cbhiii
Posts: 306 Joined: Fri Feb 15, 2008 2:02 am
Post
by cbhiii » Fri Mar 13, 2009 3:33 am
Running v4.1f on eBox-3300
My system log has stopped updating. Note the date on the log and the current time this image was taken.
Anyone else with this problem?
Station:
Davis Vantage Pro2 Plus
Hardware:
Raspberry Pi 2 (
Meteohub status )
Posts: 8022 Joined: Mon Oct 01, 2007 10:51 pm
Post
by admin » Fri Mar 13, 2009 11:03 am
can you give me access?
cbhiii
Post
by cbhiii » Sat Mar 14, 2009 12:18 am
Just emailed my IP. Thanks.
Station:
Hardware:
Raspberry Pi 2 (
Meteohub status )
Post
by admin » Sat Mar 14, 2009 9:09 pm
It looks like "logrotate" does remove the installed symlink on x86 under certain circumstances. I changed config for logrotate, which hopefully will fix this. Will be part of next update.
BTW: Doing a reboot always fixes it temporarily.
cbhiii
Post
by cbhiii » Sun Mar 15, 2009 12:24 am
Yes, I rebooted, but it stops a few hours later again. Always seems to stop on 08:18 or 20:18.
Thanks, I'll look for the update.
Station:
Hardware:
Raspberry Pi 2 (
Meteohub status )
Post
by admin » Tue Mar 17, 2009 7:48 pm
please check if 4.2rc2 (or newer) still has this problem on x86.
cbhiii
Post
by cbhiii » Tue Mar 17, 2009 10:40 pm
My system log has stopped again. Feel free to connect to it again if needed. Running 4.2rc2.
Station:
Hardware:
Raspberry Pi 2 (
Meteohub status )
Post
by admin » Wed Mar 18, 2009 1:09 am
rc3 is a cure for that. I installed it on your system. Should work flawless now... hopefully ;-)
cbhiii
Post
by cbhiii » Wed Mar 18, 2009 8:32 pm
Sorry to rain on your parade.
I just logged in and found that the system logged stopped again yesterday at 20:18:xx under version 4.2rc3.
Same IP if you want to log in.
Cheers!
Station:
Hardware:
Raspberry Pi 2 (
Meteohub status )
