garybridge
Re: Weather34 TEMPLATE
Post by garybridge »
Looking forward to it Brian! :D
Gary Bridge MIET, MIPS.
wsnoordbergum
Post by wsnoordbergum »
I don't get to see Aqi from luftdaten.
I have entered the correct id of luftdaten on the setup page.
The graphs don't work either.
I am using the nano SD version of the template.
I have the Aurora download link requested but no response yet. I really like the template.
good morning
are you running the services as per setup guide? .. unfortunately like most IP addresses from holland they are blocked in turkey via the ISP and only usually viewable when using a VPN ...its nothing personal from my end and not something the ISP would make an exception for individuals.probably why you never got a response for request..the url if was valid correctly supplied was unreachable..unfortunately i dont use a vpn on my dev computer only on a ipad..also its been noticed that many urls provided also block turkey so its a common thing i just put up with..as we say locally only friend of a turk is a turk.. :shock:
have a read of setup page its valid for previous version and new Aurora version
robr57
Post by robr57 »
Hi, does anyone know how to obtain the download password ? I submitted 2 requests through filling in the link https://weather34.com/homeweatherstatio ... ctform.htm in last 2 weeks, but I don't receive anything back.
I tried to read through all the forum message's but could not find any clue on what else to do to get the password.
I have since few weeks a Meteobridge Pro, with Davis Vantage and installed Saratoga website. But I think that Weather34 is more suitable for me as it supports mobile as well.
as above if the url is valid you will get a password if the url is not viewable in turkey you wont get one , if your url is not https you wont get one , if you dont provide a valid url then you wont get one .
a lot of people send url from wunderground or a weatherflow url this tells me very little , many people send url that is either using cumulus,weewx,wd software the template is 100% not compatible with those so it will save many a lot time and inconvenience.the whole point is to reduce the support time and not become overwhelmed like in the past . nothing is personal it just a means of ensuring that i dont end up getting sucked into software support i have no knowledge of and will save end user a lot of frustration which ultimately comes firing my way.since introduction of password support requirement is very low as all are using meteobridge not some unsupported software.. so if you have a valid url send a request again and if its reachable, viewable then your get a password.password changes every 7 days :D generally on a monday. i dont send out passwords over weekends as the password will change on the monday and some dont always see the reply until its too late..hope that clarifies it..
On Sep 20, 2020, at 1:21 AM, weather34-info <info@weatxxx .com> wrote:
Good morning unfortunately it is not compatible with Tempest weatherflow API you require a meteobridge device to run the template.
<F882589128644D64BCC203D6CBDAB8B4.png>
Meteobridge Weather34 weather template
https://weather34.com/homeweatherstation
On 19 Sep 2020 17:57 +0300, rhpp...wrote:
Weather34 Download Request details below.
Full Name: Robert Rose
Email:xxxx. usa.net
Website Url: https://tempestwx.com/station/28386/
Message: Using a Weatherflow Tempest. Would like to try your software. Thanks.
would that be you ???
robr57
Post by robr57 »
Thanks for the explanation.
No that is not me.
My site is https://www.robroos.nl but it is not reachable for all countries in the world due to firewall restrictions on scanning ip addresses.
Unfortunately Russia, Balkan countries are automatically blocked due to overwhelming amount of port scans on last months from those regions.
I will see if I can open the firewall for https from Turkey
ok just send us a request i can see its a genuine request from your forum posts..dont worry unblocking turkey it happens for a reason..
you can see i get some weird url sent in request this one was a phone number :shock:
Weather34 Aurora Download Request details below.
Full Name: E Hxxxx
Email: xx
Website Url: +xx491632434xxx
Message: Davis Vantage Pro2 plus
robr57
Post by robr57 »
Ok thanks, submitted request.
wsnoordbergum
I guess the stand alone version will not be available to me anyways I have to do with the built in version on the Nano SD platform.
I got the graphs working, as I can use the http request of the Nano SD, and use the admin.meteobridge.com URL
But is there a way of getting the history data to the PWS2 directory of the Nano SD?
I've got csv data of 2017, 2018,2019 and 2020.
In the stand alone I can just copy these to the mbcharts directory, but I haven't got the stand alone version.....
Cheers, wsNoordbergum
9.34 version freely available last few weeks https://weather34.com/homeweatherstatio ... 4-934.html
the 9.34 version supports languages no password required to download. probably more suited for you. internal nanosd version is a question for Boris i dont get involved in internal version i would hate to misadvise someone and nanosd unit became bricked .
robr57
Post by robr57 »
Weather34 template did not work , fix found.
Hi, I could net get Weather34 to work on my webserver (Synology NAS) with PHP 7.4.3 and Nginx and all required extension enabled.
After some debugging I found a solution :
In common.php, I got an error : “Fatal error: Call to undefined function mb_regex_encoding()” although mbstring is enabled and loaded.
As I could not see why mb_regex_encoding('UTF-8') is required, I removed this call from common.php. This fixed the problem.
Any reason why this function is in common.php ?
been there for years(2016) check mbstring extension is properly enabled in your PHP install cant help much with NAS its been problematic over the years often left to end user to resolve has I dont have the experience . its a part of encoding language strings.
I have a problem, with the sun/moon modul:
Can I get a fix for that?
ToTo wrote: Mon Dec 14, 2020 10:41 pm I have a problem, with the sun/moon modul:
good morning if I could replicate I could help , but Im at your site now and I don't see that . any specific browser type ? 9.34 if issue persists its always been there nothing changed in 9.34 since release of the Aurora version.
Screenshot at Dec 15 09-20-58-1.jpg (273.41 KiB) Viewed 7766 times
