- prestwickwx
Ok. No big issue. I probably have more in the menus than I need.
Best wishes,
Best wishes,
- jmontamat
Hi Chuck.prestwickwx wrote: Wed Oct 06, 2021 5:55 pm
Hi Josep,
I just looked at the OS2 version, on your site, using Windows 10 (Chrome and Firefox) and it looks good from here. I tried to upload a screenshot but the forum is rejected my uploads.
I corrected it here but I don't know if it's correct:
.charthome {
z-index: 150;
font-family: verb;
height: 70px;
width: 270px;
background-color: transparent;
box-shadow: none;
padding-top: 0;
position: relative;
in preload.php,
I don't know how it will look in other systems.
todays update added Purple Air / Davis Airlink / Luftdaten module with chart view if option set to yes if no reverts to wind average module,
Download Update 7th October 2021
* (10:59) * Update all additions from March 2021 to October 7th 2021
* (10:59) * Significant update
* (10:59) **New ** optional layout for alternative screens with charts
* (10:59) * Adds Luftdaten module with chart display
* (10:59) * Adds Davis Airlink module with chart display
* (10:59) * Adds Purple air module with chart display
* (09:26) * Increase rain last time to 72 hours Ref Tom
* (09:26) * Aligns UV chart
***edit have updated to support Davis AIRLINK/ Luftdaten module with chart view
Purple Air
Davis Airlink
Luftdaten
Purple Air
Davis Airlink
Luftdaten
- rzelle-K1TTC
Excellent additions to the OS Alt screens ...
Now our new GoTo screen.
Re PurpleAir and lot's of 0 readings. Trees are the problem will just have to cut them all down ... lol We're surrounded by lot's of very tall deciduous and pines except to the SW. Here is a copy of one of the responses from the PurpleAir support:
Check out this article, specifically the part about particulate matter:
https://edu.rsc.org/feature/how-do-tree ... 64.article
They say that tall trees act like a “brick wall” against particulates, so those big guys could very well be taking the brunt of any particles swirling around your home.
I am finding PurpleAir support quite responsive.
73s
..Ron
73s
..Ron
Good morning Ronrzelle-K1TTC wrote: Thu Oct 07, 2021 10:40 pm Brian,
Excellent additions to the OS Alt screens ...Now our new GoTo screen.
73s
..Ron
now you get the part of why deforestation of any kind is a problem..my wife during the various lockdowns over the last 18 months went berserk on indoor plants of various types but looking closer our indoor air quality improved over time according to our indoor monitor https://www.iqair.com/air-quality-monit ... visual-pro had this for a few years now ,its the only instrument wife permits to be in the salon as it has that non industrial look ..
glad you like the newer layout I actually really like it , for years I have looked for a layout that just makes me feel "finally I got what I envisioned" ,things evolve and I really do like that newer layout , it doesn't feel congested which is always something that either happens or ends becoming .Its easy on the eye ..
ps Ron you need to look at your interval for running the chart day cron in Meteobridge looks to me your running at less than ten minutes ,all day charts old or new have always been set to use intervals based on ten minute data.you don't gain or miss anything as the Meteobridge script used collects data from the last ten minutes if you run the cron at less than ten minutes you basically end up duplicating the data and doubling the file size.
excerpt from https://weather34.com/homeweatherstatio ... guide.html
a. Charts for Today
Select the Services Tab
1. Goto meteobridge services screen
2. Goto Select new service
3. Select from the drop down menu HTTP Request
4. Select Perodical in the next menu
5. Click Save at the bottom of the screen
6. Now look for new HTTP request
7. select every "FULL 10 MINUTES"
8. NOW INSERT THE URL examples
8a. https://yourdomain.com/aurora/chartstoday.php
8b. https://yourdomain.com/console/chartstoday.php
8b. https://yourdomain.com/"name of the folder the template resides in"/chartstoday.php
9. now click save .
*the path can be in the root if the template was uploaded to the root directory https://yourdomain.com/chartstoday.php
hope that helps..
