Child process termination signal. **solved**
mthiessen
Post by mthiessen »
My NanoSD seems to stop sending data once a day over the last few days. You were able to remotely connect and fix something in the past. In the log below you will see I did a backup at 03.10.2020 23:31:06. 10 hours later a "child process terminations signal" which repeats.
I'm running the latest version. If I reboot then it runs fine for a while.
Platform: Meteobridge NANO SD (ambientweather Version)
RAM: 125 MB total, 44 MB free (64% used)
Storage: swissbit SLC, 1826 MB total, 1756 MB free (4% used)
SW Version: Meteobridge 4.4 (Oct 3 2020, build 3440), FW 1.3
Uptime: 19 hours, 47 minutes Buffer: 1000 items (100%)
database (03.10.2020 07:40:52): process started.
database (03.10.2020 07:40:52): Content of RAM database restored.
wnetd  (03.10.2020 07:40:57): process started.
system (03.10.2020 07:40:57): start of logging process initiated.
wnetd  (03.10.2020 07:40:57): send data thread started (pid:1932 tid:1933)
logger (03.10.2020 07:40:58): databases connected. Update interval 3600 seconds.
logger (03.10.2020 07:40:58): data logger (version 5.1d, build 3440) started.
logger (03.10.2020 07:41:00): connect station 0 (Vantage via serial).
logger (03.10.2020 07:41:00): connect station 9 (System Data via Plug-in).
logger (03.10.2020 07:41:00): station 0 (Vantage), wakeup sent.
logger (03.10.2020 07:41:03): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.10.2020 07:41:03): services paused.
logger (03.10.2020 07:41:04): station 0 (Vantage), no need to update console date/time.
logger (03.10.2020 07:41:04): station 0 (Vantage), setup script executed.
logger (03.10.2020 07:41:04): station 0 (Vantage), internal logger activated.
logger (03.10.2020 07:41:04): station 0 (Vantage), syncing.
database (03.10.2020 07:41:10): database sync done (31 tables, 102/2511 writes).
logger (03.10.2020 07:41:14): station 0 (Vantage), gettime request sent.
logger (03.10.2020 07:41:14): station 0 (Vantage), no Vantage time offset.
logger (03.10.2020 07:41:14): station 0 (Vantage), eeprom request sent.
logger (03.10.2020 07:41:14): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (03.10.2020 07:41:14): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (03.10.2020 07:41:14): station 0 (Vantage), firmware version request sent.
logger (03.10.2020 07:41:14): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (03.10.2020 07:41:14): station 0 (Vantage), no reading of Vantage's internal logger.
logger (03.10.2020 07:41:19): sensors are now providing data.
logger (03.10.2020 07:41:19): services started.
system (03.10.2020 07:56:33): Access point operation disabled 1062 secs after boot.
backup (03.10.2020 13:48:13): backup media size is 1.8G (1.7G free).
backup (03.10.2020 13:49:28): backup completed: dbase-202010031348.gz (4.3M)
logger (03.10.2020 23:31:06): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA (8) < inetupload_getline < inetupload_getfilteredline < inetupload_getlineA (8) < inetupload_getline < inetupload_ge...
logger (03.10.2020 23:31:06): disconnect station 0 (Vantage): exit
logger (03.10.2020 23:31:06): disconnect station 9 (System Data): exit
logger (03.10.2020 23:31:07): databases connected. Update interval 3600 seconds.
logger (03.10.2020 23:31:07): data logger (version 5.1d, build 3440) started.
logger (03.10.2020 23:31:08): connect station 0 (Vantage via serial).
logger (03.10.2020 23:31:08): connect station 9 (System Data via Plug-in).
logger (03.10.2020 23:31:08): station 0 (Vantage), wakeup sent.
logger (03.10.2020 23:31:11): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.10.2020 23:31:11): services paused.
logger (03.10.2020 23:31:12): station 0 (Vantage), no need to update console date/time.
logger (03.10.2020 23:31:12): station 0 (Vantage), setup script executed.
logger (03.10.2020 23:31:12): station 0 (Vantage), internal logger activated.
logger (03.10.2020 23:31:12): station 0 (Vantage), syncing.
logger (03.10.2020 23:31:22): station 0 (Vantage), gettime request sent.
logger (03.10.2020 23:31:22): station 0 (Vantage), no Vantage time offset.
logger (03.10.2020 23:31:22): station 0 (Vantage), eeprom request sent.
logger (03.10.2020 23:31:22): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (03.10.2020 23:31:22): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (03.10.2020 23:31:22): station 0 (Vantage), firmware version request sent.
logger (03.10.2020 23:31:22): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (03.10.2020 23:31:22): station 0 (Vantage), no reading of Vantage's internal logger.
logger (03.10.2020 23:31:26): sensors are now providing data.
logger (03.10.2020 23:31:26): services started.
logger (03.10.2020 23:51:13): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (8) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get...
logger (03.10.2020 23:51:13): disconnect station 0 (Vantage): exit
logger (03.10.2020 23:51:13): disconnect station 9 (System Data): exit
logger (03.10.2020 23:51:14): databases connected. Update interval 3600 seconds.
logger (03.10.2020 23:51:14): data logger (version 5.1d, build 3440) started.
logger (03.10.2020 23:51:15): connect station 0 (Vantage via serial).
logger (03.10.2020 23:51:15): connect station 9 (System Data via Plug-in).
logger (03.10.2020 23:51:15): station 0 (Vantage), wakeup sent.
logger (03.10.2020 23:51:18): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.10.2020 23:51:18): services paused.
logger (03.10.2020 23:51:19): station 0 (Vantage), no need to update console date/time.
logger (03.10.2020 23:51:19): station 0 (Vantage), setup script executed.
logger (03.10.2020 23:51:19): station 0 (Vantage), internal logger activated.
logger (03.10.2020 23:51:19): station 0 (Vantage), syncing.
logger (03.10.2020 23:51:29): station 0 (Vantage), gettime request sent.
logger (03.10.2020 23:51:29): station 0 (Vantage), no Vantage time offset.
logger (03.10.2020 23:51:29): station 0 (Vantage), eeprom request sent.
logger (03.10.2020 23:51:29): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (03.10.2020 23:51:29): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (03.10.2020 23:51:29): station 0 (Vantage), firmware version request sent.
logger (03.10.2020 23:51:29): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (03.10.2020 23:51:29): station 0 (Vantage), no reading of Vantage's internal logger.
logger (03.10.2020 23:51:34): sensors are now providing data.
logger (03.10.2020 23:51:34): services started.
logger (04.10.2020 00:11:20): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getli...
logger (04.10.2020 00:11:20): disconnect station 0 (Vantage): exit
logger (04.10.2020 00:11:20): disconnect station 9 (System Data): exit
logger (04.10.2020 00:11:21): databases connected. Update interval 3600 seconds.
logger (04.10.2020 00:11:21): data logger (version 5.1d, build 3440) started.
logger (04.10.2020 00:11:22): connect station 0 (Vantage via serial).
logger (04.10.2020 00:11:22): connect station 9 (System Data via Plug-in).
logger (04.10.2020 00:11:22): station 0 (Vantage), wakeup sent.
logger (04.10.2020 00:11:25): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.10.2020 00:11:25): services paused.
logger (04.10.2020 00:11:26): station 0 (Vantage), no need to update console date/time.
logger (04.10.2020 00:11:26): station 0 (Vantage), setup script executed.
logger (04.10.2020 00:11:26): station 0 (Vantage), internal logger activated.
logger (04.10.2020 00:11:26): station 0 (Vantage), syncing.
logger (04.10.2020 00:11:36): station 0 (Vantage), gettime request sent.
logger (04.10.2020 00:11:36): station 0 (Vantage), no Vantage time offset.
logger (04.10.2020 00:11:36): station 0 (Vantage), eeprom request sent.
logger (04.10.2020 00:11:36): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (04.10.2020 00:11:36): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (04.10.2020 00:11:36): station 0 (Vantage), firmware version request sent.
logger (04.10.2020 00:11:36): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (04.10.2020 00:11:36): station 0 (Vantage), no reading of Vantage's internal logger.
logger (04.10.2020 00:11:41): sensors are now providing data.
