I'm having problems for the last few days with the logger restarting due to "error while waiting for data from weather stations", since build 1921.
edit, sysinfo:
Platform: Raspberry Pi 3 Model B
RAM: 941 MB total, 819 MB free (12% used)
Storage: WD SLC, 7.1 GB total, 7.0 GB free (1% used, 548.0 yrs)
SW Version: Meteobridge 5.1 (Jan 24 2021, build 1921), FW 1.3
Uptime: 2 days, 5 hours, 45 minutes Buffer: 3 items (0%)
Best regards
//A
logger (27.01.2021 07:21:24): sensors are now providing data.
logger (27.01.2021 07:21:24): services started.
logger (27.01.2021 07:21:58): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (27.01.2021 20:21:33): error while waiting for data from weather stations
logger (27.01.2021 20:21:33): disconnect station 0 (Vantage): wrap-up
logger (27.01.2021 20:21:33): disconnect station 9 (System Data): wrap-up
logger (27.01.2021 20:21:33): databases disconnected.
logger (27.01.2021 20:21:33): data logger stopped.
logger (27.01.2021 20:21:33): databases connected. Update interval 3600 seconds.
logger (27.01.2021 20:21:33): data logger (version 5.1e, build 1921) started.
logger (27.01.2021 20:21:34): connect station 0 (Vantage via USB serial).
logger (27.01.2021 20:21:34): connect station 9 (System Data via Plug-in).
logger (27.01.2021 20:21:34): station 0 (Vantage), wakeup sent.
logger (27.01.2021 20:21:35): station 0 (Vantage), no need to update console date/time.
logger (27.01.2021 20:21:35): station 0 (Vantage), setup script executed.
logger (27.01.2021 20:21:35): station 0 (Vantage), internal logger activated.
logger (27.01.2021 20:21:35): station 0 (Vantage), syncing.
logger (27.01.2021 20:21:37): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (27.01.2021 20:21:37): services paused.
logger (27.01.2021 20:21:45): station 0 (Vantage), gettime request sent.
logger (27.01.2021 20:21:45): station 0 (Vantage), no Vantage time offset.
logger (27.01.2021 20:21:45): station 0 (Vantage), eeprom request sent.
logger (27.01.2021 20:21:45): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.01.2021 20:21:45): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (27.01.2021 20:21:45): station 0 (Vantage), firmware version request sent.
logger (27.01.2021 20:21:45): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (27.01.2021 20:21:45): station 0 (Vantage), no reading of Vantage's internal logger.
logger (27.01.2021 20:21:45): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (27.01.2021 20:21:45): sensors are now providing data.
logger (27.01.2021 20:21:45): services started.
logger (27.01.2021 23:30:03): error while waiting for data from weather stations
logger (27.01.2021 23:30:03): disconnect station 0 (Vantage): wrap-up
logger (27.01.2021 23:30:03): disconnect station 9 (System Data): wrap-up
logger (27.01.2021 23:30:03): databases disconnected.
logger (27.01.2021 23:30:03): data logger stopped.
logger (27.01.2021 23:30:03): databases connected. Update interval 3600 seconds.
logger (27.01.2021 23:30:03): data logger (version 5.1e, build 1921) started.
logger (27.01.2021 23:30:04): connect station 0 (Vantage via USB serial).
logger (27.01.2021 23:30:04): connect station 9 (System Data via Plug-in).
logger (27.01.2021 23:30:04): station 0 (Vantage), wakeup sent.
logger (27.01.2021 23:30:06): station 0 (Vantage), no need to update console date/time.
logger (27.01.2021 23:30:06): station 0 (Vantage), setup script executed.
logger (27.01.2021 23:30:06): station 0 (Vantage), internal logger activated.
logger (27.01.2021 23:30:06): station 0 (Vantage), syncing.
logger (27.01.2021 23:30:07): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (27.01.2021 23:30:07): services paused.
logger (27.01.2021 23:30:16): station 0 (Vantage), gettime request sent.
logger (27.01.2021 23:30:16): station 0 (Vantage), no Vantage time offset.
logger (27.01.2021 23:30:16): station 0 (Vantage), eeprom request sent.
logger (27.01.2021 23:30:16): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.01.2021 23:30:16): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (27.01.2021 23:30:16): station 0 (Vantage), firmware version request sent.
logger (27.01.2021 23:30:16): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (27.01.2021 23:30:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (27.01.2021 23:30:16): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (27.01.2021 23:30:16): sensors are now providing data.
logger (27.01.2021 23:30:16): services started.
backup (28.01.2021 00:00:07): backup media size is 14.8G (12.6G free).