Download Update 8th October 2021
* (09:14) * Update all additions from March 2021 to October 8th 2021
* (09:14) * Significant update
* (09:14) **New ** optional layout for alternative screens with charts
* (09:14) * Cleans up chart views
* (09:14) * Auto interval for time in chart display
* (09:14) * Remove internal chart tooltips
* (09:14) * Reduce load when using newer chart display OS
here's my basement iPad ..
- jmontamat
Good morning Brian, if uv = no, appear at https://meteosantgenis.org/MKII/weather ... tablet.php
- Captura de pantalla (88).png (82.4 KiB) Viewed 5916 times
- jmontamat
Thanks, quick reply.
Have a nice day.
Have a nice day.
your welcome , many thanks just me thinks i need another sticky note * dont forget no uv sensor setups
@alex i havent forgot mmHG just not got around to set it up yet..
- prestwickwx
Great updates.
. Removing the Tooltips from OS2 really speeds it up.
I have rearranged a little to get the version switch icons on the Tool Bar for quick switching to each screen version. Working great except for one overflow on the OS2 version on mobile. Seems to have an extra space. No problem, I will find it.
https://myrtleweather.com/console/index.php
Have a great weekend!
Great updates.
- jmontamat
It's the size of the $weather34smtv icon reduced the width to width = "23pt" works fine.prestwickwx wrote: Fri Oct 08, 2021 6:13 pm Hi Brian,
Great updates.. Removing the Tooltips from OS2 really speeds it up.
I don't want to distract Brian with details.
https://meteosantgenis.org/pws/weather34-os2-tablet.php
Ok only problem Chuck is this can't be a permanent method as updates will break it , I see you substitute the Unit C/F icon .so this change below is a one off you will have to remember.Think most want to have a quick UNIT C/F option but below will give you what you want.prestwickwx wrote: Fri Oct 08, 2021 6:13 pm Hi Brian,
So I've updated the CSS files just pushed to GITHUB with a new class to have things right in mobile view for you .
so in weather34-os2-tablet.php
simply cut and paste this think this replicates what you've shown above
<bottomtoolbarspacetablet></bottomtoolbarspacetablet>
<a href="index.php" data-title="Dashboard" class="showicon4"><?php echo $adjust2?></a>
<a href="index.php" data-title="Dashboard" class="showicon2"><?php echo $adjust2?></a>
<a href="weather34-tablet.php" data-title="OS Theme" class="showicon4"><?php echo $weather34smtv?></a>
<a href="weather34-tablet.php" data-title="OS Theme" class="showicon2"><?php echo $weather34smtv?></a>
<a href="consolecharts.php" data-title="Daily Charts"><?php echo $weather34chart2?></a>
<a href="outlookwutext.php" data-lity data-title="Forecast"><?php echo $weather34foret?></a>
<a href="weather34-os2-tablet.php" data-title="Refresh" class="showicon2"><?php echo $weather34refr?></a>
<weather34-rightfootericons><aurora>Aurora MKII (Vantage-OS2)</aurora>
Download Update 9th October 2021
* (13:10) * Update all additions from March 2021 to October 9th 2021
* (13:10) * Significant update
* (13:10) **New ** optional layout for alternative screens with charts
* (13:10) * Aligns all chart modules to use identical CSS
* (13:10) * New Adds mmHG option in setup screem
* (13:10) * Adds rain accumulated color shades of blue
* (13:10) * Adds seperate mmHG module for OS layouts
* (13:10) * Adds minor CSS addition Ref Chuck
* (13:10) * Adds Lux Tooltip to UV module
* (13:10) * Adds Max/Min day tooltip to modules
*** those using air quality don't forget to change the small module option or you will be duplicating the data view with a large and small module
should now resemble this based on your options set
have a good weekend ...Brian
- jmontamat
Good morning Brian, some servers are not case sensitive.
barometermodmmHG-tablet2.php
updater-tabletchart.php :
barometermodmmHg-tablet2.php
The rest all good.
The rest all good.
I don't understand filename is barometermodmmHG-tablet2.php and the script calls barometermodmmHG-tablet2.php . not sure where the case sensitive comes in unless one was
called barometermodmmHg-tablet2.php with a lowercase and
calling barometermodmmHG-tablet2.php.
