Re: Weather34 TEMPLATE
Looks like you have been busy. :D
Just noticed an odd thing with my September and 2020 Barometer Chart. I thought it might be a bad data point, but Ron's site is showing the same issue.
Here is a section of the 2020 data file.
Charts end of Day file that was updated yesterday?
Best wishes,
hmm this is why avoided meddling with the chart data for so long , what you will have todo unfortunately is edit/delete the line beggining/from 17 Sep .
I have pushed a fix but its a case of waiting till end of day to see if it works for you. failing this I will simply just revert back to original end of day charts file .sincerely apologize but been pestered for this feature for months and try to avoid it knowing full well how it can mess up If I get it wrong and I did . sometimes if aint broke don't fix it is too true..
weatherist34 wrote: Thu Sep 17, 2020 2:31 pm hmm this is why avoided meddling with the chart data for so long , what you will have todo unfortunately is edit/delete the line beggining/from 17 Sep .
No problem. I am assuming the last line should be 16 Sep data.
check your email corrected files sent .
weatherist34 wrote: Thu Sep 17, 2020 2:45 pm check your email corrected files sent .
I have the files and it's all fixed. I saw the new data points that were added. Charts look fine now! :D
Just let me know whenever you want to try IFTTT - I know these changes have been keeping you busy.
Thanks for the fast response!
I had hoped to work on it this week but all this Davis air quality sidetracked me and other requests so probably not this week now. did you update the file I pushed to GitHub ?
No problem. I just updated the latest end of day file.
ok chuck well i think that file has just about broke it so i will revert back to previous file until i have some real time to test all scenarios.sincerely apologize for this inconvenience. rule number 1 if aint broke dont fix it..
No problem. I noticed it added a couple new 16 Sep, Lines of data, so I replaced them again with the one you sent.
ok chuck thanks for your help . i did push two files a short while ago , if you got those i can test it but you would need too edit or alternatively just wait till midnight and see what it produces as im generally just getting up around your midnight 6am ish my time so i can see what happens. it looks ok runs ok locally but you never know. all it simply has two new values for uv and solar for month and year charts if all works well ill compile the two additional charts.
I did update the 2 latest files and uploaded the edited files you sent.
So, anything you want to try is fine. I can always upload again, if needed.
ok I just ran it on your server from here it worked as expected :-) you will need to just delete or reupload the two files I sent via email earlier.
below show the new values of max UV and max Solar
16 Sep,26.0,19.4,23.4,16.7,15.2,10.1,1.0,24.0,1019.3,1014.1,6.2,816.0
16 Sep,26.3,24.0,25.0,22.7,6.1,9.4,0.3,26.0,1014.5,1008.9,1.9,272.0 .
so at midnight it should do as expected . theoretically :-)
I will release and update for all in the morning ..once again thanks for your help..Brian
Ok. Glad to help.
I will overwrite the files.
Take care,
good morning i released a critical fix in the simple update file 18-09-2020 . big thanks to chuck for choosing GITHUB it really does provide a good platform for eradicating and finding problems quick.
if you have a broken month, year chart which is most likely if you ran the update 17-09-2020 please contact me via email i will happily fix your charts .
sincere apologies for the inconvenience.
update this morning gives the option for those who own a uv sensor , solar sensor to have month and year charts for these two sensors .
Brian
Looks like everything is working fine :D
