I have been using meteobridge and Observer IP (Ambient) on TPLink TL-MR3020 for five years. The last update (with multi stations) has the station setup page drastically changed and eventhough Observer IP is featured in the dropdown (box not checked) it offers no possibility to enter IP address of the Observer IP.
Is this still Work in Progress with the multi station enhancement? can one roll back to something that works with the old Observer IP.
I use ethernet connection via router between IP Observer and TP with fixed IP.
Meteobridge 4.4 build 13737 - Observer IP.
Re: Meteobridge 4.4 build 13737 - Observer IP
Thanks for finding this bug. I just released a fixed version. Please reboot to have changes applied and give it another try.
Re: Meteobridge 4.4 build 13737 - Observer IP. **solved**
I also have the same problem with ObserverIP. Reload and now I can see the IP setting but the log shows connection refused.
My OberverIP is 192.168.4.71
- IMG_1955.jpg (466.98 KiB) Viewed 3910 times
SW Version: Meteobridge 4.4 (Sep 16 2020, build 3314), FW 1.3 ObserverIP still broken. Please fix this ASAP!
logger (16.09.2020 09:53:16): data logger (version 5.1d, build 3314) started.
logger (16.09.2020 09:53:16): station 0 (Observer-IP), error connect socket 192.168.5.45 (22): port 22222: Invalid argument
logger (16.09.2020 09:53:16): station 1 (Observer-IP), error connect socket 192.168.5.45 (22): port 22222: Invalid argument
logger (16.09.2020 09:53:20): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.09.2020 09:53:20): services paused.
logger (16.09.2020 09:53:46): station 0 (Observer-IP), error connect socket 192.168.5.45 (22): port 22222: Invalid argument
logger (16.09.2020 09:53:46): station 1 (Observer-IP), error connect socket 192.168.5.45 (22): port 22222: Invalid argument
logger (16.09.2020 09:54:16): station 0 (Observer-IP), error connect socket 192.168.5.45 (22): port 22222: Invalid argument
logger (16.09.2020 09:54:16): station 1 (Observer-IP), error connect socket 192.168.5.45 (22): port 22222: Invalid argument
Making progress as far as the setup screen (shows correct IP) but I am getting the same result as Kanok.
logger (16.09.2020 06:48:28): data logger (version 5.1d, build 13744) started.
logger (16.09.2020 06:48:29): station 0 (Observer-IP), error connect socket 192.168.1.99 (146): port 22222: Connection refused
logger (16.09.2020 06:48:32): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.09.2020 06:48:32): services paused.
logger (16.09.2020 06:48:59): station 0 (Observer-IP), error connect socket 192.168.1.99 (146): port 22222: Connection refused
logger (16.09.2020 06:49:59): message above repeats 2 times.
logger (16.09.2020 06:50:29): give up waiting for sensors after 120 secs.
logger (16.09.2020 06:50:29): services activated.
logger (16.09.2020 06:50:29): station 0 (Observer-IP), error connect socket 192.168.1.99 (146): port 22222: Connection refused
logger (16.09.2020 06:51:59): message above repeats 3 times.
- Screenshot 2020-09-16 065510.jpg (51.03 KiB) Viewed 3902 times
- Screenshot 2020-09-16 065602.jpg (78.42 KiB) Viewed 3902 times
The problem is that ObserverIP communicating over port 80 not 22222.
Please reboot to have just released fix applied.
Great! The connectivity issue has been fixed!
There is minor GUI issue right now.
Confirm the ObserverIP connection issue was fixed but GUI is all over the place.
- 9917A282-F3EA-4BF6-902F-4A7733C61B4E.jpeg (326.83 KiB) Viewed 3881 times
yep, I think it was not so smart to publish the new GUI code without attaching the correspondig css file. Is fixed by now. Please reboot.
