error while waiting for data from weather stations **solved**
andlil
Post by andlil »
Hello!
I'm having problems for the last few days with the logger restarting due to "error while waiting for data from weather stations", since build 1921.
edit, sysinfo:
Platform:	Raspberry Pi 3 Model B
RAM:	941 MB total, 819 MB free (12% used)
Storage:	WD SLC, 7.1 GB total, 7.0 GB free (1% used, 548.0 yrs)
SW Version:	Meteobridge 5.1 (Jan 24 2021, build 1921), FW 1.3
Uptime:	2 days, 5 hours, 45 minutes    Buffer: 3 items (0%)
Has there been any changes in the logging that could have introduced a bug?
Best regards
//A
logger (27.01.2021 07:21:24): sensors are now providing data.
logger (27.01.2021 07:21:24): services started.
logger (27.01.2021 07:21:58): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (27.01.2021 20:21:33): error while waiting for data from weather stations
logger (27.01.2021 20:21:33): disconnect station 0 (Vantage): wrap-up
logger (27.01.2021 20:21:33): disconnect station 9 (System Data): wrap-up
logger (27.01.2021 20:21:33): databases disconnected.
logger (27.01.2021 20:21:33): data logger stopped.
logger (27.01.2021 20:21:33): databases connected. Update interval 3600 seconds.
logger (27.01.2021 20:21:33): data logger (version 5.1e, build 1921) started.
logger (27.01.2021 20:21:34): connect station 0 (Vantage via USB serial).
logger (27.01.2021 20:21:34): connect station 9 (System Data via Plug-in).
logger (27.01.2021 20:21:34): station 0 (Vantage), wakeup sent.
logger (27.01.2021 20:21:35): station 0 (Vantage), no need to update console date/time.
logger (27.01.2021 20:21:35): station 0 (Vantage), setup script executed.
logger (27.01.2021 20:21:35): station 0 (Vantage), internal logger activated.
logger (27.01.2021 20:21:35): station 0 (Vantage), syncing.
logger (27.01.2021 20:21:37): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (27.01.2021 20:21:37): services paused.
logger (27.01.2021 20:21:45): station 0 (Vantage), gettime request sent.
logger (27.01.2021 20:21:45): station 0 (Vantage), no Vantage time offset.
logger (27.01.2021 20:21:45): station 0 (Vantage), eeprom request sent.
logger (27.01.2021 20:21:45): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.01.2021 20:21:45): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (27.01.2021 20:21:45): station 0 (Vantage), firmware version request sent.
logger (27.01.2021 20:21:45): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (27.01.2021 20:21:45): station 0 (Vantage), no reading of Vantage's internal logger.
logger (27.01.2021 20:21:45): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (27.01.2021 20:21:45): sensors are now providing data.
logger (27.01.2021 20:21:45): services started.
logger (27.01.2021 23:30:03): error while waiting for data from weather stations
logger (27.01.2021 23:30:03): disconnect station 0 (Vantage): wrap-up
logger (27.01.2021 23:30:03): disconnect station 9 (System Data): wrap-up
logger (27.01.2021 23:30:03): databases disconnected.
logger (27.01.2021 23:30:03): data logger stopped.
logger (27.01.2021 23:30:03): databases connected. Update interval 3600 seconds.
logger (27.01.2021 23:30:03): data logger (version 5.1e, build 1921) started.
logger (27.01.2021 23:30:04): connect station 0 (Vantage via USB serial).
logger (27.01.2021 23:30:04): connect station 9 (System Data via Plug-in).
logger (27.01.2021 23:30:04): station 0 (Vantage), wakeup sent.
logger (27.01.2021 23:30:06): station 0 (Vantage), no need to update console date/time.
logger (27.01.2021 23:30:06): station 0 (Vantage), setup script executed.
logger (27.01.2021 23:30:06): station 0 (Vantage), internal logger activated.
logger (27.01.2021 23:30:06): station 0 (Vantage), syncing.
logger (27.01.2021 23:30:07): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (27.01.2021 23:30:07): services paused.
