Very annoying inconsistency. **solved**
krischj
Post by krischj »
Reporting on sensors works really well with MeteoBridge.
Of course choices has been made, ex: when reporting on sensor and for a given timeframe, having several “max” values (several occurrences of the same max-value) within a given timeframe, it is always the first max-value that is reported (you can see that when also reporting on the max-time for that max sensor value). This is perfectly fine and is consistent thought-out all the sensors with one very annoying exception.
The wind0maxdir-sensor consistently reports the wind0maxdir:degress from the latest occurrence within a given timeframe, not the first.
Reporting on:
[wind0wind-max.1:--] [wind0wind-maxtime.ij:--]:[wind0wind-maxtime.kl:--] [wind0maxdir-max.0:--]
Given that you have 2 [wind0wind-max.1:--]=11,9 m/s first with [wind0maxdir-max.0:--]=281 deg and @ 17:09 hrs and the second one with [wind0maxdir-max.0:--]=303 deg @ 17:18 hrs,
the report would be:
11,9 17:09 303
Where it should be:
11,9 17:09 281
Would it possible change this and make [wind0maxdir-max] consistent with all the other sensors, meaning reporting on the first occurrence within a given timeframe instead of the last.
//kris
Re: Very annoying inconsistency
Looks like this issue shows up when doing exports, not when using the template replacement. right?
I checked code and on template evaluation the first occurrence is selected while the export and graphing code selects the last one.
I will change to always first occurrence in next release.
Thanks for spotting this.
Why should it be the first occurrence?
The last occurrence is really the most relevant one? OR am I missing something here?
I don't have a bias on that. Can also make it the last occurrence.
Please try just released version.
krischj
Post by krischj »
Hi Boris,
It works perfectly, Thanks
All sensors incl wind0maxdir-sensor are now reporting consistently.
(@Mattk: As mentioned consistency across all sensor is the important issue, first or last is less important, - personally I prefer first)
//kris
krischj wrote: Fri Apr 23, 2021 5:51 pm ....(@Mattk: As mentioned consistency across all sensor is the important issue, first or last is less important, - personally I prefer first)
From a wind perspective the time and direction of say a peak gust of the day can be rather meaningless based on the first occurrence. For example a peak gust at say 12:01 being the first occurrence is flagged as the peak gust for the day then at say 18:00 hours that is still being reported as the peak gust details for the whole day when maybe at 17:00 hours there was an equal peak gust speed (and this scenario does occur quite a bit) and even being a totally different direction that has way more importance than the first so called gust occurrence at 12:01
It is now reporting the last incident.
krischj
Re: Very annoying inconsistency. **solved**
Post by krischj »
Hi Boris,
There was a perfect consistency across all sensor on the 23rd release, now the inconsistency has been re-introduced.
There is now no way to get the the wind0maxdir for the either the first or last wind0wind-max, since wind0wind reports first and wind0maxdir reports the last.
As long as as all sensors report the same (first or last) I am happy, bur all other reports on first, so...
/kris
please try again with just released version.
krischj
Post by krischj »
just tried april 27th release, the export is still the same as in my april 17th post.
The april 23rd release reported 281 degrees @ 17:09 which was perfect and consistent :-)
//kris
