MB on RPi4 - restore from USB (and SD card) not possible. **solved**
Gyvate
Post by Gyvate »
I cannot restore the database on the RPi4
symptoms:
a) the backup files on the USB stick are not visible/selectable
b) if manually provided with backup database, the restore fails saying not enough free space available.
More details at
https://www.wxforum.net/index.php?topic=41198.0
system configuration:
Re: MB on RPi4 - restore from USB (and SD card) not possible
just released version allows restore of backups from USB stick.
Gyvate
Re: MB on RPi4 - restore from USB (and SD card) not possible. **solved**
Post by Gyvate »
Tested and works - backups on USB stick now visible and selectable.
And the restore goes through without complaints.
Thanks, Boris !
JohnsPro
Post by JohnsPro »
Group,
I did attempt to update from my Meteobridge PRO to the Meteobridge PI and unfortunately it doesn't appear that the data updated.
The Meteobridge PRO only has hour data and the Meteobridge PI has both hour data and minute data. The attempt to restore also deleted all of the minute data that the Meteobridge PI had collected. I was able to restore the original database of both hour data and minute data that was backed up from the Meteobridge PI successfully.
Thank You John
Gyvate
Post by Gyvate »
Hi John
same observation here - I did a restore as an initial data load (having set the per minute data option with persistent data for all sensors before the import/restore) and the per minute data from the MB Pro got lost and are only available from the restore date onward.
But we need to open a new thread as this one is marked ** solved**.