logger (04.10.2020 00:11:41): services started.
logger (04.10.2020 00:31:27): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get...
logger (04.10.2020 00:31:27): disconnect station 0 (Vantage): exit
logger (04.10.2020 00:31:27): disconnect station 9 (System Data): exit
logger (04.10.2020 00:31:28): databases connected. Update interval 3600 seconds.
logger (04.10.2020 00:31:28): data logger (version 5.1d, build 3440) started.
logger (04.10.2020 00:31:29): connect station 0 (Vantage via serial).
logger (04.10.2020 00:31:29): connect station 9 (System Data via Plug-in).
logger (04.10.2020 00:31:29): station 0 (Vantage), wakeup sent.
logger (04.10.2020 00:31:32): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.10.2020 00:31:32): services paused.
logger (04.10.2020 00:31:33): station 0 (Vantage), no need to update console date/time.
logger (04.10.2020 00:31:33): station 0 (Vantage), setup script executed.
logger (04.10.2020 00:31:33): station 0 (Vantage), internal logger activated.
logger (04.10.2020 00:31:33): station 0 (Vantage), syncing.
logger (04.10.2020 00:31:43): station 0 (Vantage), gettime request sent.
logger (04.10.2020 00:31:43): station 0 (Vantage), no Vantage time offset.
logger (04.10.2020 00:31:43): station 0 (Vantage), eeprom request sent.
logger (04.10.2020 00:31:43): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (04.10.2020 00:31:43): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (04.10.2020 00:31:43): station 0 (Vantage), firmware version request sent.
logger (04.10.2020 00:31:43): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (04.10.2020 00:31:43): station 0 (Vantage), no reading of Vantage's internal logger.
logger (04.10.2020 00:31:47): sensors are now providing data.
logger (04.10.2020 00:31:47): services started.
logger (04.10.2020 01:02:03): child process received timeout signal (14).
logger (04.10.2020 01:02:03): disconnect station 0 (Vantage): exit
logger (04.10.2020 01:02:03): disconnect station 9 (System Data): exit
xray77
Re: Child process termination signal
Post by xray77 »
Hello mthiessen,
see post viewtopic.php?f=56&t=15174
same issue but dissipated byself.. :-)
I can see from the log that it has something to do with the upload to meteoplug.com.
Meteobridge recovers from this by starting the data logging process again, but the root cause should be eliminated.
I just changed something in the code. Please reboot and give this a try and report back.
mthiessen
Post by mthiessen »
I woke up this morning and NanoSD wasn't sending data and same "termination signal 11". I rebooted as you suggested and everything came back online using build 3461.
I'll let you know how it goes. If it breaks is usually within the next 24 hours.
Thank you.
Please send logging protocol, as I added a bit more detailed information there.
mthiessen
Post by mthiessen »
Same thing happened again. With build 3461
Here is log.
I rebooted to get it back online.
wnetd  (05.10.2020 01:30:44): send data thread started (pid:1931 tid:1933)
logger (05.10.2020 01:30:45): databases connected. Update interval 3600 seconds.
logger (05.10.2020 01:30:45): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 01:30:46): connect station 0 (Vantage via serial).
logger (05.10.2020 01:30:46): connect station 9 (System Data via Plug-in).
logger (05.10.2020 01:30:46): station 0 (Vantage), wakeup sent.
logger (05.10.2020 01:30:49): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.10.2020 01:30:49): services paused.
logger (05.10.2020 01:30:50): station 0 (Vantage), no need to update console date/time.
logger (05.10.2020 01:30:50): station 0 (Vantage), setup script executed.
logger (05.10.2020 01:30:50): station 0 (Vantage), internal logger activated.
logger (05.10.2020 01:30:51): station 0 (Vantage), syncing.
database (05.10.2020 01:30:55): database sync done (31 tables, 90/2201 writes).
logger (05.10.2020 01:31:01): station 0 (Vantage), gettime request sent.
logger (05.10.2020 01:31:01): station 0 (Vantage), no Vantage time offset.
logger (05.10.2020 01:31:01): station 0 (Vantage), eeprom request sent.
logger (05.10.2020 01:31:01): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.10.2020 01:31:01): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.10.2020 01:31:01): station 0 (Vantage), firmware version request sent.
logger (05.10.2020 01:31:01): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (05.10.2020 01:31:01): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.10.2020 01:31:07): sensors are now providing data.
logger (05.10.2020 01:31:07): services started.
system (05.10.2020 01:45:57): Access point operation disabled 1023 secs after boot.
logger (05.10.2020 22:10:51): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA (8) < inetupload_getline < inetupload_getlin...
logger (05.10.2020 22:10:51): disconnect station 0 (Vantage): exit
logger (05.10.2020 22:10:51): databases connected. Update interval 3600 seconds.
logger (05.10.2020 22:10:51): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 22:10:52): connect station 0 (Vantage via serial).
logger (05.10.2020 22:10:52): connect station 9 (System Data via Plug-in).
logger (05.10.2020 22:10:52): station 0 (Vantage), wakeup sent.
logger (05.10.2020 22:10:55): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.10.2020 22:10:55): services paused.
logger (05.10.2020 22:10:55): station 0 (Vantage), no need to update console date/time.
logger (05.10.2020 22:10:56): station 0 (Vantage), setup script executed.
logger (05.10.2020 22:10:56): station 0 (Vantage), internal logger activated.
logger (05.10.2020 22:10:56): station 0 (Vantage), syncing.
logger (05.10.2020 22:11:06): station 0 (Vantage), gettime request sent.
logger (05.10.2020 22:11:06): station 0 (Vantage), no Vantage time offset.
logger (05.10.2020 22:11:06): station 0 (Vantage), eeprom request sent.
logger (05.10.2020 22:11:06): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.10.2020 22:11:06): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.10.2020 22:11:06): station 0 (Vantage), firmware version request sent.
logger (05.10.2020 22:11:06): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (05.10.2020 22:11:06): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.10.2020 22:11:11): sensors are now providing data.
logger (05.10.2020 22:11:11): services started.
logger (05.10.2020 22:30:57): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLO...
logger (05.10.2020 22:30:57): disconnect station 0 (Vantage): exit
logger (05.10.2020 22:30:57): disconnect station 9 (System Data): exit
logger (05.10.2020 22:30:58): databases connected. Update interval 3600 seconds.
logger (05.10.2020 22:30:58): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 22:30:59): connect station 0 (Vantage via serial).
logger (05.10.2020 22:30:59): connect station 9 (System Data via Plug-in).
logger (05.10.2020 22:30:59): station 0 (Vantage), wakeup sent.
logger (05.10.2020 22:31:00): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.10.2020 22:31:00): services paused.
logger (05.10.2020 22:31:03): station 0 (Vantage), no need to update console date/time.
logger (05.10.2020 22:31:03): station 0 (Vantage), setup script executed.
logger (05.10.2020 22:31:03): station 0 (Vantage), internal logger activated.
logger (05.10.2020 22:31:03): station 0 (Vantage), syncing.
logger (05.10.2020 22:31:13): station 0 (Vantage), gettime request sent.
logger (05.10.2020 22:31:13): station 0 (Vantage), no Vantage time offset.
logger (05.10.2020 22:31:13): station 0 (Vantage), eeprom request sent.
logger (05.10.2020 22:31:13): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.10.2020 22:31:13): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.10.2020 22:31:13): station 0 (Vantage), firmware version request sent.
logger (05.10.2020 22:31:13): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (05.10.2020 22:31:13): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.10.2020 22:31:17): sensors are now providing data.
logger (05.10.2020 22:31:17): services started.
logger (05.10.2020 22:51:04): databases connected. Update interval 3600 seconds.
logger (05.10.2020 22:51:04): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 22:51:04): error (22) while doing bind (port 22222): Invalid argument
logger (05.10.2020 22:51:04): killed process "17732/sh" listening to port 5553.
logger (05.10.2020 22:51:04): killed process "17733/meteosys" listening to port 5551.
logger (05.10.2020 22:51:07): data logger stopped.
logger (05.10.2020 22:51:07): databases disconnected.
logger (05.10.2020 22:51:07): parent process to be terminated.
