System Log No Longer Updating
cbhiii
Post by cbhiii »
Running v4.1f on eBox-3300
My system log has stopped updating. Note the date on the log and the current time this image was taken.
Anyone else with this problem? Image
Re:System Log No Longer Updating
can you give me access?
cbhiii
Post by cbhiii »
Just emailed my IP. Thanks.
It looks like "logrotate" does remove the installed symlink on x86 under certain circumstances. I changed config for logrotate, which hopefully will fix this. Will be part of next update.
BTW: Doing a reboot always fixes it temporarily.
cbhiii
Post by cbhiii »
Yes, I rebooted, but it stops a few hours later again. Always seems to stop on 08:18 or 20:18.
Thanks, I'll look for the update.
please check if 4.2rc2 (or newer) still has this problem on x86.
cbhiii
Post by cbhiii »
My system log has stopped again. Feel free to connect to it again if needed. Running 4.2rc2.
rc3 is a cure for that. I installed it on your system. Should work flawless now... hopefully ;-)
cbhiii
Post by cbhiii »
Sorry to rain on your parade.
I just logged in and found that the system logged stopped again yesterday at 20:18:xx under version 4.2rc3.
Same IP if you want to log in.
Cheers!