backup (28.01.2021 00:00:19): backup completed: dbase-202101280000 (34.6M)
logger (28.01.2021 00:36:03): station 0 (Vantage), connection on port 22222 closed.
logger (28.01.2021 00:36:45): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (28.01.2021 23:20:37): error while waiting for data from weather stations
logger (28.01.2021 23:20:37): disconnect station 0 (Vantage): wrap-up
logger (28.01.2021 23:20:37): disconnect station 9 (System Data): wrap-up
logger (28.01.2021 23:20:37): databases disconnected.
logger (28.01.2021 23:20:37): data logger stopped.
logger (28.01.2021 23:20:37): databases connected. Update interval 3600 seconds.
logger (28.01.2021 23:20:37): data logger (version 5.1e, build 1921) started.
logger (28.01.2021 23:20:38): connect station 0 (Vantage via USB serial).
logger (28.01.2021 23:20:38): connect station 9 (System Data via Plug-in).
logger (28.01.2021 23:20:38): station 0 (Vantage), wakeup sent.
logger (28.01.2021 23:20:39): station 0 (Vantage), no need to update console date/time.
logger (28.01.2021 23:20:39): station 0 (Vantage), setup script executed.
logger (28.01.2021 23:20:39): station 0 (Vantage), internal logger activated.
logger (28.01.2021 23:20:39): station 0 (Vantage), syncing.
logger (28.01.2021 23:20:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.01.2021 23:20:41): services paused.
logger (28.01.2021 23:20:49): station 0 (Vantage), gettime request sent.
logger (28.01.2021 23:20:49): station 0 (Vantage), no Vantage time offset.
logger (28.01.2021 23:20:49): station 0 (Vantage), eeprom request sent.
logger (28.01.2021 23:20:49): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (28.01.2021 23:20:49): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (28.01.2021 23:20:49): station 0 (Vantage), firmware version request sent.
logger (28.01.2021 23:20:49): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (28.01.2021 23:20:49): station 0 (Vantage), no reading of Vantage's internal logger.
logger (28.01.2021 23:20:49): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (28.01.2021 23:20:49): sensors are now providing data.
logger (28.01.2021 23:20:49): services started.
logger (28.01.2021 23:36:05): error while waiting for data from weather stations
logger (28.01.2021 23:36:05): disconnect station 0 (Vantage): wrap-up
logger (28.01.2021 23:36:05): disconnect station 9 (System Data): wrap-up
logger (28.01.2021 23:36:05): databases disconnected.
logger (28.01.2021 23:36:05): data logger stopped.
logger (28.01.2021 23:36:05): databases connected. Update interval 3600 seconds.
logger (28.01.2021 23:36:05): data logger (version 5.1e, build 1921) started.
logger (28.01.2021 23:36:06): connect station 0 (Vantage via USB serial).
logger (28.01.2021 23:36:06): connect station 9 (System Data via Plug-in).
logger (28.01.2021 23:36:06): station 0 (Vantage), wakeup sent.
logger (28.01.2021 23:36:07): station 0 (Vantage), no need to update console date/time.
logger (28.01.2021 23:36:07): station 0 (Vantage), setup script executed.
logger (28.01.2021 23:36:07): station 0 (Vantage), internal logger activated.
logger (28.01.2021 23:36:07): station 0 (Vantage), syncing.
logger (28.01.2021 23:36:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.01.2021 23:36:09): services paused.
logger (28.01.2021 23:36:17): station 0 (Vantage), gettime request sent.
logger (28.01.2021 23:36:17): station 0 (Vantage), no Vantage time offset.
logger (28.01.2021 23:36:17): station 0 (Vantage), eeprom request sent.
logger (28.01.2021 23:36:17): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (28.01.2021 23:36:17): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (28.01.2021 23:36:17): station 0 (Vantage), firmware version request sent.
logger (28.01.2021 23:36:17): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (28.01.2021 23:36:17): station 0 (Vantage), no reading of Vantage's internal logger.
logger (28.01.2021 23:36:17): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (28.01.2021 23:36:17): sensors are now providing data.
logger (28.01.2021 23:36:17): services started.
backup (29.01.2021 00:00:08): backup media size is 14.8G (12.6G free).
backup (29.01.2021 00:00:18): backup completed: dbase-202101290000 (34.7M)
logger (29.01.2021 00:31:37): error while waiting for data from weather stations
logger (29.01.2021 00:31:37): disconnect station 0 (Vantage): wrap-up
logger (29.01.2021 00:31:37): disconnect station 9 (System Data): wrap-up
logger (29.01.2021 00:31:37): databases disconnected.
logger (29.01.2021 00:31:37): data logger stopped.
logger (29.01.2021 00:31:37): databases connected. Update interval 3600 seconds.