logger (05.10.2020 22:51:34): databases connected. Update interval 3600 seconds.
logger (05.10.2020 22:51:34): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 22:51:35): connect station 0 (Vantage via serial).
logger (05.10.2020 22:51:35): connect station 9 (System Data via Plug-in).
logger (05.10.2020 22:51:35): station 0 (Vantage), wakeup sent.
logger (05.10.2020 22:51:38): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.10.2020 22:51:38): services paused.
logger (05.10.2020 22:51:38): station 0 (Vantage), no need to update console date/time.
logger (05.10.2020 22:51:39): station 0 (Vantage), setup script executed.
logger (05.10.2020 22:51:39): station 0 (Vantage), internal logger activated.
logger (05.10.2020 22:51:39): station 0 (Vantage), syncing.
logger (05.10.2020 22:51:49): station 0 (Vantage), gettime request sent.
logger (05.10.2020 22:51:49): station 0 (Vantage), no Vantage time offset.
logger (05.10.2020 22:51:49): station 0 (Vantage), eeprom request sent.
logger (05.10.2020 22:51:49): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.10.2020 22:51:49): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.10.2020 22:51:49): station 0 (Vantage), firmware version request sent.
logger (05.10.2020 22:51:49): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (05.10.2020 22:51:49): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.10.2020 22:51:53): sensors are now providing data.
logger (05.10.2020 22:51:53): services started.
logger (05.10.2020 23:11:40): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get...
logger (05.10.2020 23:11:40): disconnect station 0 (Vantage): exit
logger (05.10.2020 23:11:40): disconnect station 9 (System Data): exit
logger (05.10.2020 23:11:41): databases connected. Update interval 3600 seconds.
logger (05.10.2020 23:11:41): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 23:11:42): connect station 0 (Vantage via serial).
logger (05.10.2020 23:11:42): connect station 9 (System Data via Plug-in).
logger (05.10.2020 23:11:42): station 0 (Vantage), wakeup sent.
logger (05.10.2020 23:11:45): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.10.2020 23:11:45): services paused.
logger (05.10.2020 23:11:46): station 0 (Vantage), no need to update console date/time.
logger (05.10.2020 23:11:46): station 0 (Vantage), setup script executed.
logger (05.10.2020 23:11:46): station 0 (Vantage), internal logger activated.
logger (05.10.2020 23:11:46): station 0 (Vantage), syncing.
logger (05.10.2020 23:11:56): station 0 (Vantage), gettime request sent.
logger (05.10.2020 23:11:56): station 0 (Vantage), no Vantage time offset.
logger (05.10.2020 23:11:56): station 0 (Vantage), eeprom request sent.
logger (05.10.2020 23:11:56): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.10.2020 23:11:56): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.10.2020 23:11:56): station 0 (Vantage), firmware version request sent.
logger (05.10.2020 23:11:56): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (05.10.2020 23:11:56): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.10.2020 23:12:01): sensors are now providing data.
logger (05.10.2020 23:12:01): services started.
logger (05.10.2020 23:31:47): error writing logged data to pipe "gzip >/var/run/meteohub/inetupload.z": Invalid argument
logger (05.10.2020 23:31:47): child process received termination signal (11) in functions: termination_handler < gen_INETUPLOADTS < get_prevsend < inetupload_getlineA8b < gen_INETUPLOADFN < inetupload_getlineA (7) < inetupload_getline < inetupload_getlineA (3) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < gene...
logger (05.10.2020 23:31:47): disconnect station 0 (Vantage): exit
logger (05.10.2020 23:31:47): disconnect station 9 (System Data): exit
logger (05.10.2020 23:31:50): data logger stopped.
logger (05.10.2020 23:31:50): databases disconnected.
logger (05.10.2020 23:31:50): parent process to be terminated.
logger (05.10.2020 23:31:50): databases connected. Update interval 3600 seconds.
logger (05.10.2020 23:31:50): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 23:31:51): connect station 0 (Vantage via serial).
logger (05.10.2020 23:31:51): connect station 9 (System Data via Plug-in).
logger (05.10.2020 23:31:51): station 0 (Vantage), wakeup sent.
logger (05.10.2020 23:31:54): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.10.2020 23:31:54): services paused.
logger (05.10.2020 23:31:54): station 0 (Vantage), no need to update console date/time.
logger (05.10.2020 23:31:55): station 0 (Vantage), setup script executed.
logger (05.10.2020 23:31:55): station 0 (Vantage), internal logger activated.
logger (05.10.2020 23:31:55): station 0 (Vantage), syncing.
logger (05.10.2020 23:32:05): station 0 (Vantage), gettime request sent.
logger (05.10.2020 23:32:05): station 0 (Vantage), no Vantage time offset.
logger (05.10.2020 23:32:05): station 0 (Vantage), eeprom request sent.
logger (05.10.2020 23:32:05): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.10.2020 23:32:05): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.10.2020 23:32:05): station 0 (Vantage), firmware version request sent.
logger (05.10.2020 23:32:05): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (05.10.2020 23:32:05): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.10.2020 23:32:09): sensors are now providing data.
logger (05.10.2020 23:32:09): services started.
logger (05.10.2020 23:51:56): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get...
logger (05.10.2020 23:51:56): disconnect station 0 (Vantage): exit
logger (05.10.2020 23:51:56): disconnect station 9 (System Data): exit
logger (05.10.2020 23:51:57): databases connected. Update interval 3600 seconds.
logger (05.10.2020 23:51:57): data logger (version 5.1d, build 3461) started.
logger (05.10.2020 23:51:58): connect station 0 (Vantage via serial).
logger (05.10.2020 23:51:58): connect station 9 (System Data via Plug-in).
logger (05.10.2020 23:51:58): station 0 (Vantage), wakeup sent.
logger (05.10.2020 23:52:00): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.10.2020 23:52:00): services paused.
logger (05.10.2020 23:52:01): station 0 (Vantage), no need to update console date/time.
logger (05.10.2020 23:52:02): station 0 (Vantage), setup script executed.
logger (05.10.2020 23:52:02): station 0 (Vantage), internal logger activated.
logger (05.10.2020 23:52:02): station 0 (Vantage), syncing.
logger (05.10.2020 23:52:12): station 0 (Vantage), gettime request sent.
logger (05.10.2020 23:52:12): station 0 (Vantage), no Vantage time offset.
logger (05.10.2020 23:52:12): station 0 (Vantage), eeprom request sent.
logger (05.10.2020 23:52:12): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.10.2020 23:52:12): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.10.2020 23:52:12): station 0 (Vantage), firmware version request sent.
logger (05.10.2020 23:52:12): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (05.10.2020 23:52:12): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.10.2020 23:52:17): sensors are now providing data.
logger (05.10.2020 23:52:17): services started.
logger (06.10.2020 00:12:03): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get...
logger (06.10.2020 00:12:03): disconnect station 0 (Vantage): exit
logger (06.10.2020 00:12:03): disconnect station 9 (System Data): exit
logger (06.10.2020 00:12:04): databases connected. Update interval 3600 seconds.
logger (06.10.2020 00:12:04): data logger (version 5.1d, build 3461) started.
logger (06.10.2020 00:12:05): connect station 0 (Vantage via serial).
logger (06.10.2020 00:12:05): connect station 9 (System Data via Plug-in).
logger (06.10.2020 00:12:05): station 0 (Vantage), wakeup sent.
logger (06.10.2020 00:12:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.10.2020 00:12:08): services paused.
logger (06.10.2020 00:12:08): station 0 (Vantage), no need to update console date/time.
logger (06.10.2020 00:12:09): station 0 (Vantage), setup script executed.
logger (06.10.2020 00:12:09): station 0 (Vantage), internal logger activated.
logger (06.10.2020 00:12:09): station 0 (Vantage), syncing.
logger (06.10.2020 00:12:19): station 0 (Vantage), gettime request sent.
logger (06.10.2020 00:12:19): station 0 (Vantage), no Vantage time offset.
logger (06.10.2020 00:12:19): station 0 (Vantage), eeprom request sent.
logger (06.10.2020 00:12:19): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (06.10.2020 00:12:19): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (06.10.2020 00:12:19): station 0 (Vantage), firmware version request sent.
logger (06.10.2020 00:12:19): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (06.10.2020 00:12:19): station 0 (Vantage), no reading of Vantage's internal logger.
logger (06.10.2020 00:12:25): sensors are now providing data.
logger (06.10.2020 00:12:25): services started.
xray77
Post by xray77 »
Hello mthiessen,
..hope, you hav'nt activate the automatic update function on reboot..
see viewtopic.php?f=61&t=15186
regards
Mike
mthiessen
Post by mthiessen »
I do have automatic update on reboot set up.
