Re: Weather34 TEMPLATE
yes found a few references to that particular issue . ive reverted back to dots and balanced the barometer color to match . ill take a look next week see if i can do something to match the design the dashes didnt look right.
sorry ron thats my custom api output the daily average for wind direction isnt in the api perhaps next time i update the api structure which wont be anytime soon ill ask boris to slot it in .
No problem. I keep my working computers set on 110% - easier on my eyes. My main viewer for the Weather Station (Template) is a 23" Touchscreen and I have it set on 148% and the dots show up fine.
Take care.
Re: Weather34 TEMPLATE 8.34
Managed to implement some ideas forwarded but not all . some things need closely looking at but here is what I managed todo today . thank you to Bjarne (dk)/Torsten(de) for the languages update.
* Pushed to Version 8.34
* New setup UNIT options (requires to be set in setup screen)
* CSS refined color balances
* Calendar alignments
* Adjust Css to allow better icon alignment
* Danish Language updated (Ref Bjarne Riis)
* German Language updated (Ref Torsten)
* Minor CSS design change to bottom buttons
* Adds new Wind Compass design
* Adds Barometer color balance to Wind Compass
(426kb) Standalone-update-02-08-2020.zip via https://weather34.com/homeweatherstation/
jasonmfarrow
Post by jasonmfarrow »
Brian, the weather34popup is no longer working on index.php after the 8.34 update. The code in index.php looks unchanged in this area. Has something changed in the CSS to stop it working?
Jason
hello Jason . update has the following changes/additions
99% turned it off so it really didn't serve any purpose in general and in truth I guess it was an unnecessary overhead.
(426kb) Standalone-update-03-08-2020.zip
* REMOVES unnecessary popup intro
* Add circular grid to small air quality modules
* Add circular grid to forecast temperature
jasonmfarrow
Cheers. I'd rebranded the pop-up but I can see why it was removed.
Unfortunately If found a bug in weather34-tv.php on the weather34-dayforecast:
Jason
patience is a virtue just finished smart tv css .. unfortunately things take time and language alignments to check each time..
(426kb) Standalone-update-04-08-2020.zip
* Smart TV CSS updated to support circular grids
rzelle-K1TTC
Post by rzelle-K1TTC »
After this last update I'm seeing this in Positions 11 & 12 Did I miss something ? Everything looking Great! otherwise. Waiting for the tropical storm I'm sure Chuck has experienced already.
73s
.. Ron
Forecast and Sun problem 11-12.PNG (115.3 KiB) Viewed 5293 times
Hi Ron,
I am seeing the same issue on all of the chart pages.
The Hurricane/TS has not been bad, so far. Wind and rain, but nothing severe. It has spawned Tornados in a few spots. Looks like it will make a close pass by us around 10 - 11 pm EDT. Lots of dry air seems to be breaking it down.
I suspect it may not be a major issue by the time it makes it up to you, but they can change fast.
Take care.
rzelle-K1TTC wrote: Mon Aug 03, 2020 11:09 pm Hi Brian,
73s
.. Ron
no it was this end I was going through each module late last night and bang the power went so ive finished it this morning .hopefully should be fine across all webkit supported browsers and I think I got the languages aligned ok. if not then ill take up bird watching and confide myself to being totally blind forever more :-) .
ok I have addressed those alignments in sun, moon,forecast, etc
should end up like this with translations checked .sorry for the inconvenience just languages always take time to perfect but get there sooner or later..
(Updated 4th August 9:42 GMT)
* Adds translated phrases till sunset/rise to small module
* Updated CSS to support circular grids in chart view
* Adjust CSS to allow better icon alignment
Looks fine now! :D
rzelle-K1TTC
All looks good here too.
Just watching the Storm ..
.. Ron
Hello Brian,
I have installed the last update from 05.08. I see the heat index is not converted to my language german. In the sunset module the line break does not fit, in Safari iPad it is ok, in Firefox and Edge Chrome not.
bye
Torsten
ToTo wrote: Wed Aug 05, 2020 8:35 am Hello Brian,
bye
Torsten
one day there will be a balance between safari/firefox etc never can fathom why they render things so differently .anyway ive just updated the update file so download it again and run it .many thanks and added language translate value for heat index..screenshot
in firefox(ps your GitHub name you sent/gave does not exist so I cant add you to private access privialege )
