Luftdaten Data
woolfg
Luftdaten Data
Post by woolfg »
Hi
I see that the latest Meteobridge Pro update adds support for the Luftdaten Air Quality sensor
I was just wondering how this is configured . I have my sensor connected to a Raspberry Pi - do I just enter the IP of the Pi or is there more to it
many thanks
Graham
Re: Luftdaten Data
When you run SW that reports data in the defined JSON format when called with URL "http://x.x.x.x/data.json" you are fine, otherwise out of luck. Meteobridge cannot adapt to every individual home-brew approach.
woolfg
Re: Luftdaten Data
Post by woolfg »
Hi
Thanks - I have a file like that but when I add the station to Meteobridge it stops all uploads
Graham
Re: Luftdaten Data
woolfg wrote: Sat Nov 28, 2020 1:26 pm I have a file like that but when I add the station to Meteobridge it stops all uploads
FIle? Uploads? No idea what you mean. Could you please a bit more explicit and provide evidences?
woolfg
Re: Luftdaten Data
Post by woolfg »
Hi
I have a file at http://xxx.xxx.x.xxx/data.json
I have added the above ip as a new station into Meteobridge Pro
Then when I save the station after about 5 minutes the Meteobridge goes offline .This s the message
logger (28.11.2020 12:30:46): connect station 9 (System Data via Plug-in).
logger (28.11.2020 12:30:47): child process received termination signal (11) in functions: termination_handler < forward < chars_avail < process_data < handle_data < set_basic_timeout < forward < chars_avail < process_data < handle_data < set_basic_timeout < forward < chars_avail < process_data < handle_data < set_basic_timeout < forward < chars_avail < process_data < handle_data < set_b...
This is a sample of my data.json file
"time": "2020.11.26 19:00:35"}, {"pm10": 8.2, "pm25": 5.5, "time": "2020.11.26 19:30:34"}, {"pm25": 4.9, "pm10": 7.9, "time": "2020.11.26 20:00:35"}, {"pm10": 8.1, "pm25": 4.4, "time": "2020.11.26 20:30:35"}, {"pm25": 3.9, "pm10": 7.8, "time": "2020.11.26 21:00:34"}, {"pm10": 7.1, "pm25": 3.9, "time": "2020.11.26 22:00:35"}, {"pm25": 3.8, "pm10": 6.2, "time": "2020.11.26 22:30:35"}, {"pm10": 4.7, "pm25": 3.1, "time": "2020.11.26 23:00:35"}, {"pm25": 2.9, "pm10": 4.1, "time": "2020.11.26 23:30:34"}, {"pm10": 3.7, "pm25": 2.8, "time": "2020.11.27 00:00:35"}, {"pm25": 2.3, "pm10": 3.3, "time": "2020.11.27 01:00:35"}, {"pm10": 3.6, "pm25": 2.6, "time": "2020.11.27 01:30:35"}, {"pm25": 2.4, "pm10": 3.3, "time": "2020.11.27 02:00:34"}, {"pm10": 3.4, "pm25": 2.2, "time": "2020.11.27 03:00:35"}, {"pm25": 2.1, "pm10": 2.8, "time": "2020.11.27 03:30:35"}, {"pm10": 2.5, "pm25": 1.8, "time": "2020.11.27 04:00:34"}, {"pm25": 1.6, "pm10": 1.7, "time": "2020.11.27 05:00:35"}, {"pm10": 1.7, "pm25": 1.5, "time": "2020.11.27 05:30:35"}, {"pm25": 1.5, "pm10": 2.0, "time": "2020.11.27 06:30:34"}, {"pm10": 1.8, "pm25": 1.4, "time": "2020.11.27 07:00:35"}, {"pm25": 1.4, "pm10": 1.6, "time": "2020.11.27 07:30:35"}, {"pm10": 1.4, "pm25": 1.3, "time": "2020.11.27 08:00:35"}, {"pm25": 2.1, "pm10": 3.0, "time": "2020.11.27 08:30:35"}, {"pm10": 5.3, "pm25": 3.0, "time": "2020.11.27 09:30:35"}, {"pm25": 4.6, "pm10": 5.9, "time": "2020.11.27 10:00:35"}, {"pm10": 7.6, "pm25": 5.0, "time": "2020.11.27 10:30:35"}, {"pm25": 3.9, "pm10": 6.8, "time": "2020.11.27 11:00:34"}, {"pm10": 5.1, "pm25": 2.7, "time": "2020.11.27 12:00:35"}, {"pm25": 2.7, "pm10": 4.5, "time": "2020.11.27 12:30:35"}, {"pm10": 3.7, "pm25": 2.2, "time": "2020.11.27 13:00:34"}, {"pm25": 2.8, "pm10": 4.8, "time": "2020.11.27 14:00:35"}, {"pm10": 4.4, "pm25": 2.7, "time": "2020.11.27 14:30:35"}, {"pm25": 2.8, "pm10": 4.5, "time": "2020.11.27 15:00:34"}, {"pm10": 4.0, "pm25": 2.5, "time": "2020.11.27 15:30:35"}, {"pm25": 2.9, "pm10": 4.7, "time": "2020.11.27 16:00:35"}, {"pm10": 7.9, "pm25": 6.5, "time": "2020.11.27 19:00:35"}, {"pm25": 5.8, "pm10": 7.3, "time": "2020.11.27 19:30:34"}, {"pm10": 9.3, "pm25": 6.5, "time": "2020.11.27 20:30:35"}, {"pm25": 6.4, "pm10": 9.1, "time": "2020.11.27 21:00:35"}, {"pm10": 8.2, "pm25": 6.1, "time": "2020.11.27 21:30:34"}, {"pm25": 5.2, "pm10": 7.2, "time": "2020.11.27 22:30:35"}, {"pm10": 6.6, "pm25": 5.2, "time": "2020.11.27 23:00:35"}, {"pm25": 4.9, "pm10": 6.3,
Hope that helps
Graham
Re: Luftdaten Data
Thanks, this helps a lot. Could you please provide me a remote login, as I would like to get deeper into that.
Anyway the data is not what Meteobridge expects and is not in the Luftdaten format Wim did provide. Which software are you using that resonds with this json string?
woolfg
Re: Luftdaten Data
Post by woolfg »
Hi
I have sent a PM with login details
The json file is written by a python script
I actually have 3 AQ sensors a Purple Air and Davis for outside and a Luftdaten for inside
Graham
Re: Luftdaten Data
Thanks for providing me access. Currently I can't see a definition for a Luftdaten station. Can you please add to make me test?
woolfg
Re: Luftdaten Data
Post by woolfg »
Hi
I have done that
I dont want to leave it there too long though as my meteobridge will soon stop sending data
Willyou let me know when you are done
Graham
woolfg
Re: Luftdaten Data
Post by woolfg »
Hi
You can delete the Luftdaten station when you have finished if you like
Then I will know you have finished
Graham
