My new Raspberry Pi 4 - AWEKAS upload issue ** solved **
captgadget
- Expert Boarder
I have everything working except AWEKAS. I've checked the config file and the user ID and Password are correct so I'm wondering if there might a bug in the program somewhere. I can log in to the AWEKAS webpage just fine with the same credentials.
UPDATE - New Firmware Released:
viewtopic.php?p=36060#p36060
Re: My new Raspberry Pi 4 up and running
Boris,
Please have a look at MB code in the Pi image regarding AWEKAS upload. I can upload to AWEKAS with my Meteobridge (MR3020) using captgadget's credentials. I've remoted in and doubled checked everything was correct with captgadget's configuration. Downloaded a Meteobridge config backup and looked at the config file. Data was being saved correctly with all the xawekas entries. Tried erasing all xwekas entries from the config file and restoring to the Pi. Then newly entered in username and password for AWEKAS and it still didn't work....still get red X's.
I'm also an administrator at AWEKAS and I reset the password thinking that there might be a problem with the AWEKAS account. One of the passwords that we were using had ! character in the password. Thinking that maybe the Meteobridge may not like that character the password was changed and replaced ! with - (dash) and it still doesn't work. There are no problems with the AWEKAS account as we can log into the user's web portal. And as I said the current password does work when uploading with a Meteobridge MR3020.
I'd be curious to know if anyone with a Meteobridge Raspberry Pi is able to upload to AWEKAS. The Pi being used is a 4B.
Thanks!
George
Thanks!
George
Meteobridge RPI | GW1000
Confirmed:
Can not upload to Awekas using my credentials on a Rapsberry 4B
Also created an extra account => no luck either
See attached screenshot.
RAM: 1903 MB total, 1738 MB free (8% used)
Storage: WD SLC, 14.6 GB total, 14.4 GB free (1% used, 10.0 yrs)
SW Version: Meteobridge 5.0 (Nov 20 2020, build 1511), FW 1.3
Uptime: 23 hours, 8 minutes Buffer: 1 items (0%)See attached screenshot.
- awekas.jpeg (101.98 KiB) Viewed 4951 times
Re: My new Raspberry Pi 4 - AWEKAS upload issue
Temporary Solution:
UPDATE:** Please continue reading this thread as a new firmware makes this temporary solution unnecessary **
Thank you Wim for confirming. In the mean time a temporary fix is to use WU manually crafted HTTP upload format as AWEKAS does support the WU protocol also. This is complicated and requires knowledge of the WU protocol formatting. I could piece it together but by the time I do that I know Boris will have fixed this bug.
EDIT: Well I had some time to attempt the creation of this manual HTTP upload. Here it is. [s]But I've not tested it. It should work though.[/s]
UPDATE: TESTED and it works!
Add this to your MB Services / Events as an HTTP upload and set to appropriate interval for your account type (don't forget to edit in your AWEKAS username and password for the XXXXX's):
Success = OK
If you have UV then this requires manual editing to include those!
Hopefully we'll see an update soon from Boris.
https://ws.awekas.at/weatherstation/updateweatherstation.php?ID=XXXXXXXXX&PASSWORD=XXXXXX&dateutc=now&winddir=[wind0dir-avg1]&windspeedmph=[wind0wind-avg1=mph]&windgustmph=[wind0wind-max10=mph]&tempf=[th0temp-act=F]&rainin=[rain0total-daysum=in.2]&baromin=[thb0seapress-act=inHg.2]&dewptf=[th0dew-act=F]&humidity=[thb0hum-act]&softwaretype=ManualHTTP&action=updateraw
captgadget
- Expert Boarder
Except in Raspberry Pi 4 our only option is HTTP Request. No HTTP Upload and no way to set the time interval. At least I can't see it.
captgadget
- Expert Boarder
I'm wrong!!!!! But still no dice! I don't get a success. This is what I get:Event #01 has been triggered manually
- Screen Shot 2020-11-23 at 4.26.49 PM.png (121.83 KiB) Viewed 4792 times
You have to enter in OK into the Success field, then click Save. The purpose of this field is to tell the MB what is the response to expect back from the AWEKAS server if the upload was successful. Every website may have a different Success message to look for. With WU for example the response for Success is SUCCESS in all caps. This is how the MB knows to put in a green check mark or not after an upload.
Copy my code above again. I had a typo in the code. Make sure it says at the end action=updateraw as before it incorrectly had an extra "w" at the end.
captgadget
- Expert Boarder
I got successfully reloaded this time
captgadget
- Expert Boarder
Not working
- Screen Shot 2020-11-24 at 9.21.58 AM.png (183.79 KiB) Viewed 4736 times
- Screen Shot 2020-11-24 at 9.20.50 AM.png (236.49 KiB) Viewed 4736 times
AWEKAS upload problem on MB RPI is solved with just released update. Thanks for spotting this!
Root cause was a wrong endianess of md5 computation on RPI which prevented uploads to AWEKAS. Unfortunately, this fix also invalidates the licenses of Meteobridge RPIs which were given new or transferred licenses before and including Nov 24,2020. If you are impacted, please drop a note to "info(at)meteobridge.com" including the MAC of your Meteobridge to have this manually fixed by me. Just about 10 users are impacted, so not a big deal for doing a manual fix. Nevertheless, I am sorry for the inconvenience.
captgadget
- Expert Boarder
Not sure if I understand correctly. My license runs through 11-05-2022 so does that mean I'm affected?
Yes you are. All licenses [that were issued] for the RPI version up until November 24 have to be redone by admin.captgadget wrote: Tue Nov 24, 2020 10:56 pm Not sure if I understand correctly. My license runs through 11-05-2022 so does that mean I'm affected?
Just reboot and go to the licence tab.
Then note down the mac address from the system tab and sent the mail as requested by admin.
I was the first one when testing the fix for Awekas.
Which now works OK.
- awekas.jpeg (57.98 KiB) Viewed 4713 times
If you are running a licensed Meteobridge RPI, please send your MAC to "info(at)meteobridge.com". Only thing you need to do afterwards is to do a reboot.captgadget wrote: Tue Nov 24, 2020 10:56 pm Not sure if I understand correctly. My license runs through 11-05-2022 so does that mean I'm affected?
captgadget
- Expert Boarder
Re: My new Raspberry Pi 4 - AWEKAS upload issue ** solved **
I've rebooted a couple of times but the license is still blank.