You can see from the chart here that it goes offline around 9pm each night.
https://www.wunderground.com/dashboard/ ... 0-1/weekly
Look at the daily chart from Oct 1 going forward. You can see where it stops sending data.
https://www.wunderground.com/dashboard/ ... 10-1/daily
Things should now be fine again.
mthiessen
Post by mthiessen »
Build 3470 installed. I'll let you know if there are problems.
mthiessen
Post by mthiessen »
It went offline again. Build 3470.
Here is log
database (06.10.2020 13:51:21): process started.
database (06.10.2020 13:51:22): Content of RAM database restored.
wnetd  (06.10.2020 13:51:25): process started.
system (06.10.2020 13:51:25): start of logging process initiated.
wnetd  (06.10.2020 13:51:25): send data thread started (pid:1906 tid:1907)
logger (06.10.2020 13:51:26): databases connected. Update interval 3600 seconds.
logger (06.10.2020 13:51:26): data logger (version 5.1d, build 3470) started.
logger (06.10.2020 13:51:27): connect station 0 (Vantage via serial).
logger (06.10.2020 13:51:27): connect station 9 (System Data via Plug-in).
logger (06.10.2020 13:51:28): station 0 (Vantage), wakeup sent.
logger (06.10.2020 13:51:31): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.10.2020 13:51:31): services paused.
logger (06.10.2020 13:51:31): station 0 (Vantage), no need to update console date/time.
logger (06.10.2020 13:51:32): station 0 (Vantage), setup script executed.
logger (06.10.2020 13:51:32): station 0 (Vantage), internal logger activated.
logger (06.10.2020 13:51:32): station 0 (Vantage), syncing.
database (06.10.2020 13:51:38): database sync done (31 tables, 101/2418 writes).
logger (06.10.2020 13:51:42): station 0 (Vantage), gettime request sent.
logger (06.10.2020 13:51:42): station 0 (Vantage), no Vantage time offset.
logger (06.10.2020 13:51:42): station 0 (Vantage), eeprom request sent.
logger (06.10.2020 13:51:42): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (06.10.2020 13:51:42): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (06.10.2020 13:51:42): station 0 (Vantage), firmware version request sent.
logger (06.10.2020 13:51:42): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (06.10.2020 13:51:42): station 0 (Vantage), no reading of Vantage's internal logger.
logger (06.10.2020 13:51:46): sensors are now providing data.
logger (06.10.2020 13:51:46): services started.
system (06.10.2020 14:05:52): Access point operation disabled 981 secs after boot.
system (07.10.2020 03:31:33): Disconnected from WLAN or Internet, reconnect issued.
system (07.10.2020 03:31:40): Access point operation temporarily enabled.
system (07.10.2020 03:35:19): Access point operation disabled 49548 secs after boot.
logger (07.10.2020 22:11:40): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 (8503552) < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a1 (8503552) < inetupload_getlineA8a0 (8503552) < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a1 (850355...
logger (07.10.2020 22:11:40): disconnect station 0 (Vantage): exit
logger (07.10.2020 22:11:40): disconnect station 9 (System Data): exit
logger (07.10.2020 22:11:41): databases connected. Update interval 3600 seconds.
logger (07.10.2020 22:11:41): data logger (version 5.1d, build 3470) started.
logger (07.10.2020 22:11:42): connect station 0 (Vantage via serial).
logger (07.10.2020 22:11:42): connect station 9 (System Data via Plug-in).
logger (07.10.2020 22:11:42): station 0 (Vantage), wakeup sent.
logger (07.10.2020 22:11:45): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (07.10.2020 22:11:45): services paused.
logger (07.10.2020 22:11:46): station 0 (Vantage), no need to update console date/time.
logger (07.10.2020 22:11:46): station 0 (Vantage), setup script executed.
logger (07.10.2020 22:11:46): station 0 (Vantage), internal logger activated.
logger (07.10.2020 22:11:47): station 0 (Vantage), syncing.
logger (07.10.2020 22:11:57): station 0 (Vantage), gettime request sent.
logger (07.10.2020 22:11:57): station 0 (Vantage), no Vantage time offset.
logger (07.10.2020 22:11:57): station 0 (Vantage), eeprom request sent.
logger (07.10.2020 22:11:57): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (07.10.2020 22:11:57): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (07.10.2020 22:11:57): station 0 (Vantage), firmware version request sent.
logger (07.10.2020 22:11:57): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (07.10.2020 22:11:57): station 0 (Vantage), no reading of Vantage's internal logger.
logger (07.10.2020 22:12:01): sensors are now providing data.
logger (07.10.2020 22:12:01): services started.
logger (07.10.2020 22:31:47): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 (8662192) < inetupload_getlineA (8) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid ...
logger (07.10.2020 22:31:47): disconnect station 0 (Vantage): exit
logger (07.10.2020 22:31:47): disconnect station 9 (System Data): exit
logger (07.10.2020 22:31:48): databases connected. Update interval 3600 seconds.
logger (07.10.2020 22:31:48): data logger (version 5.1d, build 3470) started.
logger (07.10.2020 22:31:50): connect station 0 (Vantage via serial).
logger (07.10.2020 22:31:50): connect station 9 (System Data via Plug-in).
logger (07.10.2020 22:31:50): station 0 (Vantage), wakeup sent.
logger (07.10.2020 22:31:53): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (07.10.2020 22:31:53): services paused.
logger (07.10.2020 22:31:54): station 0 (Vantage), no need to update console date/time.
logger (07.10.2020 22:31:54): station 0 (Vantage), setup script executed.
logger (07.10.2020 22:31:54): station 0 (Vantage), internal logger activated.
logger (07.10.2020 22:31:54): station 0 (Vantage), syncing.
logger (07.10.2020 22:32:04): station 0 (Vantage), gettime request sent.
logger (07.10.2020 22:32:04): station 0 (Vantage), no Vantage time offset.
logger (07.10.2020 22:32:04): station 0 (Vantage), eeprom request sent.
logger (07.10.2020 22:32:04): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (07.10.2020 22:32:04): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (07.10.2020 22:32:04): station 0 (Vantage), firmware version request sent.
logger (07.10.2020 22:32:04): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (07.10.2020 22:32:04): station 0 (Vantage), no reading of Vantage's internal logger.
logger (07.10.2020 22:32:09): sensors are now providing data.
logger (07.10.2020 22:32:09): services started.
logger (07.10.2020 22:51:56): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 (8457152) < inetupload_getlineA (8) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid ...
logger (07.10.2020 22:51:56): disconnect station 0 (Vantage): exit
logger (07.10.2020 22:51:56): disconnect station 9 (System Data): exit
logger (07.10.2020 22:51:57): databases connected. Update interval 3600 seconds.
logger (07.10.2020 22:51:57): data logger (version 5.1d, build 3470) started.
logger (07.10.2020 22:51:58): connect station 0 (Vantage via serial).
logger (07.10.2020 22:51:58): connect station 9 (System Data via Plug-in).
logger (07.10.2020 22:51:58): station 0 (Vantage), wakeup sent.
logger (07.10.2020 22:52:00): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (07.10.2020 22:52:00): services paused.
logger (07.10.2020 22:52:01): station 0 (Vantage), no need to update console date/time.
logger (07.10.2020 22:52:02): station 0 (Vantage), setup script executed.
logger (07.10.2020 22:52:02): station 0 (Vantage), internal logger activated.
logger (07.10.2020 22:52:02): station 0 (Vantage), syncing.
logger (07.10.2020 22:52:12): station 0 (Vantage), gettime request sent.
logger (07.10.2020 22:52:12): station 0 (Vantage), no Vantage time offset.
logger (07.10.2020 22:52:12): station 0 (Vantage), eeprom request sent.
logger (07.10.2020 22:52:12): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (07.10.2020 22:52:12): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (07.10.2020 22:52:12): station 0 (Vantage), firmware version request sent.
logger (07.10.2020 22:52:12): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (07.10.2020 22:52:12): station 0 (Vantage), no reading of Vantage's internal logger.
logger (07.10.2020 22:52:17): sensors are now providing data.
logger (07.10.2020 22:52:17): services started.
