Data is no longer processed **solved**
webcam
Post by webcam »
Hello everybody,
since the last update (Oct.5) my data is no longer processed. The pages are uploaded, but they remain blank.
The only thing that works is uploading it to Meteoplug.
Have restarted the system several times.
Meteobridge reads the data from the weather station. (See image)
https://www.wetterbrienz.ch/meteoplug.html
https://www.wetterbrienz.ch/meteobridge ... eite1.html
Where else can I look where the problem is?
Merci for your help.
Greeting
Daniel
xray77
Re: Data is no longer processed
Post by xray77 »
Hello Daniel,
After last MeteoBridge-FW/SW-Update last night something goes wrong, also at my unit MB NANO SD. All template-files to feed any uploads on my server are empty, it seem's so, that the MB has forgotten all variables.. Only thing what resolve for me is the downgrade to an earlier MeteoBridge-FW/SW-Version. All services run again after downgrade to Version 4.3 from July 2020..
Meteobridge NANO SD (awekas Version)
RAM: 125572 kB insgesamt, 44780 kB frei (64% verwendet)
Speicher: swissbit SLC, 1825 MB total, 1745 MB free (4% used)
SW-Version: Meteobridge 4.3 (Jul 12 2020, build 3163), FW 1.4
I think, Boris is working to resolve this bug in the SW/FW-Version 4.4 as soon as he can..
webcam
Post by webcam »
unfortunately it doesn't work for me with 4.3 either.
Greeting
Daniel
webcam
Post by webcam »
The graphics seem to work with 4.3. Unfortunately not the rest.
https://www.wetterbrienz.ch/meteobridge-grafik.html
webcam
Post by webcam »
gave an update. Now it works again.
Merci .....
Greeting
Daniel
current version should be fine. Please reboot and check.
Links given in the first posts look fine (again). I think this can be regarded solved.
webcam
Re: Data is no longer processed **solved**
Post by webcam »
Merci for the quick completion.