logger (27.01.2021 23:30:16): station 0 (Vantage), gettime request sent.
logger (27.01.2021 23:30:16): station 0 (Vantage), no Vantage time offset.
logger (27.01.2021 23:30:16): station 0 (Vantage), eeprom request sent.
logger (27.01.2021 23:30:16): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.01.2021 23:30:16): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (27.01.2021 23:30:16): station 0 (Vantage), firmware version request sent.
logger (27.01.2021 23:30:16): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (27.01.2021 23:30:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (27.01.2021 23:30:16): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (27.01.2021 23:30:16): sensors are now providing data.
logger (27.01.2021 23:30:16): services started.
backup (28.01.2021 00:00:07): backup media size is 14.8G (12.6G free).
backup (28.01.2021 00:00:19): backup completed: dbase-202101280000 (34.6M)
logger (28.01.2021 00:36:03): station 0 (Vantage), connection on port 22222 closed.
logger (28.01.2021 00:36:45): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (28.01.2021 23:20:37): error while waiting for data from weather stations
logger (28.01.2021 23:20:37): disconnect station 0 (Vantage): wrap-up
logger (28.01.2021 23:20:37): disconnect station 9 (System Data): wrap-up
logger (28.01.2021 23:20:37): databases disconnected.
logger (28.01.2021 23:20:37): data logger stopped.
logger (28.01.2021 23:20:37): databases connected. Update interval 3600 seconds.
logger (28.01.2021 23:20:37): data logger (version 5.1e, build 1921) started.
logger (28.01.2021 23:20:38): connect station 0 (Vantage via USB serial).
logger (28.01.2021 23:20:38): connect station 9 (System Data via Plug-in).
logger (28.01.2021 23:20:38): station 0 (Vantage), wakeup sent.
logger (28.01.2021 23:20:39): station 0 (Vantage), no need to update console date/time.
logger (28.01.2021 23:20:39): station 0 (Vantage), setup script executed.
logger (28.01.2021 23:20:39): station 0 (Vantage), internal logger activated.
logger (28.01.2021 23:20:39): station 0 (Vantage), syncing.
logger (28.01.2021 23:20:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.01.2021 23:20:41): services paused.
logger (28.01.2021 23:20:49): station 0 (Vantage), gettime request sent.
logger (28.01.2021 23:20:49): station 0 (Vantage), no Vantage time offset.
logger (28.01.2021 23:20:49): station 0 (Vantage), eeprom request sent.
logger (28.01.2021 23:20:49): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (28.01.2021 23:20:49): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (28.01.2021 23:20:49): station 0 (Vantage), firmware version request sent.
logger (28.01.2021 23:20:49): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (28.01.2021 23:20:49): station 0 (Vantage), no reading of Vantage's internal logger.
logger (28.01.2021 23:20:49): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (28.01.2021 23:20:49): sensors are now providing data.
logger (28.01.2021 23:20:49): services started.
logger (28.01.2021 23:36:05): error while waiting for data from weather stations
logger (28.01.2021 23:36:05): disconnect station 0 (Vantage): wrap-up
logger (28.01.2021 23:36:05): disconnect station 9 (System Data): wrap-up
logger (28.01.2021 23:36:05): databases disconnected.
logger (28.01.2021 23:36:05): data logger stopped.
logger (28.01.2021 23:36:05): databases connected. Update interval 3600 seconds.
logger (28.01.2021 23:36:05): data logger (version 5.1e, build 1921) started.
logger (28.01.2021 23:36:06): connect station 0 (Vantage via USB serial).
logger (28.01.2021 23:36:06): connect station 9 (System Data via Plug-in).
logger (28.01.2021 23:36:06): station 0 (Vantage), wakeup sent.
logger (28.01.2021 23:36:07): station 0 (Vantage), no need to update console date/time.
logger (28.01.2021 23:36:07): station 0 (Vantage), setup script executed.
logger (28.01.2021 23:36:07): station 0 (Vantage), internal logger activated.
logger (28.01.2021 23:36:07): station 0 (Vantage), syncing.
logger (28.01.2021 23:36:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.01.2021 23:36:09): services paused.