Ok, that helps. Looks like a "getline" c statement throws the error. Please give just released version a try.
mthiessen
Post by mthiessen »
Build 3475
 database (11.10.2020 15:09:56): process started.
database (11.10.2020 15:09:56): Content of RAM database restored.
wnetd  (11.10.2020 15:10:00): process started.
system (11.10.2020 15:10:00): start of logging process initiated.
wnetd  (11.10.2020 15:10:01): send data thread started (pid:1910 tid:1911)
logger (11.10.2020 15:10:02): databases connected. Update interval 3600 seconds.
logger (11.10.2020 15:10:02): data logger (version 5.1d, build 3475) started.
logger (11.10.2020 15:10:03): connect station 0 (Vantage via serial).
logger (11.10.2020 15:10:03): connect station 9 (System Data via Plug-in).
logger (11.10.2020 15:10:03): station 0 (Vantage), wakeup sent.
logger (11.10.2020 15:10:06): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (11.10.2020 15:10:06): services paused.
logger (11.10.2020 15:10:07): station 0 (Vantage), no need to update console date/time.
logger (11.10.2020 15:10:07): station 0 (Vantage), setup script executed.
logger (11.10.2020 15:10:07): station 0 (Vantage), internal logger activated.
logger (11.10.2020 15:10:08): station 0 (Vantage), syncing.
database (11.10.2020 15:10:13): database sync done (31 tables, 95/2480 writes).
logger (11.10.2020 15:10:18): station 0 (Vantage), gettime request sent.
logger (11.10.2020 15:10:18): station 0 (Vantage), no Vantage time offset.
logger (11.10.2020 15:10:18): station 0 (Vantage), eeprom request sent.
logger (11.10.2020 15:10:18): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (11.10.2020 15:10:18): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (11.10.2020 15:10:18): station 0 (Vantage), firmware version request sent.
logger (11.10.2020 15:10:18): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (11.10.2020 15:10:18): station 0 (Vantage), no reading of Vantage's internal logger.
logger (11.10.2020 15:10:23): sensors are now providing data.
logger (11.10.2020 15:10:23): services started.
system (11.10.2020 15:25:49): Access point operation disabled 1069 secs after boot.
logger (12.10.2020 16:00:14): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 (10836064 3) < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a1 (10836064 3) < inetupload_getlineA8a0 (10836064 6) < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a...
logger (12.10.2020 16:00:14): disconnect station 0 (Vantage): exit
logger (12.10.2020 16:00:14): disconnect station 9 (System Data): exit
logger (12.10.2020 16:00:15): databases connected. Update interval 3600 seconds.
logger (12.10.2020 16:00:15): data logger (version 5.1d, build 3475) started.
logger (12.10.2020 16:00:16): connect station 0 (Vantage via serial).
logger (12.10.2020 16:00:16): connect station 9 (System Data via Plug-in).
logger (12.10.2020 16:00:16): station 0 (Vantage), wakeup sent.
logger (12.10.2020 16:00:19): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (12.10.2020 16:00:19): services paused.
logger (12.10.2020 16:00:20): station 0 (Vantage), no need to update console date/time.
logger (12.10.2020 16:00:20): station 0 (Vantage), setup script executed.
logger (12.10.2020 16:00:20): station 0 (Vantage), internal logger activated.
logger (12.10.2020 16:00:20): station 0 (Vantage), syncing.
logger (12.10.2020 16:00:30): station 0 (Vantage), gettime request sent.
logger (12.10.2020 16:00:30): station 0 (Vantage), no Vantage time offset.
logger (12.10.2020 16:00:30): station 0 (Vantage), eeprom request sent.
logger (12.10.2020 16:00:30): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (12.10.2020 16:00:30): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (12.10.2020 16:00:30): station 0 (Vantage), firmware version request sent.
logger (12.10.2020 16:00:30): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (12.10.2020 16:00:30): station 0 (Vantage), no reading of Vantage's internal logger.
logger (12.10.2020 16:00:35): sensors are now providing data.
logger (12.10.2020 16:00:35): services started.
logger (12.10.2020 16:20:21): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 (10830352 2006667896) < inetupload_getlineA (8) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < g...
logger (12.10.2020 16:20:21): disconnect station 0 (Vantage): exit
logger (12.10.2020 16:20:21): disconnect station 9 (System Data): exit
logger (12.10.2020 16:20:22): databases connected. Update interval 3600 seconds.
logger (12.10.2020 16:20:22): data logger (version 5.1d, build 3475) started.
logger (12.10.2020 16:20:23): connect station 0 (Vantage via serial).
logger (12.10.2020 16:20:23): connect station 9 (System Data via Plug-in).
logger (12.10.2020 16:20:23): station 0 (Vantage), wakeup sent.
logger (12.10.2020 16:20:26): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (12.10.2020 16:20:26): services paused.
logger (12.10.2020 16:20:27): station 0 (Vantage), no need to update console date/time.
logger (12.10.2020 16:20:27): station 0 (Vantage), setup script executed.
logger (12.10.2020 16:20:27): station 0 (Vantage), internal logger activated.
logger (12.10.2020 16:20:27): station 0 (Vantage), syncing.
logger (12.10.2020 16:20:37): station 0 (Vantage), gettime request sent.
logger (12.10.2020 16:20:37): station 0 (Vantage), no Vantage time offset.
logger (12.10.2020 16:20:37): station 0 (Vantage), eeprom request sent.
logger (12.10.2020 16:20:37): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (12.10.2020 16:20:37): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (12.10.2020 16:20:37): station 0 (Vantage), firmware version request sent.
logger (12.10.2020 16:20:37): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (12.10.2020 16:20:37): station 0 (Vantage), no reading of Vantage's internal logger.
logger (12.10.2020 16:20:41): sensors are now providing data.
logger (12.10.2020 16:20:41): services started.
mthiessen
Post by mthiessen »
It continues to go offline once a day. I this happening to anyone else or just me?
Build 3481
database (13.10.2020 20:44:51): process started.
database (13.10.2020 20:44:52): Content of RAM database restored.
wnetd  (13.10.2020 20:44:55): process started.
system (13.10.2020 20:44:55): start of logging process initiated.
wnetd  (13.10.2020 20:44:55): send data thread started (pid:1911 tid:1913)
logger (13.10.2020 20:44:56): databases connected. Update interval 3600 seconds.
logger (13.10.2020 20:44:56): data logger (version 5.1d, build 3481) started.
logger (13.10.2020 20:44:58): connect station 0 (Vantage via serial).
logger (13.10.2020 20:44:58): connect station 9 (System Data via Plug-in).
logger (13.10.2020 20:44:58): station 0 (Vantage), wakeup sent.
logger (13.10.2020 20:45:00): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (13.10.2020 20:45:00): services paused.
logger (13.10.2020 20:45:01): station 0 (Vantage), no need to update console date/time.
logger (13.10.2020 20:45:01): station 0 (Vantage), setup script executed.
logger (13.10.2020 20:45:01): station 0 (Vantage), internal logger activated.
logger (13.10.2020 20:45:01): station 0 (Vantage), syncing.
database (13.10.2020 20:45:08): database sync done (31 tables, 99/2487 writes).
logger (13.10.2020 20:45:11): station 0 (Vantage), gettime request sent.
logger (13.10.2020 20:45:11): station 0 (Vantage), no Vantage time offset.
logger (13.10.2020 20:45:11): station 0 (Vantage), eeprom request sent.
logger (13.10.2020 20:45:11): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (13.10.2020 20:45:11): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (13.10.2020 20:45:11): station 0 (Vantage), firmware version request sent.
logger (13.10.2020 20:45:11): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (13.10.2020 20:45:11): station 0 (Vantage), no reading of Vantage's internal logger.
