Data recovery from the meteohub
masgio69
Post by masgio69 »
Hi, I'm uploading the data I had on my meteohub in raw format to the meteobridge pro, I realized that the wind0chill tag is regularly created with all the related data but the th0heatindex tag is not created. Yet in the meteohub I have these values, where am I wrong? The sensors have the same name on both platforms.
Re: Data recovery from the meteohub
Are you sure that heatindex data is part of the raw data exported by Meteohub?
masgio69
Post by masgio69 »
Senza titolo.png (424.29 KiB) Viewed 5493 times
The raw raw data of the weather hub have only the data relating to the sensors, the calculated values such as heatindex and windchill are not there, as per the attached image, but once the data has been imported, the values relating to the windchill are found and heatindex are not ... ..
masgio69
Post by masgio69 »
Having the necessary data, how do I get the meteobridge to calculate the heatindex value?
Windchill data is in the wind lines (last item). Meteobridge does not compute it. As heatindex is not in the data it does not show up on import. Works as designed, no bug.
Just checked how to compute heatindex. As it does not depend on data apart from the TH sensor, Meteobridge could do a rather easy computation on imnport. I will put it on my todo list.
masgio69
Post by masgio69 »
Thank you so much!!!
masgio69
Post by masgio69 »
Hi, do you have any idea when you might implement this feature? I'm almost finished copying about 10 years of meteohub data to the meteobridge. To complete the data I only need the heatindex that I can find through nooa tables, but I would have to write them all by hand .....
It is already implemented in the latest release.
masgio69
Post by masgio69 »
Hi, I have version 5.2 installed, under which heading do I find the possibility to create the heatindex data?
Thank you very much for your availability.
It is now done when importing the data. It is not a separate post-processing step.
masgio69
Post by masgio69 »
Hi, sorry if I disturb you again, I have data in .sdb format, can I retrieve them via the meteobridge?
Sorry, I have no idea what ".sdb" data is.
masgio69
Post by masgio69 »
* .Sdb files are database archive files, in my specific case it was used by a weather server with wview base. Mine was just curiosity, if it is not possible to automatically add the data manually.
Hello and thanks.
not supported.
Ricky
Re: Data recovery from the meteohub -Windchill
Post by Ricky »
From these Forum posts it seems Windchill is computed somewhere. It is selectable in the Define Graphs dialogue. However, while Isee the Windchill Legend in the graph, I get no trace. Simple solution?
