xray77
Re: Weather34 TEMPLATE
Hello, Brian,
Okay, thanks for the info. I also think it is better if the data comes from MeteoBridge and you are not so dependent on cloud services.
Best regards
Mike
Best regards
Mike
(*Morning Update for 18th October 08:21)
* Standardized all air quality pop up screens with new descriptions
* Fixes font-size in day forecast large module Ref Josep
* Fixes year being rounded up for date installed hardware Ref Mike(xray77)
* Fixes duplicate script meteobridge air quality module Ref Mike(xray77)
* Fix for non metric max dewpoint if below freezing ref Robert (Fairbanks Alaska)
* Adds Purple Air/Davis/Luftdaten Air Quality new chart view for today
* Catalan/Spanish language update ref Josep
* German language update ref Mike(xray77)
* Danish language update ref Bjarne Riis
attempts to create a similar appearance across air quality popups and easier to maintain going forward. also I dont want to make this just another page looking like a WIKI layout lets keep weather34 different thats how its identifiable .. if we all use the boring standard wiki layout type designs then its a pretty boring uninspiring outcome..
*I appreciate the emails but just be patient with me I do get to the issue sooner or later perhaps not as quick as you would like but I get there so I dont ignore your issues/ideas .
- prestwickwx
The latest update with AQI descriptions looks great.
xray77
Hello Brian,
I agree with Chuck, looks great and will help viewers to understand more clearly what they see.!
But i can't translate the AQI-descriptions via language-file, they have no dependencies to it..
Best regards
Mike
Best regards
Mike
as before first lets make it work then enhance it to accommodate ideas.. ive no idea how it will fit in other languages apart from a short english explanation as you can see it fits in english but could well break in translations due to word length variations. ill add translation string per pm 2.5 and pm10 by default it will be in english and as always the translation file can be translated updated accordingly..
xray77
Hello Brian,
Ok, This translation into german language would fit for future builds: the english original is more meaningful, but you can't put it in german due to lack of space.
Best regards and stay healthy,
Mike
Mike
ha welcome to my world , you get a moment of inspiration (a lightbulb switches on) it works well then you attempt to use in another language and it all goes pete tong (wrong) https://www.cockneyrhymingslang.co.uk/slang/pete-tong .my southern cockney rhyming slang is apparent here. brits will know what i mean
. idea gets shelved.. dont worry will work on it in the week..
xray77
Okay, I guess that's it..
somewhat easier than thought however files need to be correctly translated no idea if they will correctly fit in translation especially VOC description..
(*Evening Update for 18th October 20:26)
* Adds translations capability to air quality pop up screens Ref Mike(xray77)
3 additional language strings
probably,said before year in year out best what if ideas come from listening to tangerine dream staring out the window with my bose headphones on...
currently listening too white eagle...
$lang['PM25desc']='PM2.5 is a greater threat to your health .High levels causes severe respiratory problems.';
$lang['PM10desc']='PM10 particles these can get deep into your lungs causing respiratory problems,lung disease.';
$lang['VOCdesc']='Exposure to VOCs can cause eye,nose and throat irritation,as well as upper respiratory infections,nausea,allergic reactions and headaches.';
Hi Brian
Slight alignment issue with Purple Air and VOC
I love Tangerine Dream too and Mike Oldfield and Pink Floyd - real music
Graham
Graham
as I said VOC might cause issues now we see a 3 figure value highlights that .. so try the update again should be fine now ..
My hands felt just like two balloons
Now I've got that feeling once again ...
sometimes I think do with the mistakes I make :-)_ ...
atlantic21
- Junior Boarder
Hi Brian with the latest up date my sun rise and set times have changed see attachment
Regards Richard
Regards Richard
- sun .png (36.06 KiB) Viewed 4797 times
good morning .. no changes been made to any sun related data in latest updates . can you throw some light into what exactly is incorrect ?
ok I see what you mean now its the sun moon module showing incorrect till set/rise phrase..
updated update file with fix..
(*Morning Update for 19th October 10:06))
* Fix incorrect sunrise/set phrase in moon sun module Ref Richard(atlantic21)
Good morning if using weather34-airquality-mod-mb.php it expects AQI value to be in position 175 as per default string air0pm not air0!0pm .if you assign your air quality sensor to another like air0!0pm then this module will not work for you .you would need to adapt or use the Davis module however your not using a Davis hardware so the description will be invalid or wrong. very sorry there is zero support for Ecowitt configurations out of courtesy I re-enabled GW1000 use to be used but there is zero support it is way to complex and mind blowing for me who doesn't own an ecowitt array of sensors to develop anything to a standard as the variety of sensors are all over the place and majority in the house , this template is not designed for Ecowitt stuff or home environment monitoring on that level or quantity of sensors. dont take it personally but you can always attempt to use it but dont expect it to be fully compatible as there is zero focus on making it compatible .I strongly recommend to use Wim van de Kuil template if you want full ecowitt support not this one unfortunately..alexdelprete wrote: Mon Oct 19, 2020 1:41 am
In MB I have mapped air0!0pm physical sensor (WH41) to air1pm logical sensor. I found that the PM2.5 value (11.0) was actually uploaded by MB in position 181. So I tried modifying weather34-airquality-mod-mb.php pointing it to position 181 instead of 175, and finally I could display AQI with my setup.