logger (13.10.2020 20:45:16): sensors are now providing data.
logger (13.10.2020 20:45:16): services started.
system (13.10.2020 21:01:13): Access point operation disabled 1088 secs after boot.
logger (13.10.2020 22:45:03): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a2 < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload...
logger (13.10.2020 22:45:03): disconnect station 0 (Vantage): exit
logger (13.10.2020 22:45:03): disconnect station 9 (System Data): exit
logger (13.10.2020 22:45:04): databases connected. Update interval 3600 seconds.
logger (13.10.2020 22:45:04): data logger (version 5.1d, build 3481) started.
logger (13.10.2020 22:45:05): connect station 0 (Vantage via serial).
logger (13.10.2020 22:45:05): connect station 9 (System Data via Plug-in).
logger (13.10.2020 22:45:05): station 0 (Vantage), wakeup sent.
logger (13.10.2020 22:45:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (13.10.2020 22:45:08): services paused.
logger (13.10.2020 22:45:09): station 0 (Vantage), no need to update console date/time.
logger (13.10.2020 22:45:09): station 0 (Vantage), setup script executed.
logger (13.10.2020 22:45:09): station 0 (Vantage), internal logger activated.
logger (13.10.2020 22:45:09): station 0 (Vantage), syncing.
logger (13.10.2020 22:45:19): station 0 (Vantage), gettime request sent.
logger (13.10.2020 22:45:19): station 0 (Vantage), no Vantage time offset.
logger (13.10.2020 22:45:19): station 0 (Vantage), eeprom request sent.
logger (13.10.2020 22:45:19): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (13.10.2020 22:45:19): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (13.10.2020 22:45:19): station 0 (Vantage), firmware version request sent.
logger (13.10.2020 22:45:19): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (13.10.2020 22:45:19): station 0 (Vantage), no reading of Vantage's internal logger.
logger (13.10.2020 22:45:24): sensors are now providing data.
logger (13.10.2020 22:45:24): services started.
logger (13.10.2020 23:05:10): databases connected. Update interval 3600 seconds.
logger (13.10.2020 23:05:10): data logger (version 5.1d, build 3481) started.
logger (13.10.2020 23:05:10): error (22) while doing bind (port 22222): Invalid argument
logger (13.10.2020 23:05:10): killed process "13658/sh" listening to port 5553.
logger (13.10.2020 23:05:10): killed process "13659/meteosys" listening to port 5551.
logger (13.10.2020 23:05:13): data logger stopped.
logger (13.10.2020 23:05:13): databases disconnected.
logger (13.10.2020 23:05:13): parent process to be terminated.
logger (13.10.2020 23:05:40): databases connected. Update interval 3600 seconds.
logger (13.10.2020 23:05:40): data logger (version 5.1d, build 3481) started.
logger (13.10.2020 23:05:41): connect station 0 (Vantage via serial).
logger (13.10.2020 23:05:41): connect station 9 (System Data via Plug-in).
logger (13.10.2020 23:05:41): station 0 (Vantage), wakeup sent.
logger (13.10.2020 23:05:44): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (13.10.2020 23:05:44): services paused.
logger (13.10.2020 23:05:44): station 0 (Vantage), no need to update console date/time.
logger (13.10.2020 23:05:45): station 0 (Vantage), setup script executed.
logger (13.10.2020 23:05:45): station 0 (Vantage), internal logger activated.
logger (13.10.2020 23:05:45): station 0 (Vantage), syncing.
logger (13.10.2020 23:05:55): station 0 (Vantage), gettime request sent.
logger (13.10.2020 23:05:55): station 0 (Vantage), no Vantage time offset.
logger (13.10.2020 23:05:55): station 0 (Vantage), eeprom request sent.
logger (13.10.2020 23:05:55): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (13.10.2020 23:05:55): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (13.10.2020 23:05:55): station 0 (Vantage), firmware version request sent.
logger (13.10.2020 23:05:55): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (13.10.2020 23:05:55): station 0 (Vantage), no reading of Vantage's internal logger.
logger (13.10.2020 23:06:00): sensors are now providing data.
logger (13.10.2020 23:06:00): services started.
logger (13.10.2020 23:25:46): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a2 < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload...
logger (13.10.2020 23:25:46): disconnect station 0 (Vantage): exit
logger (13.10.2020 23:25:46): disconnect station 9 (System Data): exit
logger (13.10.2020 23:25:47): databases connected. Update interval 3600 seconds.
logger (13.10.2020 23:25:47): data logger (version 5.1d, build 3481) started.
logger (13.10.2020 23:25:48): connect station 0 (Vantage via serial).
logger (13.10.2020 23:25:48): connect station 9 (System Data via Plug-in).
logger (13.10.2020 23:25:48): station 0 (Vantage), wakeup sent.
logger (13.10.2020 23:25:51): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (13.10.2020 23:25:51): services paused.
logger (13.10.2020 23:26:01): station 0 (Vantage), execution of setup script failed (console is not responding).
logger (13.10.2020 23:26:01): station 0 (Vantage), internal logger activated.
logger (13.10.2020 23:26:01): station 0 (Vantage), syncing.
logger (13.10.2020 23:26:01): station 0 (Vantage), gettime request sent.
logger (13.10.2020 23:26:01): station 0 (Vantage), communication with Davis console/envoy seems to be stalled. Please power cycle the console/envoy by (1) disconnect from AC, (2) remove batteries and (3) disconnect USB. Wait a minute and power on again. Weak batteries need to be replaced.
logger (13.10.2020 23:26:11): station 0 (Vantage), gettime request sent.
logger (13.10.2020 23:26:11): station 0 (Vantage), no Vantage time offset.
logger (13.10.2020 23:26:11): station 0 (Vantage), eeprom request sent.
logger (13.10.2020 23:26:11): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (13.10.2020 23:26:11): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (13.10.2020 23:26:11): station 0 (Vantage), firmware version request sent.
logger (13.10.2020 23:26:11): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (13.10.2020 23:26:11): station 0 (Vantage), no reading of Vantage's internal logger.
logger (13.10.2020 23:26:16): sensors are now providing data.
logger (13.10.2020 23:26:16): services started.
logger (13.10.2020 23:45:53): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getli...
logger (13.10.2020 23:45:53): disconnect station 0 (Vantage): exit
logger (13.10.2020 23:45:53): disconnect station 9 (System Data): exit
logger (13.10.2020 23:45:54): databases connected. Update interval 3600 seconds.
logger (13.10.2020 23:45:54): data logger (version 5.1d, build 3481) started.
logger (13.10.2020 23:45:55): connect station 0 (Vantage via serial).
logger (13.10.2020 23:45:55): connect station 9 (System Data via Plug-in).
logger (13.10.2020 23:45:55): station 0 (Vantage), wakeup sent.
logger (13.10.2020 23:45:58): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (13.10.2020 23:45:58): services paused.
logger (13.10.2020 23:45:59): station 0 (Vantage), no need to update console date/time.
logger (13.10.2020 23:45:59): station 0 (Vantage), setup script executed.
logger (13.10.2020 23:45:59): station 0 (Vantage), internal logger activated.
logger (13.10.2020 23:45:59): station 0 (Vantage), syncing.
logger (13.10.2020 23:46:09): station 0 (Vantage), gettime request sent.
logger (13.10.2020 23:46:09): station 0 (Vantage), no Vantage time offset.
logger (13.10.2020 23:46:09): station 0 (Vantage), eeprom request sent.
logger (13.10.2020 23:46:09): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (13.10.2020 23:46:09): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (13.10.2020 23:46:09): station 0 (Vantage), firmware version request sent.
logger (13.10.2020 23:46:09): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (13.10.2020 23:46:09): station 0 (Vantage), no reading of Vantage's internal logger.
logger (13.10.2020 23:46:14): sensors are now providing data.
logger (13.10.2020 23:46:14): services started.
logger (14.10.2020 00:16:29): child process received timeout signal (14).
logger (14.10.2020 00:16:29): disconnect station 0 (Vantage): exit
logger (14.10.2020 00:16:29): disconnect station 9 (System Data): exit
marco
Post by marco »
mthiessen wrote: Wed Oct 14, 2020 1:24 pm It continues to go offline once a day. I this happening to anyone else or just me?
