Re: Weather34 TEMPLATE
oh dear to be honest i wish i could just remove translations altogether they are the biggest obstacle and challenging, i have no understanding of any language apart from turkish and my native english.. will look at it later
just download the update file again it should be ok now .
xray77
Post by xray77 »
...i would have no problem with a pure english site.. :-) But other users wouldn't like that, I guess. But now enjoy the weekend!
regards
Mike
The language support is already 98% very good, I think the remaining 2% is just a difficult matter, but that's no problem if it doesn't fit right away.
Is it possible to display in the dayforecast.php the expected daily amount in mm instead of the rain probability in percent. What do you think?
I just say thanks again
Torsten
xray77 wrote: Fri Sep 25, 2020 8:51 pm ...i would have no problem with a pure english site.. :-) But other users wouldn't like that, I guess. But now enjoy the weekend!
regards
Mike
@xray77
Thank you very much for taking the time to apply your idea to all translated files that is certainly a rare occurrence .the template update file was just updated for all translation files.
(2nd Update for 26th September 11:31 GMT)
* All translations updated kindly by Mike(xray77)
* Adds translation to new SUN-UV module
* Minor changes to UV and Air Qulaity modules
* Adds new Sun Position with UVINDEX module
* Adds new Sun Position module design
* Adds new setup option for Sun Position modules
ToTo wrote: Sat Sep 26, 2020 8:10 am The language support is already 98% very good, I think the remaining 2% is just a difficult matter, but that's no problem if it doesn't fit right away.
Torsten
no problem perhaps in a couple of weeks I have other things to get done but I will take a look . for reference the values for accumulation in the forecast are not to good or just a typical relative indication hence I went for the chance probability .however that said why not just have a simple what if scenario if forecast accumulation value is >0 then show accumulated value else show probability ? 20-30% often produces a light rain probability which doesn't always produce a worthy accumulation value.. i.e light drizzle. anyway food for thought for later...thanks for the idea..Brian
Hope all is well. I just noticed a small alignment issue on the Indoor module - Sun.
Seems to show up in all browsers that I have tried.
Take care,
I could not reproduce this locally so I just pushed the indoor css files perhaps I forgot ?
I updated the update file for the third time today basically refines the uv sun module and minor fix for sunrise/set Southern Hemisphere (down under)..
so it should look like this . I must go now catch up hopefully towards end of week..have a safe week all..
many thanks for the all the emails, feedback take each idea at a time all will come good where possible.
Brian
Looks like that fixed it!
woolfg
Post by woolfg »
Hi Chuck
I just wondered why your Purple Air shows data in the VOC whereas mine doesnt - I assume we have the same hardware
Yours
Mine
Have you made some specific code change to show that
Kind Regards
Graham
Hi Graham,
A few months ago the guys (Adrian) at Purple Air started selling an add on chip/board - BME680 for VOC. You can pop into the original unit. I think they are currently calling it experimental. I am not sure how many have been deployed, but Brian added the API data point to the template. I suspect it may be standard in future Purple Air devices.
I think Simon (conligwx) has one, as well.
woolfg
Post by woolfg »
Hi Chuck
Ok sounds like a fun project - Ill do some research
Many thanks
Graham
28-09-2020 update file contains most of the stuff done last week that wasn't uploaded .
new modules based on uvindex module now has the options for those who do not own a UV Sensor/Solar Sensor.
the module with the moon phase will come later next weekend need to make sure users do not run the small moonphase module alongside the option new redesigned sun position with moonphase. this will break the template so need to come up with a solution because I know some will try :-) .
(28th September 00:01 GMT)
* Rework Smart tv to use master css file
* Rework indoor screen layout
* Adds Humidity reading to indoor indicator bar
* Spanish / Catalan Languages updated (Ref Josep)
* Redesign Sun Position module design to match new UV sun module
* Minor fix for sunrise/set
* Adds better translation to new SUN-UV module
ps I have answered all requests for download password those that did not receive a response you have provided a invalid url or it is not reachable here in Istanbul (blocked) .FWIW I don't collect URLS all it does it shows me you are using a meteobridge device not some other software , it will save you a lot of time and myself because this template is strictly only compatible with meteobridge software . Brian..
Just loaded the new update - thanks. I don't know whether you decided to eliminate the choices for the bottom 3 modules on the Almanac page or it was an oversight. It looks like they are now static - regardless of the chosen option in setup. Noticed that the Fire risk module was gone.
Edit: I took a second look and I see that you did remove the choices from 10a, 11a and 12a from the updater-almanac file.
Best wishes,
good afternoon
todays update 29-09-2020 contains Catalan/Danish language updates from Josep/Bjarne
new sun combined with moon phase optional module (**do not run the newer sun-moon option with the small moon phase module on same page)
new setup options to select which sun module you wish to use 3 options available see screenshot below
weather34-sun-moon.php(sun moon combined)
weather34-sun.php (sun position and sun related data)
weather34-uv-sun.php (sun combined with uvindex and solar radiation data for owners with capable sensors)
**all Air Quality Davis related is completely on hold no further development expected anytime soon until I receive delivery..sorry for the inconvenience..
