Just realized the battery in my VSS is low, and realized I didn't have an alert configured.
I've got the following set, but it seems like it keeps flipping back and forth between "low" and not.
surprised I'm not getting hundreds of emails....
Thoughts?
Battery Alert Email. **solved**
- Alert.jpg (31.57 KiB) Viewed 3052 times
- Variable flip.jpg (107.26 KiB) Viewed 3052 times
Re: Battery Alert Email
ISS battery status comes from LOOP1 data. LOOP2 doesn't contain battery status. The Meteobridge needs to flip back and forth between reading both LOOP1 and LOOP2 data. Perhaps making a recommendation to Boris that battery status not be updated during LOOP2 is a possible solution.
https://www.wxforum.net/index.php?topic=41225.0
Meteobridge RPI | GW1000
I don't se a flipping in the posting. Raise event is always true (1) and clear event always false (0).
Ah good point. I didn't look that closely.
Non-issue then.
Non-issue then.
Oooohhhh. Gosh. Now I feel dumb for not looking closely.
Thank you!
Hoping to replace battery on ISS tonight if my roof dries off.
Thanks again!
Thank you!
Thanks again!