Build 3481
It happens also on my station last time yesterday:
database (14.10.2020 02:48:43): process started.
database (14.10.2020 02:48:43): Content of RAM database restored.
wnetd  (14.10.2020 02:48:45): process started.
system (14.10.2020 02:48:45): start of logging process initiated.
wnetd  (14.10.2020 02:48:45): send data thread started (pid:1925 tid:1926)
logger (14.10.2020 02:48:46): databases connected. Update interval 3600 seconds.
logger (14.10.2020 02:48:46): data logger (version 5.1d, build 3481) started.
logger (14.10.2020 02:48:48): connect station 0 (Vantage via USB serial).
logger (14.10.2020 02:48:48): connect station 9 (System Data via Plug-in).
logger (14.10.2020 02:48:48): station 0 (Vantage), wakeup sent.
logger (14.10.2020 02:48:51): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.10.2020 02:48:51): services paused.
logger (14.10.2020 02:48:51): station 0 (Vantage), no need to update console date/time.
logger (14.10.2020 02:48:52): station 0 (Vantage), setup script executed.
logger (14.10.2020 02:48:52): station 0 (Vantage), internal logger activated.
logger (14.10.2020 02:48:52): station 0 (Vantage), syncing.
database (14.10.2020 02:48:54): database sync done (35 tables, 0/1625 writes).
logger (14.10.2020 02:49:02): station 0 (Vantage), gettime request sent.
logger (14.10.2020 02:49:12): message above repeats 1 time.
logger (14.10.2020 02:49:12): station 0 (Vantage), no Vantage time offset.
logger (14.10.2020 02:49:12): station 0 (Vantage), eeprom request sent.
logger (14.10.2020 02:49:12): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (14.10.2020 02:49:12): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (14.10.2020 02:49:12): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (14.10.2020 02:49:12): station 0 (Vantage), firmware version request sent.
logger (14.10.2020 02:49:12): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (14.10.2020 02:49:12): station 0 (Vantage), no reading of Vantage's internal logger.
logger (14.10.2020 02:49:17): sensors are now providing data.
logger (14.10.2020 02:49:17): services started.
system (14.10.2020 03:06:40): Access point operation disabled 1157 secs after boot.
logger (14.10.2020 05:18:53): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid ...
logger (14.10.2020 05:18:53): disconnect station 0 (Vantage): exit
logger (14.10.2020 05:18:53): disconnect station 9 (System Data): exit
logger (14.10.2020 05:18:54): databases connected. Update interval 3600 seconds.
logger (14.10.2020 05:18:54): data logger (version 5.1d, build 3481) started.
logger (14.10.2020 05:18:55): connect station 0 (Vantage via USB serial).
logger (14.10.2020 05:18:55): connect station 9 (System Data via Plug-in).
logger (14.10.2020 05:18:55): station 0 (Vantage), wakeup sent.
logger (14.10.2020 05:18:58): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.10.2020 05:18:58): services paused.
logger (14.10.2020 05:18:59): station 0 (Vantage), no need to update console date/time.
logger (14.10.2020 05:18:59): station 0 (Vantage), setup script executed.
logger (14.10.2020 05:18:59): station 0 (Vantage), internal logger activated.
logger (14.10.2020 05:18:59): station 0 (Vantage), syncing.
logger (14.10.2020 05:19:09): station 0 (Vantage), gettime request sent.
logger (14.10.2020 05:19:09): station 0 (Vantage), no Vantage time offset.
logger (14.10.2020 05:19:09): station 0 (Vantage), eeprom request sent.
logger (14.10.2020 05:19:09): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (14.10.2020 05:19:09): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (14.10.2020 05:19:09): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (14.10.2020 05:19:09): station 0 (Vantage), firmware version request sent.
logger (14.10.2020 05:19:09): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (14.10.2020 05:19:09): station 0 (Vantage), no reading of Vantage's internal logger.
logger (14.10.2020 05:19:13): sensors are now providing data.
logger (14.10.2020 05:19:13): services started.
logger (14.10.2020 05:39:01): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid ...
logger (14.10.2020 05:39:01): disconnect station 0 (Vantage): exit
logger (14.10.2020 05:39:01): disconnect station 9 (System Data): exit
logger (14.10.2020 05:39:02): databases connected. Update interval 3600 seconds.
logger (14.10.2020 05:39:02): data logger (version 5.1d, build 3481) started.
logger (14.10.2020 05:39:03): connect station 0 (Vantage via USB serial).
logger (14.10.2020 05:39:03): connect station 9 (System Data via Plug-in).
logger (14.10.2020 05:39:03): station 0 (Vantage), wakeup sent.
logger (14.10.2020 05:39:06): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.10.2020 05:39:06): services paused.
logger (14.10.2020 05:39:07): station 0 (Vantage), no need to update console date/time.
logger (14.10.2020 05:39:07): station 0 (Vantage), setup script executed.
logger (14.10.2020 05:39:07): station 0 (Vantage), internal logger activated.
logger (14.10.2020 05:39:07): station 0 (Vantage), syncing.
logger (14.10.2020 05:39:17): station 0 (Vantage), gettime request sent.
logger (14.10.2020 05:39:17): station 0 (Vantage), no Vantage time offset.
logger (14.10.2020 05:39:17): station 0 (Vantage), eeprom request sent.
logger (14.10.2020 05:39:17): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (14.10.2020 05:39:17): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (14.10.2020 05:39:17): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (14.10.2020 05:39:17): station 0 (Vantage), firmware version request sent.
logger (14.10.2020 05:39:17): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (14.10.2020 05:39:17): station 0 (Vantage), no reading of Vantage's internal logger.
logger (14.10.2020 05:39:21): sensors are now providing data.
logger (14.10.2020 05:39:21): services started.
logger (14.10.2020 05:59:08): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a2 < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload...
logger (14.10.2020 05:59:08): disconnect station 0 (Vantage): exit
logger (14.10.2020 05:59:08): disconnect station 9 (System Data): exit
logger (14.10.2020 05:59:10): databases connected. Update interval 3600 seconds.
logger (14.10.2020 05:59:10): data logger (version 5.1d, build 3481) started.
logger (14.10.2020 05:59:10): connect station 0 (Vantage via USB serial).
logger (14.10.2020 05:59:10): connect station 9 (System Data via Plug-in).
logger (14.10.2020 05:59:10): station 0 (Vantage), wakeup sent.
logger (14.10.2020 05:59:13): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.10.2020 05:59:13): services paused.
logger (14.10.2020 05:59:14): station 0 (Vantage), no need to update console date/time.
logger (14.10.2020 05:59:14): station 0 (Vantage), setup script executed.
logger (14.10.2020 05:59:14): station 0 (Vantage), internal logger activated.
logger (14.10.2020 05:59:15): station 0 (Vantage), syncing.
logger (14.10.2020 05:59:25): station 0 (Vantage), gettime request sent.
logger (14.10.2020 05:59:25): station 0 (Vantage), no Vantage time offset.
logger (14.10.2020 05:59:25): station 0 (Vantage), eeprom request sent.
logger (14.10.2020 05:59:25): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (14.10.2020 05:59:25): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (14.10.2020 05:59:25): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (14.10.2020 05:59:25): station 0 (Vantage), firmware version request sent.
logger (14.10.2020 05:59:25): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (14.10.2020 05:59:25): station 0 (Vantage), no reading of Vantage's internal logger.
logger (14.10.2020 05:59:29): sensors are now providing data.
logger (14.10.2020 05:59:29): services started.
logger (14.10.2020 06:19:15): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload_getlineA8a2 < inetupload_getlineA8a0 < inetupload_getlineA8a1 < inetupload_getlineA (8) < inetupload_getline < inetupload_getlineA8b < inetupload...
logger (14.10.2020 06:19:15): disconnect station 0 (Vantage): exit
logger (14.10.2020 06:19:15): disconnect station 9 (System Data): exit
logger (14.10.2020 06:19:16): databases connected. Update interval 3600 seconds.
logger (14.10.2020 06:19:16): data logger (version 5.1d, build 3481) started.
