firmware 5.2 of 7 oct issue. **solved**
ruzzi.f@gmail.com
- Senior Boarder
starting from today (after firmware update) all my meteobridge pro started having issue:
1) after start they eork for 15-30 seconds
2) after that time they still receive signal but the log says is waiting for signal and logger restarts
3) after restart it works few seconds and.....back in the loop
I have 3 MB pro in different location and all the same
Maybe some issue with last firmware??
ruzzi.f@gmail.com
- Senior Boarder
Re: firmware 5.2 of 7 oct issue
the new version today did not solve the bug
I have meteobridge with davis meteo station.
Please let me know what to do because I have all stations off.
Not seeing any issues with FW 5.2 (Oct 8 2021, build 14608) running on MB Pro and Davis VP2
ruzzi.f@gmail.com
- Senior Boarder
I had to install version 5.1 and eliminated the issue in all 3 meteobridge.
With latest version 5.2 starting from yesterday/today all 3 meteobridge pro were restarting logger every minute....
What else can it be? Thanks
ruzzi.f@gmail.com
- Senior Boarder
I just retried to install latest version and had problem again. With FW 5.1 no issue
ruzzi.f@gmail.com
- Senior Boarder
here you can find the log file
- CCD0D752-8548-4C03-855E-CBCAD484CD09.jpeg (472.58 KiB) Viewed 2748 times
Still all good here with FW5.2/14608, been up for around 14 hours, no issues. Your Rx threshold is set to -95db? What signal strength do you see on the Raw Sensor data?
ruzzi.f@gmail.com
- Senior Boarder
that mb is set to 95 and I have signal around 85.
other 2 mb are set at 80 since signal is much stronger.
must be related to fw version because all 3 mb behave in the same way.
all of them has same issue and all of them work fine when back to fw 5.1
ruzzi.f@gmail.com
- Senior Boarder
“child process received termilation signal (11)”
this is the error generated in all 3 mb pro with FW 5.2
Maybe the new FW is not compliant with all settings?
Did you find the bug?
Fabio
Fabio
Bug should be solved with just released update.
ruzzi.f@gmail.com
- Senior Boarder
Re: firmware 5.2 of 7 oct issue. **solved**
yes now it seems being working well
thanks
thanks
