Rpi problem history
Re: Rpi problem history
norvegese wrote: Mon Nov 30, 2020 7:28 pm This happens ad son as press
You are remotly accessing your Meteobridge?
Not at the same home where the Meteobridge is located?
norvegese
Post by norvegese »
You are logging in remotely
norvegese wrote: Mon Nov 30, 2020 7:42 pm You are logging in remotely
Then I think it is a problem somewhere in the network.
Not in the Meteobridge directly as you can connect to all other tabs.
But there is only one person who can check that and that is admin.
I can only inspect this if there is a way for me to experience this via remote access. Any chance?
norvegese
Post by norvegese »
I could privately send you the link to log in remotely
yes, please do.
Solved with just released update.
norvegese
Post by norvegese »
admin i don't know how but you solved the problem .thanks
norvegese
Post by norvegese »
last important thing is it possible to update the rain all year without changing the one for the month? data recording starts from November 29th
norvegese wrote: Wed Dec 02, 2020 9:33 am last important thing is it possible to update the rain all year without changing the one for the month? data recording starts from November 29th
No, all data is aggregated from hourly data. You have to edit on this level to impact daily, monthly, yearly results. Otherwise data would be inconsistent.