logger (14.10.2020 06:19:17): connect station 0 (Vantage via USB serial).
logger (14.10.2020 06:19:17): connect station 9 (System Data via Plug-in).
logger (14.10.2020 06:19:17): station 0 (Vantage), wakeup sent.
logger (14.10.2020 06:19:20): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.10.2020 06:19:20): services paused.
logger (14.10.2020 06:19:21): station 0 (Vantage), no need to update console date/time.
logger (14.10.2020 06:19:21): station 0 (Vantage), setup script executed.
logger (14.10.2020 06:19:21): station 0 (Vantage), internal logger activated.
logger (14.10.2020 06:19:21): station 0 (Vantage), syncing.
logger (14.10.2020 06:19:31): station 0 (Vantage), gettime request sent.
logger (14.10.2020 06:19:31): station 0 (Vantage), no Vantage time offset.
logger (14.10.2020 06:19:31): station 0 (Vantage), eeprom request sent.
logger (14.10.2020 06:19:31): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (14.10.2020 06:19:31): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (14.10.2020 06:19:31): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (14.10.2020 06:19:31): station 0 (Vantage), firmware version request sent.
logger (14.10.2020 06:19:31): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (14.10.2020 06:19:31): station 0 (Vantage), no reading of Vantage's internal logger.
logger (14.10.2020 06:19:36): sensors are now providing data.
logger (14.10.2020 06:19:36): services started.
logger (14.10.2020 06:39:22): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getline < inetupload_getlineA (4) < inetupload_getli...
logger (14.10.2020 06:39:22): disconnect station 0 (Vantage): exit
logger (14.10.2020 06:39:22): disconnect station 9 (System Data): exit
logger (14.10.2020 06:39:23): databases connected. Update interval 3600 seconds.
logger (14.10.2020 06:39:23): data logger (version 5.1d, build 3481) started.
logger (14.10.2020 06:39:24): connect station 0 (Vantage via USB serial).
logger (14.10.2020 06:39:24): connect station 9 (System Data via Plug-in).
logger (14.10.2020 06:39:24): station 0 (Vantage), wakeup sent.
logger (14.10.2020 06:39:27): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.10.2020 06:39:27): services paused.
logger (14.10.2020 06:39:27): station 0 (Vantage), no need to update console date/time.
logger (14.10.2020 06:39:28): station 0 (Vantage), setup script executed.
logger (14.10.2020 06:39:28): station 0 (Vantage), internal logger activated.
logger (14.10.2020 06:39:28): station 0 (Vantage), syncing.
logger (14.10.2020 06:39:38): station 0 (Vantage), gettime request sent.
logger (14.10.2020 06:39:38): station 0 (Vantage), no Vantage time offset.
logger (14.10.2020 06:39:38): station 0 (Vantage), eeprom request sent.
logger (14.10.2020 06:39:38): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (14.10.2020 06:39:38): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (14.10.2020 06:39:38): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (14.10.2020 06:39:38): station 0 (Vantage), firmware version request sent.
logger (14.10.2020 06:39:38): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (14.10.2020 06:39:38): station 0 (Vantage), no reading of Vantage's internal logger.
logger (14.10.2020 06:39:44): sensors are now providing data.
logger (14.10.2020 06:39:44): services started.
logger (14.10.2020 06:59:29): child process received termination signal (11) in functions: termination_handler < inetupload_getlineA (4) < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_INETUPLOADZ < gen_INETUPLOADREQFN < inetuploader < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get_sensorid < get...
logger (14.10.2020 06:59:29): disconnect station 0 (Vantage): exit
logger (14.10.2020 06:59:29): disconnect station 9 (System Data): exit
logger (14.10.2020 06:59:30): databases connected. Update interval 3600 seconds.
logger (14.10.2020 06:59:30): data logger (version 5.1d, build 3481) started.
logger (14.10.2020 06:59:31): connect station 0 (Vantage via USB serial).
logger (14.10.2020 06:59:31): connect station 9 (System Data via Plug-in).
logger (14.10.2020 06:59:31): station 0 (Vantage), wakeup sent.
logger (14.10.2020 06:59:34): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.10.2020 06:59:34): services paused.
logger (14.10.2020 06:59:35): station 0 (Vantage), no need to update console date/time.
logger (14.10.2020 06:59:35): station 0 (Vantage), setup script executed.
logger (14.10.2020 06:59:35): station 0 (Vantage), internal logger activated.
logger (14.10.2020 06:59:35): station 0 (Vantage), syncing.
logger (14.10.2020 06:59:45): station 0 (Vantage), gettime request sent.
logger (14.10.2020 06:59:45): station 0 (Vantage), no Vantage time offset.
logger (14.10.2020 06:59:45): station 0 (Vantage), eeprom request sent.
logger (14.10.2020 06:59:45): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (14.10.2020 06:59:45): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (14.10.2020 06:59:45): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (14.10.2020 06:59:45): station 0 (Vantage), firmware version request sent.
logger (14.10.2020 06:59:45): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (14.10.2020 06:59:45): station 0 (Vantage), no reading of Vantage's internal logger.
logger (14.10.2020 06:59:50): sensors are now providing data.
logger (14.10.2020 06:59:50): services started.
logger (14.10.2020 07:25:04): child process received timeout signal (14).
logger (14.10.2020 07:25:04): disconnect station 0 (Vantage): exit
logger (14.10.2020 07:25:04): disconnect station 9 (System Data): exit
I've configured a daily reboot at 02:45 AM, but It seems after that error: " child process received timeout signal (14)." MB is not capable to reboot on the next scheduled Time. I did the restart manually this morning 05:13AM
now I have the: (Meteobridge 4.4 (Oct 14 2020, build 3490), FW 1.4) on my MB.
database (15.10.2020 05:13:19): process started.
database (15.10.2020 05:13:19): Content of RAM database restored.
wnetd  (15.10.2020 05:13:22): process started.
system (15.10.2020 05:13:22): start of logging process initiated.
wnetd  (15.10.2020 05:13:22): send data thread started (pid:1989 tid:1990)
logger (15.10.2020 05:13:23): databases connected. Update interval 3600 seconds.
logger (15.10.2020 05:13:23): data logger (version 5.1d, build 3490) started.
logger (15.10.2020 05:13:24): connect station 0 (Vantage via USB serial).
logger (15.10.2020 05:13:24): connect station 9 (System Data via Plug-in).
logger (15.10.2020 05:13:25): station 0 (Vantage), wakeup sent.
logger (15.10.2020 05:13:28): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (15.10.2020 05:13:28): services paused.
logger (15.10.2020 05:13:28): station 0 (Vantage), no need to update console date/time.
logger (15.10.2020 05:13:29): station 0 (Vantage), setup script executed.
logger (15.10.2020 05:13:29): station 0 (Vantage), internal logger activated.
logger (15.10.2020 05:13:29): station 0 (Vantage), syncing.
database (15.10.2020 05:13:34): database sync done (35 tables, 89/1637 writes).
logger (15.10.2020 05:13:39): station 0 (Vantage), gettime request sent.
logger (15.10.2020 05:13:39): station 0 (Vantage), no Vantage time offset.
logger (15.10.2020 05:13:39): station 0 (Vantage), eeprom request sent.
logger (15.10.2020 05:13:39): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (15.10.2020 05:13:39): station 0 (Vantage), transmitter 3 active as station type #4 "Wind".
logger (15.10.2020 05:13:39): station 0 (Vantage), transmitter 6 active as station type #0 "ISS".
logger (15.10.2020 05:13:39): station 0 (Vantage), firmware version request sent.
logger (15.10.2020 05:13:39): station 0 (Vantage), firmware version 3.15 (supports LOOP2)
logger (15.10.2020 05:13:39): station 0 (Vantage), no reading of Vantage's internal logger.
logger (15.10.2020 05:13:43): sensors are now providing data.
logger (15.10.2020 05:13:43): services started.
That happens quite a few times, to my station but I thought it was, because I haven't set any "lastgooddata" alarms. I have my alarm-setup now, since about 2 days, and they worked when tested. But it does not help. No Messages arrived on my phone or mail client.
Thanks for any help.
Marco
