Newbie - only dataNNnum channels visible - **solved**
JayMacofOz
Post by JayMacofOz »
Hi all,
Love the Forum activity. Afraid that I have to dumb all the intelligent discussions down with this newbie problem. Hoping someone can provide some guidance. Will be powering down the whole unit (remove power cable and batteries) tonight to see if this does anything.
The Davis Vantage Pro 2 system (6152AU) is functioning well with all data being displayed on the console. Nano SD is connected to the Wifi with a fixed IP address.
Have connected and configured my MB Nano SD into the Vantage Pro console per the instructions. Have now done this twice.
Setup in VPro2
Setup in VPro2
JayMacofOz - MB Nano SD in Pro 2 Console - Station - Primary Station.png (143.07 KiB) Viewed 1019 times
I am currently only able to see the dataNNnum channels.
Sensor mapping
Sensor mapping
JayMacofOz - MB Nano SD in Pro 2 Console - Station - Mapping.png (62.4 KiB) Viewed 1019 times
Data is being streamed to WU without issue, but it is limited to this data only.
JayMacofOz - MB Nano SD in Pro 2 Console - Live Data - Upload Status.png (45.35 KiB) Viewed 1019 times
JayMacofOz - MB Nano SD in Pro 2 Console - Live Data - Raw Sensor Data.png (70.2 KiB) Viewed 1019 times
Thanks in advance for your thoughts.
Best regards,
Jason
galfert
Re: Newbie - only dataNNnum channels visible
Post by galfert »
The proper way to connect the NANO is to first power everything down, remove batteries. The data you are seeing are internal functions of the NANO (statistics).
Meteobridge RPI | GW1000
JayMacofOz
Powered everything down and all working brilliantly! Many thanks.
