Meteobridge is crashing all the time
WETRHE
Post by WETRHE »
since latest FW Update the Meteobridge is crashing and rebooting continuously.
Sometimes it is working stable for several minutes and then it crashes again and reboots.
Is there any way to find out why?
Thanks!
galfert
Re: Meteobridge is crashing all the time
Post by galfert »
You can start by inspecting the Logging messages user System / Logging.
Meteobridge RPI | GW1000
WETRHE
Post by WETRHE »
I noticed, that something must have changed after the last FW Update:
I have had the following configuration, which worked fine for me (pls. see screenshots):
t0!1temp was matched to th1temp:
In WD Live (Clientraw) Extra#1 was matched to t1 and th1 (which is indeed the same data as t1) was matched to Bodentemp:
But NOW, after the FW change, "th1" for Bodentemp is missing somehow:
As I am uploading the data to several services (wunderground, windy etc.) and to my SQL Database, to Twitter and sending them via Email, I guess, that THIS might be the reason for the crashes. After deleting all upload services, Meteobridge seems to run more or less stable again.
But the question is now: WHY can't I chose th1 for Bodentemp anymore? This worked perfectly before for month!?
WETRHE
Post by WETRHE »
Until to this latest FW Update, it was possible to have a Soil Temperature in the clientraw.txt
Now these figures are missing, I really need data for Soil Temperature!