logger (28.01.2021 23:36:17): station 0 (Vantage), gettime request sent.
logger (28.01.2021 23:36:17): station 0 (Vantage), no Vantage time offset.
logger (28.01.2021 23:36:17): station 0 (Vantage), eeprom request sent.
logger (28.01.2021 23:36:17): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (28.01.2021 23:36:17): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (28.01.2021 23:36:17): station 0 (Vantage), firmware version request sent.
logger (28.01.2021 23:36:17): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (28.01.2021 23:36:17): station 0 (Vantage), no reading of Vantage's internal logger.
logger (28.01.2021 23:36:17): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (28.01.2021 23:36:17): sensors are now providing data.
logger (28.01.2021 23:36:17): services started.
backup (29.01.2021 00:00:08): backup media size is 14.8G (12.6G free).
backup (29.01.2021 00:00:18): backup completed: dbase-202101290000 (34.7M)
logger (29.01.2021 00:31:37): error while waiting for data from weather stations
logger (29.01.2021 00:31:37): disconnect station 0 (Vantage): wrap-up
logger (29.01.2021 00:31:37): disconnect station 9 (System Data): wrap-up
logger (29.01.2021 00:31:37): databases disconnected.
logger (29.01.2021 00:31:37): data logger stopped.
logger (29.01.2021 00:31:37): databases connected. Update interval 3600 seconds.
logger (29.01.2021 00:31:37): data logger (version 5.1e, build 1921) started.
logger (29.01.2021 00:31:38): connect station 0 (Vantage via USB serial).
logger (29.01.2021 00:31:38): connect station 9 (System Data via Plug-in).
logger (29.01.2021 00:31:38): station 0 (Vantage), wakeup sent.
logger (29.01.2021 00:31:39): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 00:31:39): station 0 (Vantage), setup script executed.
logger (29.01.2021 00:31:39): station 0 (Vantage), internal logger activated.
logger (29.01.2021 00:31:40): station 0 (Vantage), syncing.
logger (29.01.2021 00:31:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 00:31:41): services paused.
logger (29.01.2021 00:31:50): station 0 (Vantage), gettime request sent.
logger (29.01.2021 00:31:50): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 00:31:50): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 00:31:50): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 00:31:50): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 00:31:50): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 00:31:50): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 00:31:50): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 00:31:50): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 00:31:50): sensors are now providing data.
logger (29.01.2021 00:31:50): services started.
logger (29.01.2021 00:36:03): station 0 (Vantage), connection on port 22222 closed.
logger (29.01.2021 00:36:44): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 01:35:03): error while waiting for data from weather stations
logger (29.01.2021 01:35:03): disconnect station 0 (Vantage): wrap-up
logger (29.01.2021 01:35:03): disconnect station 9 (System Data): wrap-up
logger (29.01.2021 01:35:03): databases disconnected.
logger (29.01.2021 01:35:03): data logger stopped.
logger (29.01.2021 01:35:03): databases connected. Update interval 3600 seconds.
logger (29.01.2021 01:35:03): data logger (version 5.1e, build 1921) started.
logger (29.01.2021 01:35:04): connect station 0 (Vantage via USB serial).
logger (29.01.2021 01:35:04): connect station 9 (System Data via Plug-in).
logger (29.01.2021 01:35:04): station 0 (Vantage), wakeup sent.
logger (29.01.2021 01:35:06): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 01:35:06): station 0 (Vantage), setup script executed.
logger (29.01.2021 01:35:06): station 0 (Vantage), internal logger activated.
logger (29.01.2021 01:35:06): station 0 (Vantage), syncing.
logger (29.01.2021 01:35:07): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 01:35:07): services paused.
logger (29.01.2021 01:35:16): station 0 (Vantage), gettime request sent.
logger (29.01.2021 01:35:16): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 01:35:16): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 01:35:16): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 01:35:16): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 01:35:16): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 01:35:16): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 01:35:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 01:35:16): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 01:35:16): sensors are now providing data.
logger (29.01.2021 01:35:16): services started.
