- jmontamat
Good morning, any problem with
.grid-containercharts
on Samsung 16:9 tablet in all browsers.
https://meteosantgenis.org/MKII/
- Screenshot_20211105-092001.jpg (32.25 KiB) Viewed 6147 times
]jmontamat wrote: Fri Nov 05, 2021 10:32 am Good morning, any problem with
Hi Josep I can't reproduce this unless I use the zoom increase to 180% on my laptop ! are using a zoom increase ? I can't help much I don't own anything or have anything android etc apart from a Smart TV . no changes have been made to css in relation to charts I can recall.
Im back here in istanbul till Monday , I have an appointment for my third dose (booster jab) later today . This morning I have applied some fixes/changes raised in emails this week. Please note If I don't respond in a timely manner Im not ignoring just preoccupied and restricting my time I use the internet.
Change Log 6th November 2021
* (10:31) * Contains all features/fixes from Oct 1st to Nov 6th
* (10:31) * Adjust day temp chart difference is less than 1 Ref Gary
* (10:31) * Consolidates sun/moon/meteor info pages into 1 page
* (10:31) * Adjust month date auto intervals display in charts
* (10:31) * Removes unused files and code no longer required
reworked consolidated sun/moon/meteor page which is accessible via single menu link or relevant sun module if in use
- consolidated.png (129.48 KiB) Viewed 6124 times
- jmontamat
Hi Brian, in August it was working well, I have found some difference ...
.grid-containercharts{display:flex;flex-direction:row;flex-wrap:wrap;width:99%;display:grid;grid-template-columns:repeat(auto-fit,minmax(300px,3fr));gap:1px;grid-gap:1px;filter:brightness(105%);-webkit-filter:brightness(105%)}
Josep try the file just pushed to GITHUB..Changed 320px to 300px
- prestwickwx
Hope all is well.
I just noticed that the new Sun|Moon update is showing an overflow in Firefox.
Good luck with the Booster and take care.
Hope all is well.
ok ill take a look shortly time to install firefox on laptopprestwickwx wrote: Sat Nov 06, 2021 4:22 pm Hi Brian,
Hope all is well.
- prestwickwx
All fixed
Best wishes,
All fixed
Best wishes,
alexeysailman
- Expert Boarder
Hi, Brian!
I don't know about others, but it happens to me sometimes (without any regularity) that the day charts is not stored in month charts. But the daily file itself, as I understand it, on the basis of which the maximums and minimums for the monthly chart are then added, remains in the "/weather34charts" directory. As a result, if you then open the monthly charts, "a day falls out" (for example, November 1, 2, 3, 5). I don't know how many people face this problem, maybe there is a mechanism for "manually" adding daily charts to monthly charts? For example: I noticed today that there was no upload to the monthly charts for yesterday, the script (weather34-chart-end-of-day.php ) you can run it yourself. But what if a few days have passed? And only then I noticed it, but as I wrote above, did the file remain for that day?
- jmontamat
Just a curiosity, why does this happen at the beginning of the day the rain at xx: 10 and not xx: 00 ??
- Sin título.png (25.79 KiB) Viewed 6020 times
Hi Josep a solution was requested many months ago may be a year ago, Meteobridge itself at 00:00 sends previous day total at 00:10 previous day total does NOT get sent .jmontamat wrote: Mon Nov 08, 2021 1:00 pm Just a curiosity, why does this happen at the beginning of the day the rain at xx: 10 and not xx: 00 ??
So the rain day chart is compiled to ignore first line of day data at 00:00 .
if you had rain yesterday check your current day csv you will see a value at 00:00 and if rained yesterday(previous day) it will likely have that total value .it was very apparent on sites like lars in Singapore who can have upto 100-160mm regularly in a day this would throw out intervals for following day if they were zero or a less significant amount. remember csv file is only storing data Meteobridge sent at that specific time template doesn't manipulate the data.
example screenshot..in short the first 00:00 data line is ignored is rain day chart.
@Alex likely your server was unreachable at that given time(02:00) it happens here from time to time may be once or twice a year.you have daily charts csv files stored ? so the data is on your server in a file example 4Nov2021.csv just its tedious process looking for the high and lows or you can use Meteobridge history tab to get a date specific hi and lo , avg . so in short the data is there to fall back on.
thank you for the enquiries about NANOSD RED it has now been sold . as in advert sincerely apologize but PAYPAL is not recognized here or accepted simply no Turkish bank or credit card company will honor the transaction from PAYPAL since 2016 .
there is one forthcoming update with minor additions and some small CSS changes so I think this now has reached its limit in what can be added without losing sight of original idea .I certainly don't want to have another congested layout design or have something unmanageable .
Ecowitt users the nag screen has been removed it will simply run with the standard sensor layout at present it doesn't cater for those additional sensors that said Ryan has compiled a version to accommodate the Ecowitt sensor array by using a separate manual driven configuration in Meteobridge itself so in due course a separate version Ecowitt hardware will be available to download with instructions how to setup in Meteobridge via a GITHUB repo and maintained by Ryan which will simply be able to use the simple update files as the only difference is or will be the livedata file and few extra modules to cater for the extra sensor arrays . That said Weather34 will not answer enquiries or requests all issues should be made via the GITHUB repo issues section. So when its ready ill post a link via main template page. If it becomes popular I can make request for a new separate API to Boris once any issues have been ironed out or if the process of all the extra sensors proves to be easily maintainable in template itself .So please remember Weather34 is not answering questions or dealing with this addition.
Brian
Brian
@chuck something to amuse you with Apple Watch ..
download app on App Store for iPhone called free Parity https://apps.apple.com/us/app/parrity/id1448208309
auto installs on Apple Watch , use your iPhone with Parity app type in url or cut and paste from safari app etc ,open Parity app on your watch it will sync to App on iPhone .. I found alt theme better(snappier) not having to load graphs to work best /os theme with graph does it job but less snappier but perfectly useable and voila weather34 on your Apple Watch .. nothing special but useable for quick glance at sensors ,you can scroll up and down .
- jasonmfarrow
Excellent find Brian!weatherist34 wrote: Sat Nov 13, 2021 12:26 pm download app on App Store for iPhone called free Parity https://apps.apple.com/us/app/parrity/id1448208309
- prestwickwx
Hi Brian,weatherist34 wrote: Sat Nov 13, 2021 12:26 pm @chuck something to amuse you with Apple Watch ..![]()
Browser on the watch. Works great.
