Chrome vs Edge on Windows10 (and elsewhere)
On Chrome:
ev on chrome.PNG (8.93 KiB) Viewed 5247 times
On Edge:
ev on edge.PNG (8.02 KiB) Viewed 5247 times
Changing the CSS to fix one breaks/worsens the other.
Jason
jasonmfarrow
Found it! In light/dark-indoor.css in .dashboardicon remove
  vertical-align: text-top;
which fixes the alignment issue.
Jason
jasonmfarrow wrote: Tue Jul 07, 2020 5:33 pm Odd formatting glitch between browsers for the weather34-ev.php: Chrome vs Edge on Windows10 (and elsewhere)
On Chrome:ev on chrome.PNG
On Edge:ev on edge.PNG
try redownloading the update 07-07-2020 just added a small fix (css) might help in chrome/ff/safari but no idea on Microsoft stuff don't own any ..
screenshot localhost in chrome osx macbook