logger (29.01.2021 02:50:18): error while waiting for data from weather stations
logger (29.01.2021 02:50:18): disconnect station 0 (Vantage): wrap-up
logger (29.01.2021 02:50:18): disconnect station 9 (System Data): wrap-up
logger (29.01.2021 02:50:18): databases disconnected.
logger (29.01.2021 02:50:18): data logger stopped.
logger (29.01.2021 02:50:18): databases connected. Update interval 3600 seconds.
logger (29.01.2021 02:50:18): data logger (version 5.1e, build 1921) started.
logger (29.01.2021 02:50:19): connect station 0 (Vantage via USB serial).
logger (29.01.2021 02:50:19): connect station 9 (System Data via Plug-in).
logger (29.01.2021 02:50:19): station 0 (Vantage), wakeup sent.
logger (29.01.2021 02:50:20): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 02:50:20): station 0 (Vantage), setup script executed.
logger (29.01.2021 02:50:20): station 0 (Vantage), internal logger activated.
logger (29.01.2021 02:50:21): station 0 (Vantage), syncing.
logger (29.01.2021 02:50:22): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 02:50:22): services paused.
logger (29.01.2021 02:50:31): station 0 (Vantage), gettime request sent.
logger (29.01.2021 02:50:31): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 02:50:31): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 02:50:31): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 02:50:31): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 02:50:31): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 02:50:31): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 02:50:31): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 02:50:31): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 02:50:31): sensors are now providing data.
logger (29.01.2021 02:50:31): services started.
Gyvate
Re: error while waiting for data from weather stations
Post by Gyvate »
Hi
that's not a bug - it's a feature - seriously.
Nothing is lost, but it's the result of a mechanism to avoid spontaneous reboots due to temporary storage bottleneck situations (like a backup period).
On a heavily loaded MB Pro.
You don't really have a problem.
Unless you consider the messages in themselves as a problem. :wink:
andlil wrote: Fri Jan 29, 2021 9:08 am Hello!
Best regards
//A
same here i updated firmware for the first time in 10 months from 4.2 yesterday i now have pages and pages of logs hadnt seen anything for months and months my previous uptime was 10 months and 16 days also had to reboot multiple times yesterday has no data being sent or uploaded . im going to roll back if i can later. sometimes if aint broke dont fix it is so true..
Gyvate
Post by Gyvate »
weatherist34 wrote: Fri Jan 29, 2021 11:45 am
Best regards
//A
when you look closely at the log, you will notice that the logger restart occurs most of the time after a backup.
During backup the usage of memory and CPU is momentarily extremely high and causes with some MB Pro machines, who have a lot of sensors and record minute data for them, spontaneous reboots. The above message is an indirect sign of a change in storage management.
It shouldn't stop your data from being received, logged and archived.
If the latter is the case, then the implemented solution needs improvement.
I also have the restarts of the logger, but no data, no minute data even, is lost. All in the database.
andlil
Post by andlil »
Gyvate wrote: Fri Jan 29, 2021 11:04 am Hi
Interesting feature...
One unfortunate side effect is that any active alarms gets triggered again with every restart of the logger. Also, I have other software connected on port 22222 through the Meteobridge and that connection goes down when the logger restarts.
Perhaps it is time to fork a new version only for the RPi that doesn't suffer from the same bottlenecks as the MB Pro?
//A
andlil
Post by andlil »
Gyvate wrote: Fri Jan 29, 2021 11:57 am when you look closely at the log, you will notice that the logger restart occurs most of the time after a backup.
In my case the restart of the logger is never associated with backup or cpu intensive tasks. Max CPU is never above 29% and average CPU is only 1-4%.
Gyvate
Post by Gyvate »
andlil wrote: Fri Jan 29, 2021 12:10 pm
Did you check this on minute data in the history ?
Your numbers sound like you are running MB on a RPi and not on a MB Pro.
Not sure if on a RPi this feature is necessary ... On a MB Pro with many sensors and minute data it is.
andlil
Post by andlil »
Gyvate wrote: Fri Jan 29, 2021 1:27 pm Did you check this on minute data in the history ?
