Re: Weather34 TEMPLATE
(*Update for 16th October 00:01)
* This update is all about air quality it is phase(1) for new features and additional data
* Adds extra setup option position 14 for mobile view Ref Chuck
* Air Quality adds new chart view for today with purple air/davis airlink
* Converts all air quality modules to show US Standard Air Quality Index value
* Adds additional US Air Quality Index value along with PM2.5/PM10 for info pop ups
* Adds air quality links with large or small relevant modules
* Adds Davis air quality option to setup screen
* Adds Davis air quality current value for today chart script
* Danish language update ref Bjarne Riis
@xray77 I have just uploaded this labelled 16th October 00:01 has Im off fishing all day tomorrow with a 5am start ..I catch it wife cooks it :-)
Yes I know what you mean chuck ever since some recent firmware update no idea when it happened but I had a few spare hubs lying around and setup a new never used one recently and it miraculously got a unannounced firmware update and ever since the wifi drops numerous times in a day often see the hub with a red LED or no LED its the the actual hub that loses the wifi connection to router(s)! no point in contacting them they will just say it your router which has never changed in two years .sadly I gave up long ago losing any sleep over it just going to run it until it dies of death, already had my original air die earlier in the year just fortunate I had a spare air test unit lying around so thats it after that..I only use it for lightning and its buried so no need to dig a hole for it when it does pack up :-) ..have a nice evening ...Brian ..
woolfg
Post by woolfg »
Hi Brian
Your last update has broken the Air Quality (16th Oct)
None of the pop-ups work now on Edge or Firefox
Gaham
xray77
Post by xray77 »
Oh Brian,
you've got it good! I have to catch the fish myself (which is fun!) but I also have to prepare it myself and eat it all! We live by the sea and almost nobody likes fish but me... :-(
I will wait with the last update, because an error message was posted... ;-)
Have sent you translation file "DE" for AQI on PM..
Bildschirmfoto 2020-10-15 um 21.11.55.png (71.16 KiB) Viewed 4539 times
best regards
Mike
woolfg
Post by woolfg »
Hi
I have just emailed Brian
I think the problem is the new position 14 - if its blank as it will be initially then the AQ pop-ups dont appear to work
However if you put something in module 14 then it does appear to work OK - however I cant clear position 14 to test again
Graham
whenever a new option is added to setup then it or a new option is required to be set ,once it is set you wouldn't see that error . however I have removed the option from the updated download until next week until I have some free time to look at it and put a fallback option..you can just run the update file again to clear it ..sorry you win some you lose some .... ..thanks ..Brian
ps thanks for the updated German language file just missed the update but will add in next week..
Have a good trip tomorrow!
xray77
Post by xray77 »
..and "Petri Heil", that's what they say in Germany for the angler's luck!
regards,
Mike
ha thanks for the good luck for fishing its pretty non challenging as we are only catch small fish and make a meal from it whilst we are there on a small fire nothing exotic, I live literally 5 minutes walk from the sea front and as the tourist season is over its quite relaxing and have been taught how to eat fish with bone in it but I won't in go into detail but it took me a few years to master it ..
anyway have introduced the day chart for luftdaten data , have improved the handling of time ago station was installed .
going forward I will label updates like this from Saturday 19th October as sometimes 2 updates occur in a day and its not easy to apply a time based on we all reside in different timezones ..So daytime update will be like 16-10-2020-daytime-update.zip and night time update which often occur end of day will be 16-10-2020-night-update.zip and ill will only release a maximum of two updates per day if required .best I can think of without it going astray or creating some confusion .regardless of the name of zip file it makes no difference to how the update performs its update as you simply select the appropriate zip.I get often issues raised very near to my end of day so instead of just labelling it current date.zip this hopefully might help.
(*Update for 17th October 00:01)
* Better handling of time ago station hardware was installed
* Fix for non metric max dewpoint if below freezing ref Robert (Fairbanks Alaska)
* Adds Luftdaten Air Quality new chart view for today
* German language update ref Mike(xray77)
screenshots of current update showing air quality charts for 3 different devices and time ago for hardware ..
atlantic21
Post by atlantic21 »
Hello Brian all looking great here with the new Luftdaten AQI graph
many thanks Richard :D
xray77
Post by xray77 »
Hello Brian,
Yes, you can only enjoy the sea here when the season is over... ;-) I hope the fishing trip was a complete success in terms of relaxation and recreation!
Thanks for the Update! Now i can see how long my station run's, it's over 19 years now.. wow, nice to see! Have a Question about the Luftdaten-Module: Where does the module get its data from, from the API or from luftdaten.info via station.cron? The server of luftdaten.info is not always so stable, so that sometimes no data can be retrieved from there.
Stay healthy!
Best regards
Mike
xray77
Post by xray77 »
Hello Brian,
Air-Quality-Module for MeteoBridge doesn't work anymore at my site:
Bildschirmfoto 2020-10-16 um 20.54.14.png (87.44 KiB) Viewed 4459 times
Only a blank field appear's.
Seccond issue:
The year-count in the info-module seem's to be wrong (one year too much)?
Bildschirmfoto 2020-10-16 um 21.15.14.png (40.04 KiB) Viewed 4459 times
Bildschirmfoto 2020-10-16 um 21.13.01.png (46.09 KiB) Viewed 4459 times
My station has existed for an unusually long time. Perhaps it is because of the long period? 8)
Best regards
Mike
all fixed good night ...
xray77
Post by xray77 »
it works all now, thanks and a good night and a relaxed weekend,
stay healthy,
regards
Mike
xray77 wrote: Fri Oct 16, 2020 10:49 pm Brian,
stay healthy,
regards
Mike
sorry I was very tired last night so that was just a quick dirty fix , you will find the proper fix and now with translations just updated .
the original was rounding up values hence 19 years etc as opposed to 18 years .....
(*Afternoon Update for 17th October 12:01)
* Fixes year being rounded up for date installed hardware
* Fixes duplicate script meteobridge air quality module
* Adds Purple Air/Davis/Luftdaten Air Quality new chart view for today
screenshot with start year date of 2002-01-01
Screenshot at Oct 17 10-30-11.png (103.09 KiB) Viewed 4424 times
Screenshot at Oct 17 10-46-28.png (110.12 KiB) Viewed 4420 times
xray77 wrote: Fri Oct 16, 2020 6:56 pm Have a Question about the Luftdaten-Module: Where does the module get its data from, from the API or from luftdaten.info via station.cron? The server of luftdaten.info is not always so stable, so that sometimes no data can be retrieved from there.
Luftdaten uses the API if it returns nothing or missing data then the issue is at luftdaten service.. a few years ago Piet would often report this and not much you can do apart from use a less frequent API call which means another option and script and hope it returns a valid data output..either way issue lies at luftdaten all the script in template does is call the API service and Im reluctant to throw any more time into Air Quality stuff from remote clouds, services etc I would just like to polish off and use what meteobridge now supports and take advantage of that as it has become stable in terms of AIR QUALITY support.
Brian