logger (29.01.2021 00:31:37): data logger (version 5.1e, build 1921) started.
logger (29.01.2021 00:31:38): connect station 0 (Vantage via USB serial).
logger (29.01.2021 00:31:38): connect station 9 (System Data via Plug-in).
logger (29.01.2021 00:31:38): station 0 (Vantage), wakeup sent.
logger (29.01.2021 00:31:39): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 00:31:39): station 0 (Vantage), setup script executed.
logger (29.01.2021 00:31:39): station 0 (Vantage), internal logger activated.
logger (29.01.2021 00:31:40): station 0 (Vantage), syncing.
logger (29.01.2021 00:31:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 00:31:41): services paused.
logger (29.01.2021 00:31:50): station 0 (Vantage), gettime request sent.
logger (29.01.2021 00:31:50): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 00:31:50): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 00:31:50): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 00:31:50): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 00:31:50): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 00:31:50): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 00:31:50): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 00:31:50): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 00:31:50): sensors are now providing data.
logger (29.01.2021 00:31:50): services started.
logger (29.01.2021 00:36:03): station 0 (Vantage), connection on port 22222 closed.
logger (29.01.2021 00:36:44): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 01:35:03): error while waiting for data from weather stations
logger (29.01.2021 01:35:03): disconnect station 0 (Vantage): wrap-up
logger (29.01.2021 01:35:03): disconnect station 9 (System Data): wrap-up
logger (29.01.2021 01:35:03): databases disconnected.
logger (29.01.2021 01:35:03): data logger stopped.
logger (29.01.2021 01:35:03): databases connected. Update interval 3600 seconds.
logger (29.01.2021 01:35:03): data logger (version 5.1e, build 1921) started.
logger (29.01.2021 01:35:04): connect station 0 (Vantage via USB serial).
logger (29.01.2021 01:35:04): connect station 9 (System Data via Plug-in).
logger (29.01.2021 01:35:04): station 0 (Vantage), wakeup sent.
logger (29.01.2021 01:35:06): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 01:35:06): station 0 (Vantage), setup script executed.
logger (29.01.2021 01:35:06): station 0 (Vantage), internal logger activated.
logger (29.01.2021 01:35:06): station 0 (Vantage), syncing.
logger (29.01.2021 01:35:07): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 01:35:07): services paused.
logger (29.01.2021 01:35:16): station 0 (Vantage), gettime request sent.
logger (29.01.2021 01:35:16): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 01:35:16): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 01:35:16): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 01:35:16): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 01:35:16): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 01:35:16): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 01:35:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 01:35:16): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 01:35:16): sensors are now providing data.
logger (29.01.2021 01:35:16): services started.
logger (29.01.2021 02:50:18): error while waiting for data from weather stations
logger (29.01.2021 02:50:18): disconnect station 0 (Vantage): wrap-up
logger (29.01.2021 02:50:18): disconnect station 9 (System Data): wrap-up
logger (29.01.2021 02:50:18): databases disconnected.
logger (29.01.2021 02:50:18): data logger stopped.
logger (29.01.2021 02:50:18): databases connected. Update interval 3600 seconds.
logger (29.01.2021 02:50:18): data logger (version 5.1e, build 1921) started.
logger (29.01.2021 02:50:19): connect station 0 (Vantage via USB serial).
logger (29.01.2021 02:50:19): connect station 9 (System Data via Plug-in).
logger (29.01.2021 02:50:19): station 0 (Vantage), wakeup sent.
logger (29.01.2021 02:50:20): station 0 (Vantage), no need to update console date/time.
logger (29.01.2021 02:50:20): station 0 (Vantage), setup script executed.
logger (29.01.2021 02:50:20): station 0 (Vantage), internal logger activated.
logger (29.01.2021 02:50:21): station 0 (Vantage), syncing.
logger (29.01.2021 02:50:22): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2021 02:50:22): services paused.
logger (29.01.2021 02:50:31): station 0 (Vantage), gettime request sent.
logger (29.01.2021 02:50:31): station 0 (Vantage), no Vantage time offset.
logger (29.01.2021 02:50:31): station 0 (Vantage), eeprom request sent.
logger (29.01.2021 02:50:31): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2021 02:50:31): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (29.01.2021 02:50:31): station 0 (Vantage), firmware version request sent.
logger (29.01.2021 02:50:31): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (29.01.2021 02:50:31): station 0 (Vantage), no reading of Vantage's internal logger.
logger (29.01.2021 02:50:31): station 0 (Vantage), 192.168.39.1's request on port 22222 accepted.
logger (29.01.2021 02:50:31): sensors are now providing data.
logger (29.01.2021 02:50:31): services started.
