meteobridge doesnot connect to data logger vantage pro 2
dmanandhar
- Fresh Boarder
Hi Admin,
I am getting this error
test5m (04.09.2020 02:02:33): weathernet daemon stalled, will be restarted now.
wnetd (04.09.2020 12:02:33): process started.
test5m (04.09.2020 02:02:33): logger stalled, will be restarted now.
system (04.09.2020 02:02:33): stop of logging process initiated.
test5m (04.09.2020 02:16:06): logger stalled, will be restarted now.
system (04.09.2020 02:16:06): stop of logging process initiated.
system (04.09.2020 12:25:16): stop of logging process initiated.
test5m (04.09.2020 02:25:54): logger stalled, will be restarted now.
system (04.09.2020 02:25:54): stop of logging process initiated.
system (04.09.2020 02:26:02): stop of logging process initiated.
test5m (04.09.2020 02:35:44): logger stalled, will be restarted now.
system (04.09.2020 02:35:44): stop of logging process initiated.
Can you please suggeest on this. I have attached some of the warnings. Is that related with this error. Need suggestion to fix this problem. Thanks
- Capture3.PNG (8.13 KiB) Viewed 3407 times
- Capture1.PNG (33.29 KiB) Viewed 3407 times
- Capture.PNG (44.43 KiB) Viewed 3407 times
- Capture2.PNG (23.98 KiB) Viewed 3407 times
Re: meteobridge doesnot connect to data logger vantage pro 2
Are you using a USB 2.0 hub between your logger and the Meteobridge?
Meteobridge RPI | GW1000
dmanandhar
- Fresh Boarder
Nope. But Now I have connected to usb 2.0 hub And that error weather station tab error gone. But Now I am getting this error.
- error.PNG (14.79 KiB) Viewed 3371 times
- Restart failed.PNG (20.51 KiB) Viewed 3371 times
Looks like you are on an older version of Meteobridge. I remember this sort of bug at some point. I recommend a few different things to try in this order.
- Make sure your USB logger firmware is current.
- Try a newer version of Meteobridge than 3.6. Your upgrade license expired April 2019 and you should be able to run up to version 3.8 or 3.9 I think. There may be a bug in 3.6 for your particular setup.
- Try going the other way if 3.8 or 3.9 doesn't work with an earlier version than 3. 6 of Meteobridge (you'll sacrifice features). Maybe skip to next recommendation point if this doesn't produce results you want. I'm listing this for completeness, but I don't think it is a good option.
- Renew your Meteobridge license to give you the latest version and all bug fixes to date, including new features.
You can read about all the improvements and fixes since your 3.6 version here (currently up to version 4.4):
dmanandhar
- Fresh Boarder
Hi Admin,
I have updated meteobridge license license. But still getting error.
- Current Data.PNG (56.05 KiB) Viewed 3330 times
- updated.PNG (25.38 KiB) Viewed 3330 times
- error1.PNG (63.88 KiB) Viewed 3330 times
Your console is physically not connected or its data connector is hung-up.
1) Please check all cables, especially the logger sitting tight in the console.
2) When Meteobridge "Station" page shows a red cross in the Vantage USB line, then there is no USB connection. Check hub and hub connections.
3) when "Station" page shows a green mark for Vantage USB and errors keep on, then reset console. Depower console (including batteries), connect all cables again and power it up.
Last option is a HW defect of your USB hub or the USB port in your Meteobridge. But this is rarely the case...
dmanandhar
- Fresh Boarder
Hi admin,
I have checked all the usb ports to hub and usb hub to data logger connected securely. Tried 2, 3 times. Meteobridge "Station" page doesnot shows a red cross in the Vantage USB line.
Still not getting data in live data and also in weatherunderground.
In Min MAx data tab it shows historical data but not current data. Is that still mean usb not connected properly or the stations settings are not correct. I have attached the screenshot.
- Capture2.PNG (57.5 KiB) Viewed 3300 times
- Capture1.PNG (92.28 KiB) Viewed 3300 times
- Capture.PNG (69.92 KiB) Viewed 3300 times
have you checked remarks 1 und 3 of my previous post?
dmanandhar
- Fresh Boarder
Hi Admin,
I had checked 1 and 3 properly. But still getting this error. Please help me on this. Thanks
- Error.PNG (29.88 KiB) Viewed 3263 times
Can you please give me remote access (as explained in the FAQ) and send credentials to info(at)meteobridge.com.
Currently this looks like a HW problem (USB port of TP-Link, Cables, Data logger, Console) to me. It is not a SW issue as there are thousands of users out there using Meteobridge with a Davis Vantage.
dmanandhar
- Fresh Boarder
Hi Admin,
I am happy to give you remote access. I will be onsite on weekdays at 7 am to 4 pm Australian time. Which time is best suit for you.I have sent my credentials to info(at)meteobridge.com as well.