Sorry, I had the sysinfo in my first draft post but I must have deleted it, yes, it is a RPi and I added sysinfo to the first post.
//A
It rellay looks like a bug. I currently don't understand why the logger tends to restart in certain situations. I am on this, but still trying to understand why we have this.
andlil
Post by andlil »
admin wrote: Sat Jan 30, 2021 12:04 am It rellay looks like a bug. I currently don't understand why the logger tends to restart in certain situations. I am on this, but still trying to understand why we have this.
Thanks for looking into this, I rebooted to build 1941 and within minutes I had a logger restart.
database (29.01.2021 21:44:58): process started.
database (29.01.2021 21:44:58): Content of RAM database restored.
database (29.01.2021 21:45:00): database sync done (28 tables, 74/2240 writes).
wnetd  (29.01.2021 21:45:01): process started.
system (29.01.2021 21:45:01): start of logging process initiated.
logger (29.01.2021 21:45:01): databases connected. Update interval 3600 seconds.
logger (29.01.2021 21:45:01): data logger (version 5.1e, build 1941) started.
wnetd  (29.01.2021 21:45:01): send data thread started (pid:2742 tid:2744)
logger (29.01.2021 21:45:01): connect station 0 (Vantage via USB serial).
logger (29.01.2021 21:45:01): connect station 9 (System Data via Plug-in).
logger (29.01.2021 21:45:01): station 0 (Vantage), wakeup sent.
logger (29.01.2021 21:45:04): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 21:45:04): services paused.
logger (29.01.2021 21:45:05): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 21:45:05): station 0 (Vantage), setup script executed.
logger (29.01.2021 21:45:05): station 0 (Vantage), internal logger activated.
logger (29.01.2021 21:45:06): station 0 (Vantage), syncing.
logger (29.01.2021 21:45:16): station 0 (Vantage), gettime request sent.
logger (29.01.2021 21:45:16): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 21:45:16): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 21:45:16): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 21:45:16): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 21:45:16): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 21:45:16): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 21:45:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 21:45:20): sensors are now providing data.
logger (29.01.2021 21:45:20): services started.
logger (29.01.2021 21:45:53): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 21:49:15): error while waiting for data from weather stations
logger (29.01.2021 21:49:15): disconnect station 0 (Vantage): wrap-up
logger (29.01.2021 21:49:15): disconnect station 9 (System Data): wrap-up
logger (29.01.2021 21:49:15): databases disconnected.
logger (29.01.2021 21:49:15): data logger stopped.
logger (29.01.2021 21:49:15): databases connected. Update interval 3600 seconds.
logger (29.01.2021 21:49:15): data logger (version 5.1e, build 1941) started.
logger (29.01.2021 21:49:16): connect station 0 (Vantage via USB serial).
logger (29.01.2021 21:49:16): connect station 9 (System Data via Plug-in).
logger (29.01.2021 21:49:16): station 0 (Vantage), wakeup sent.
logger (29.01.2021 21:49:17): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 21:49:17): station 0 (Vantage), setup script executed.
logger (29.01.2021 21:49:17): station 0 (Vantage), internal logger activated.
logger (29.01.2021 21:49:18): station 0 (Vantage), syncing.
logger (29.01.2021 21:49:19): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 21:49:19): services paused.
logger (29.01.2021 21:49:28): station 0 (Vantage), gettime request sent.
logger (29.01.2021 21:49:28): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 21:49:28): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 21:49:28): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 21:49:28): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 21:49:28): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 21:49:28): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 21:49:28): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 21:49:28): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 21:49:28): sensors are now providing data.
logger (29.01.2021 21:49:28): services started.
I found an unwanted side effect of shortly added feature to automatically reload template files if not successfully loaded on boot. Bug should be fixed with just released update.
andlil
Post by andlil »
admin wrote: Sat Jan 30, 2021 2:16 am I found an unwanted side effect of shortly added feature to automatically reload template files if not successfully loaded on boot. Bug should be fixed with just released update.
Great, rebooting and keeping my fingers crossed :-)
